Old 01-08-2016, 09:21 AM   #1
Tech
Tech's Avatar
Drives: White MT GT86 with TRD extras
Boot (trunk) light tilt switch
On three occasions I have had the key fob in my pocket and when sitting or moving around, the boot (trunk) button has got pressed and I have not known about it.
The light comes on in the boot and if the car is not used for a couple of days, the battery goes flat.
To solve this problem I installed a tilt switch so if this happens now (and it has) the light won't come on unless you lift the boot lid at least 6"
Yay! No flat battery.
Uploading lots of text and photo's one by one to this forum is a pain, so I have attached a pdf of the DIY which was much easier to produce.
I have also replaced the bulb with an high brightness LED version, so it draws less current anyway. I recommend this to everyone even if you don't fit the tilt switch.
Boot Light Tilt Switch.pdf
Tech is offline   Reply With Quote
The Following User Says Thank You to Tech For This Useful Post:
LXXXV1 (01-08-2016)
Old 01-08-2016, 10:13 AM   #2
Nickosport
Drives: 2015 WRB BRZ Premium
I think its crazy that the light is not on a timer. My wife's Volvo will shut it off automatically after a few minutes. I haven't had your issue, but I could see it being a problem.
Another thing you could do is change that bulb to an LED. You'll have more light and less current draw to kill the battery. The clean white light is nice too.
2015 WRB BRZ - Nameless - Raceseng - Eibach - Whiteline - Cusco - Perrin
Nickosport is offline   Reply With Quote
Old 01-08-2016, 10:21 PM   #3
Tech
Tech's Avatar
Yep I have done that... as in the last sentence of my post
WTB/WTT wingless trunk/boot lid in lightning red C7P - JAPAN Futaba Want-To-Buy Requests 0 06-30-2015 12:48 PM
How to wire a fog light switch to Diode Dynamics fog light kit *SOLVED tiz22 Cosmetic Modification (Interior/Exterior/Lighting) 6 06-04-2014 02:16 AM
WTB: Trunk/boot Lid Any Color VirUzxZ Canada Classifieds 0 05-30-2014 02:49 PM
Auto-Hauss Dual Trunk Light Introuctory Price! Light Up The Rest Of Your Trunk! Auto-Hauss Interior Parts (Incl. Lighting) 10 03-11-2013 11:55 PM
[StreetFX] BRIGHT Boot/Trunk LED light upgrade & DIY step by step guide (GT and GTS) WTF Australia Classifieds 0 07-11-2012 12:27 PM
