Southern California SoCal
Old 01-14-2016, 04:43 PM   #407
PradiG
Drives: Fr-s
Originally Posted by BRZtoni View Post
i have a harness bar and ordering a seatbelt harness
wont be installing until subaru calls me back to pick up my
both side b pillar trim so i can drill a hole to make it look more clean with the harness bar installed
When's the next DIY day?
PradiG is offline   Reply With Quote
Old 01-14-2016, 05:24 PM   #408
BRZtoni
Turbo E85
BRZtoni's Avatar
Drives: 13 wrb brz
Originally Posted by swarb View Post
@BRZtoni what brackets did you end up using? Are they centered to the steering wheel? even stock, the seat is to the left a little bit.
buddy club super low seat rails. i dont know never bothered checking
if its centered. seems centered.
Flex Fuel Turbo BRZ
BRZtoni is offline   Reply With Quote
Old 01-14-2016, 05:24 PM   #409
BRZtoni
Turbo E85
BRZtoni's Avatar
Drives: 13 wrb brz
not too sure got to talk to @LXXXV1
Flex Fuel Turbo BRZ
The Following User Says Thank You to BRZtoni For This Useful Post:
LXXXV1 (01-14-2016)
Old 01-14-2016, 05:42 PM   #410
ryoma
ryoma's Avatar
also, does your status seats have holes for side mounting? I saw a vendor on here selling packages for the status seats and I like how they're customizable. I definitely want mine in alcantera lol, but I also want to side mount them and not put them on rails. and maybe swap over the seat warmers too but I doubt I will even use it in this weather
Old 01-15-2016, 08:28 PM   #411
VIC_BRZ
VIC_BRZ's Avatar
I'm thinking about getting a backup cam. Do any of you guys have one installed and have any recommendations?
VIC_BRZ is offline   Reply With Quote
Old 01-15-2016, 09:16 PM   #412
ryoma
ryoma's Avatar
I have the Rydeen duo. it has a full metal body and is pretty solidly built. since you drive a BRZ, you don't need to do anything aside from buying an adapter and the camera. the FRS guys need to add in a reverse trigger. here are some pictures from when I installed mine: http://www.ft86club.com/forums/showp...9&postcount=59
The Following User Says Thank You to ryoma For This Useful Post:
VIC_BRZ (01-16-2016)
Old 01-16-2016, 02:01 AM   #413
sillierabbit
Drives: 2014 FR-S Monogram Whiteout AT
My brother @LXVVV1 has it installed. He can chime in.
sillierabbit is offline   Reply With Quote
The Following 3 Users Say Thank You to sillierabbit For This Useful Post:
BRZtoni (01-16-2016), LXXXV1 (01-16-2016), VIC_BRZ (01-16-2016)
Old 01-16-2016, 02:30 AM   #414
tinma
Drives: '13 BRZ
Interested in backup cam as well
tinma is offline   Reply With Quote
Old 01-16-2016, 02:31 AM   #415
VIC_BRZ
VIC_BRZ's Avatar
Thanks I'll look into that, sounds like really simple install.
Old 01-16-2016, 11:49 AM   #416
LXXXV1
LXXXV1's Avatar
Drives: 2014 FR-S Monogram, Whiteout 6MT
I have the Beat Sonic BCAM7 and the BCUS3 harness. Really easy install, plug and play. Bit pricey imo but I got it during special event pricing.
2007 Honda CBR600RR-Pearl White/Silver - Totaled
2014 Scion FR-S Monogram-Whiteout - #LXXXV1 (build)
φφκα
LXXXV1 is offline   Reply With Quote
The Following 2 Users Say Thank You to LXXXV1 For This Useful Post:
BRZtoni (01-16-2016), VIC_BRZ (01-18-2016)
Old 01-23-2016, 09:14 PM   #417
VIC_BRZ
VIC_BRZ's Avatar
Has anyone installed the whiteline KDT922 kit, its the bushing inserts for the rear subframe. With the bushings in I can't get the rear bolts to lineup, but if I take them out the bolts go right in.
Old 03-14-2016, 01:18 AM   #418
nova.86
Legendary Member
nova.86's Avatar
Drives: HyperBlue BRZ
Any chances of there being one soon? Just ordered a front pipe lol
nova.86 is offline   Reply With Quote
The Following User Says Thank You to nova.86 For This Useful Post:
BRZtoni (03-14-2016)
Old 03-14-2016, 01:30 AM   #419
BRZtoni
Turbo E85
BRZtoni's Avatar
Drives: 13 wrb brz
Ill be installing ap racing big brake kit very soon before track day.
will be needing someone to help me bleed calipers
I can help you with the front pipe. Ill be be free 2 weeks from now ill be in maryland and newyork next weekend.
Flex Fuel Turbo BRZ
Old 03-14-2016, 12:11 PM   #420
LXXXV1
LXXXV1's Avatar
Never considered installing these. Ever figure it out? Would be interested in your solution.
Front pipe is easy. Make sure you have new gaskets, unless you don't mind running the risk of reusing your old ones. 1-2hr job, to let pipes cool down. If you can find a local place to work on it, I can help and I'll have all the tools you'll need to do it.
Depending on my work schedule, I may be down to help. I have yet to install my JDM underpanels bc I have no where to work on my car lol.
φφκα
The Following User Says Thank You to LXXXV1 For This Useful Post:
