Old 01-11-2016, 09:31 PM   #15
FRSBRZGT86FAN
FRSBRZGT86FAN's Avatar
Originally Posted by AKUSHOU View Post
After driving 20+ miles to work with an average speed of 60-65 mph and the light not going out I was scratching my head. But that same trip back home in the afternoon it went out sometime along the way.
So figuring it was temp related, but wanted to make sure with you fine folks
Originally Posted by PandaSPUR View Post
Yep, I think the approximation is like every 10 degrees = 1psi. Rough approximation.
Btw, related but slightly OT, does anyone know if the TPMS actually updates during the ride? Or does it only update on engine start? To me, it seems like it only checks pressure on engine start. I don't think I've ever had that light go out mid-drive.
Anyway, I just picked up a Vivair portable compressor that runs off the 12v accessory port and a digital tire gauge. Cost me $50 after tax from Amazon.
My 2015 nissan rogue with tech package fully loaded seems to have the whole temp thing figured out. In fact it won't even show each of the tire pressures till you've driven for some time and the tires get up to a preset temp, or if one of the sensors is reading an extremely low number. I feel like the TPMS system on these cars could use an update as a whole.
Old 01-11-2016, 09:37 PM   #16
They are updating constantly. Not much use having a low pressure sensor that only tells if there is a problem with the pressure at start up.
Old 01-11-2016, 09:41 PM   #17
So you could drive with an almost flat tire until it reaches a certain temp? Or if it is below a certain threshold it would still tell you it is low regardless of temperature? That sounds overly complex to me. Just let me know if low. I know if it is cold out and will make the call if it needs to be checked or not.
Old 01-11-2016, 09:43 PM   #18
jawn
jawn's Avatar
Drives: 2015 CWP BRZ Limited
My last car used the wheel speed sensors to figure out if one of the tires was flat. No TPMS needed on the wheel itself. I miss it.
jawn is offline   Reply With Quote
Old 01-11-2016, 10:14 PM   #19
mdm
not a twin owner
mdm's Avatar
Drives: 2016 Veloster Turbo DCT
I don't have TPMS but another version of my car has this speed-based pseudo-TPMS. In the manual, they are saying that in some cases such system may miss a low-pressure tire, like two tires on one side or on the same axle losing pressure. They go on to say that these cases account for ~50% of real-life low-tire-pressure situations. So it seems that true TPMS is better after all :-)
mdm is offline   Reply With Quote
Old 01-11-2016, 10:14 PM   #20
FRSBRZGT86FAN
No the tpms works normally, but when you switch to the infotainment screen which tells you exact pressures it won't show it, it shows a message like "Tire Pressures will appear while driving". One morning we had a flat when you started the car it would say Warning _____ side ____ tire leak detected and it also prevents the awd from being fully engaged when that occurs. So yes below a certain threshold it will warn you regardless, theres a lot of safety tech in that car.
Old 01-11-2016, 11:33 PM   #21
PandaSPUR
PandaPandaPandaPandaPanda
PandaSPUR's Avatar
Drives: 2015 BRZ Limited CWP
Makes sense. Coulda sworn I've had the light stay on until I park the car momentarily and then restart it. Guess I'm imagining it.
Anyway, will be inflating my tires some more once my pump and gauge get here tomorrow. wee.
Old 01-12-2016, 02:34 AM   #22
chaoskaze
The Fail Boat
chaoskaze's Avatar
Drives: CWP S.B.
isn't every -10 degree sorta = -1 psi?
Old 01-12-2016, 05:37 AM   #23
OK that makes sense. Still over complicated but makes sense.
Old 01-12-2016, 12:45 PM   #24
bcj
Geo Tyrebighter Esq
bcj's Avatar
Drives: '13 scion fr-s
The warning will come on if you get a hole in the tire while driving.
Got a .75" x 1.25" piece of metal strapping in a rear tire. Sucked.
Inspect your tires for foreign materials in the tread.
If you let your pressures drop close enough to the low margin, a high pressure weather system cruising through may trigger on the inside/outside differential pressure.
Man up and put some air in your tires. Running low isn't good for them.
Old 01-19-2016, 07:26 PM   #25
Dorb
Drives: 16 LM STI/13 LM BRZ/04 AVALANCHE
My BRZ has sat in the garage pretty much since winter snow hit, just fired it up and the tire light was on, just put air in as they were down to 27-29psi each tire. I was amazed. My Avalanche sits out all year and checking it tomorrow after work, can't wait to see how low it will be. - I just don't recall the BRZ losing that much the last couple of winters.
Dorb is offline   Reply With Quote
Old 01-19-2016, 08:17 PM   #26
BRZnut
Drives: BRZ DGM Limited
Mine does that each winter if I do not keep on top of it and triggers the low pressure light at around the same level as you.
Old 01-19-2016, 10:44 PM   #27
SmartedPanda
SmartedPanda's Avatar
Drives: SWP BRZ Limited Manual. 2014
Happens to mein California, 40F-ish and 1 tire loses 2-3 PSI.
[| Blox 490 Knob | Mishimoto Silicon Intake | K&N Filter | DD Always-On DRL | Tomei 60S | Weather Tech | RED USDM TOM's Tail Lights | OEM Underbody Panels | Intec High Mount Brake | RexSpeed Heated Wide Mirrors | TC105N 17x9 | Super Sport 245/40R17 |TRD Quickshifter | Porsche Brake Air Duct | TRD Sliding Armrest| OEM Knee Pads | MTEC Shifter Springs| WRX OEM Oil Cooler| Generic PVC Catch Can|]
SmartedPanda is offline   Reply With Quote
Old 01-20-2016, 11:54 AM   #28
thomasmryan
thomasmryan's Avatar
Drives: hyper blue
coming from motorcycles, I check the tire pressure every ride.
if your garage is 60 and its 20 outside, +4 psi.
thomasmryan is offline   Reply With Quote
best tire pressure gauge (tire pressure question) steveholt Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 19 03-21-2015 10:27 PM
tire pressure warning light kinda wonky? chickdigger802 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 18 10-27-2013 12:00 PM
tire pressure mrnibbs Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 1 10-18-2013 10:09 AM
what is your tire pressure? abling2 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 9 06-03-2013 10:49 AM
What Hot Tire Pressure? gbgracer Tracking / Autocross / HPDE / Drifting 24 05-14-2013 05:47 AM
