| Engine Swaps Discussion of engine swaps. |
#29 | |||||
Drives: AP2 S2000, S14 240sx
I've done some serious time attack bench racing in my head concerning this very subject (lol), only I was thinking about putting an F22C into a 240sx or FD RX7. However, the benefits would be similar. Let me break it down: First, the F20C/F22C is simply a better engine than the SR20DET, FA20, 13B, etc. when you consider all the factors together: reliability, efficiency (fuel enconomy), flow, power capability with forced induction, etc.... It's one of the best 4 cylinder engines you can get. Yes, the 13B can make a lot of power, but it's going to cost you a lot of money to build, a lot of money to fuel, and it's most likely not going to be as reliable. As for the SR20DET, they too can be awesome when you convert them to use the NEO VVL head from the NA FWD SR20VE. It flows much, much better than the DET head and features variable valve lift, similar to Honda's VTEC, while also eliminating the DET's main weakness (breaking rocker arms) by having a better design (rolling rockers). Once you do that, it becomes an incredible engine. The problem? It costs a lot of money to do that. Also, F2xC engines seem to last a lot longer without needing to be sleeved compared to SR20VET setups. Cost effective! This leaves us with addressing the alternatives: LSx swaps. LSx swaps are very common in drifting because of only 2 things: cost and torque. They are perfect for constantly being able to break traction as easily as possible, but they aren't perfect for small, front-biased Japanese coupes/roadsters competing in time attack. Why? 2 reasons: Weight and torque. They weigh more. Sometimes that weight difference is minimal, but every little bit counts in time attack cars, as it makes a huge difference in handling. As for the torque, it can be difficult to dial in the right balance of traction and power. Smaller engines with a turbo are just a bit easier to get the proper balance when you're trying to maintain as much grip as possible. This is why you don't really see any competitive LSx Silvias/RX7s/S2000s/Miatas/etc. in pro time attack. There are some, but they aren't winning. So, back to the F20C/F22C. Besides being very good engines that can make a lot of power with boost, you are able to get a 2.2L right out of the box! Most people running SR2xVETs go for at least 2.2L to get just a bit more torque (but not too much like in a big V8).... Some do 2.3L or 2.4L, but there are very, very successful cars running 2.2L..... With the F22C, you get this right out of the box. Again, it's cost effective! Now, to address this..... the BRZ may be a better option, but I don't really think it's because of stiffness. The S2000 is plenty stiff already, and so are the Silvias and RX7s when caged, and those are significantly less stiff than the S2000. I think the real advantage comes comes from 2 things: 1. Weight and 2. Stability. It's a slightly lighter car than the S2000, and it has a significantly longer wheelbase, making it much more stable at high speeds. For as incredibly agile and awesome the S2000 is at low to medium speeds, the short wheelbase and hyper-responsive steering can make it unstable at high speeds compared to these other cars, especially something like an S14/S15 or BRZ/FRS. This is the same reason why Miatas dominate autocross so often, but almost never do well in time attack. However, suspension design on the S2000 is easily better.... this is why you see most non-double-wishbones-all-around-from-the-factory time attack cars (Evos, WRXs, Silvias, etc.) using custom fabricated double wishbone (or even push-rod) suspension. This is not easy to do and is very expensive because it's not easy to find people to do it right for you. So, again, it's about tradeoffs.... This is one area where the RX7, S2000, and NSX really excel. Quote:
Now, keeping all of the things previously mentioned in mind, think about how the longer wheelbase of a car like the S14 (longest wheelbase of the Silvias) or FRS/BRZ (much longer than even the S14) would aid the car's stability at high speeds and you start to understand why the F22C actually makes a lot of sense for a dedicated time attack car, IMO. I've recently been considering trying to swap one into my S14... much more difficult than dropping in an SR20DET at first, but potentially much more cost effective in the long run if looking for a serious track car project! Last edited by Sideways&Smiling; 01-15-2016 at 08:13 PM. |
| The Following 3 Users Say Thank You to Sideways&Smiling For This Useful Post: |
#30 | |
Built Not Bought
Drives: 2012 Toyota 86 ZN6
#31 | |
Thank about it from a physics standpoint. An unbalanced car with a smaller moment of inertia around the yaw axis, will still rotate faster than a balanced car with a larger moment of inertia around the yaw axis. Another example. If you move the center of mass, and thus the axis of yaw, further back, it means when you turn the front wheels, they now have more leverage to turn the car. Hmmm.....
#32 | |
And, yeah, I'd imagine it's much more often attempted to put the weight in the center, but I think sometimes moving it a little farther back might be desired considering how much weight you already have up front and whether or not you might want a slightly more rear-biased distribution to get better traction. For me, besides the aero, I think the custom double wishbone suspension would be the hardest stuff to fabricate. It's so hard to find people in the U.S. to do that. I've been looking for people to convert the S14 to use wishbones for a while, and I can't find anybody except for people in the time attack scene in Australia/New Zealand. :[ |
#33 |
Drives: FRS
i don't know much about swaps and engine positions but damn that engine sits nicely right by the firewall...
for someone who has been cross shopping from AP2 - FRS this swap seems best of the both worlds...
'14 Scion FRS
Tein Flex TE37 |
#34 |
Drives: Nevermorange FRS
So I just looked at the picture and tried to answer the question of "why?".
I came up with:
PRO86 | WTCC | STL
| The Following User Says Thank You to rice_classic For This Useful Post: | MrFisty (04-05-2016) |
#35 | |
Junior
Drives: a car
Opposite thought (the the logical mathmatical proof); putting weight near the ends of the car would require more torque from a steering standpoint.
#36 |
#37 |
Drives: Toyobaru
It makes way more sense to go with a K20,K24 since you can get 250-300whp adapter plate for S2 trans and that's it but I guess F20-F22 is not bad either.
#38 |
Drives: white subaru brz
Damn I'm really intrigued by this swap.
when attempting to be the first person to do a swap, would I be easiest to contact wiring specialties to see if they can fan up a plug n play harness? |
#39 | |
Drives: RAVEN
I once started a thread on the main FRS forum with the tittle " Would you prefer that the FRS had a "real" engine? That was almost a year ago, still trying to put the flames out! Who knew that the boxer was a sacred design? Or is that sacred cow? |
#40 | |
Drives: '13 FRS - STX
PANCAKE MOTOR!!!!!111!!!111!
#41 |
PRO86 | WTCC | STL
#42 |
| The Following 2 Users Say Thank You to jdmblood For This Useful Post: | Draco_PR23 (04-05-2016), Sportsguy83 (04-04-2016) |
| F20C performance out of the FA20 | discretion | Engine, Exhaust, Transmission | 41 | 06-12-2015 10:37 AM |
| 2JZ swapped BRZ ... | rh9 | Engine Swaps | 32 | 12-08-2014 01:50 AM |
| How many of you Swapped your 86 for 15 WRX ? | Xti | Scion FR-S / Toyota 86 GT86 General Forum | 45 | 08-09-2014 09:09 AM |
| F20c engine | Whitigir | Engine, Exhaust, Transmission | 4 | 11-03-2013 07:03 PM |
| BRZ Swapped with LS2 | weedtank | FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum | 13 | 09-05-2013 05:02 PM |
