#113 |
is Tsudo pronounced the same as pseudo? hmmm
| The Following User Says Thank You to swarb For This Useful Post: | bfrank1972 (12-11-2015) |
#114 | |
#115 | |
Drives: 2005 Toyota Camry
Just exchange it so you are not stuck with something you can't sell later... -alex |
| The Following User Says Thank You to mav1178 For This Useful Post: | Cole (12-11-2015) |
#116 | |
Drives: 2017 86
Sent from my Nexus 6P using Tapatalk |
| The Following User Says Thank You to invaliduser For This Useful Post: | Cole (12-11-2015) |
#117 |
Not a troll
I feel like it is.
On topic, bargain bin parts are always a bit of a gamble. I've lost on 2 of them. A cheap exhaust I had didn't hang evenly and my CNT header was off by about 1/16th of an inch, so I had to hammer it with a rubber mallet to get one side to slip onto the studs. |
#118 |
Drives: 2013 Frs:Full Exhaust, NA etc
Well I disconnected the sensor from the ECU female connector that is mounted by the battery. Fully removed the sensor and its wire from the car. TBH I didn't notice it was missing the 2nd sensor hole until I pulled the factory header off. At that point I figured I could just do without the second sensor, assuming I could take care of the CEL by tuning. User preference I suppose.
#119 |
Thanks! Yeah I will check with the return policy and whatnot. I love the way the car sounds now, if I can't resolve the CEL I will try and get a replacement.
#120 |
I love peanut butter
Drives: 2013 SWP BRZ Limited
I'd definitely return it. I think they will fix their mistake, they responded to my inquiry quickly and even let me use a coupon code that expired.
If all else fails you could buy an o2 bung and have it welded to your header. It sucks, but if that is the only issue you have with the header then it may be an easy fix. As for the CEL, you will have it even with both o2 sensors. A tune can disable it though. |
#121 |
Drives: frs
#122 | |
Drives: 2015 BRZ Limited
2015 DGM BRZ/Gruppe-S UEL/Gruppe-S Overpipe/Invidia N1 Catback/AEM Strut/TEIN Street Basis/Cusco AOS |
#123 |
Just an update for future potential buyers. OFT stage 2 removed the CEL, so I had no reason to return the product (my preference). Virtually nothing was different with only 1 bung, aside from disconnecting the unneeded 02 sensor. As for my mounting experience, I chose to install, run it for 100 miles, then tighten up the bolts. No exhaust leaks or issues from my experience. One thing to note, installer has to use a swivel deep socket for 1 of the bolts, that resides in-between the driver side runners.
#124 | |
Not a troll
| The Following User Says Thank You to Cole For This Useful Post: | FRSBRZGT86FAN (03-17-2016) |
#125 |
In the A01C stage 2 ROM it was disabled by default. I'm surprised they would leave this enabled in any stage 2 ROM.
#126 |
I think my header is cracked or something. I started getting like a clicky and more airy of a sound when accelerating, slightly worse gas mileage and when I pop the hood I can smell exhaust. I'm going to remove the skid plate this weekend and take a better look to confirm.
I contacted semotors.com and they said they only warranty for 1 year. I have a friend who welds who said he will attempt to fix it. Have to reflash a stage 1 OFT rom too until this is resolved. Has anyone else had issues? |
| Tsudo Header and Overpipe | boredom.is.me | Engine, Exhaust, Transmission | 70 | 11-04-2014 01:14 AM |
| For sale: Tsudo UEL header | jupillam | Engine, Exhaust, Bolt-Ons | 10 | 07-08-2014 12:40 PM |
| Anyone have the Tsudo header? | Iam-Naimless | Engine, Exhaust, Transmission | 8 | 07-02-2014 01:55 PM |
| New Tsudo UEL header | Fast_Freddy | Engine, Exhaust, Transmission | 1 | 05-11-2014 01:33 AM |
| Tsudo Header | ML | Engine, Exhaust, Transmission | 7 | 01-11-2014 01:31 PM |
