go_a_way1, Sarlacc
Old 01-08-2016, 12:26 PM   #1
xsnapshot
Fast enough
Drives: 2013 Subaru BRZ AT
Hitting rev limiter with supercharger
I have a BRZ automatic with the JRSC and high boost pulley on E85.
When I floor it in D, I bounce off the rev limiter in 1st and 2nd before it has time to shift. I think it's just simply revving too fast. 3rd and onward seem ok.
Is there a way to program the transmission to shift sooner or am I SOL and have to use manual mode?
xsnapshot is offline   Reply With Quote
Old 01-08-2016, 12:28 PM   #2
cdq85
cdq85's Avatar
Drives: 2013 Raven FR-S
in before "should have bought manual".
to offer some help though, would keeping it in snow mode help? maybe keep you in 2nd gear when stopped and help alleviate some of the torque. idk other than that.
cdq85 is offline   Reply With Quote
The Following User Says Thank You to cdq85 For This Useful Post:
Dream20b (01-09-2016)
Old 01-08-2016, 12:29 PM   #3
Toyarzee
Shibby!
Toyarzee's Avatar
Drives: '14 White FR-S, '01 turbo mini taco
Are you just possibly breaking traction in the shorter gears before the load and speed warrants an AT upshift?
Toyarzee is offline   Reply With Quote
The Following User Says Thank You to Toyarzee For This Useful Post:
whataboutbob (01-11-2016)
Old 01-08-2016, 12:37 PM   #4
xsnapshot
Fast enough
Originally Posted by new2subaru View Post
Have you tried sport mode or shifting manually?
I don't think I've ever had my automatic in automatic.
Shifting manually is great. I can control it to shift whenever I want, and it's how I usually drive. I just thought it was strange that it didn't shift soon enough in D.
The Following User Says Thank You to xsnapshot For This Useful Post:
new2subaru (01-08-2016)
Old 01-08-2016, 12:39 PM   #5
Freeman
Freeman's Avatar
Drives: 2013 Ultramarine FR-S
I don't think anyone has cracked or maybe even bothered to crack the computer for the A/T yet. You might look into SSP and their offerings for the A/T.
Freeman is offline   Reply With Quote
Old 01-08-2016, 12:40 PM   #6
xsnapshot
Fast enough
I suppose that could be happening.
So you are saying that when it breaks traction it's essentially revving so fast it has an opportunity to hit the rev limiter before it has a chance to shift?
Old 01-08-2016, 12:43 PM   #7
go_a_way1
Not Bаnned Anymore
go_a_way1's Avatar
Drives: Heavily Modified FRS
^this lol. Some people forget I drive a auto I uses the "manual" mode so much.
Old 01-08-2016, 12:44 PM   #8
go_a_way1
Not Bаnned Anymore
go_a_way1's Avatar
This could be happening?
Old 01-08-2016, 12:51 PM   #9
Toyarzee
Shibby!
Toyarzee's Avatar
I've had it happen, though on a much much more powerful and squirrely muscle car.... but based on your mods and since you say you're flooring it, if on oem or equivalent tires, and possibly turning while applying the load, I suppose it's possible. Never owned an auto so I could be mistaken due to my lack of familiarity with this issue. Normally if I hit rev limiter, it's cause I'm too slow!
Is that a question or confirmation? Lol
Old 01-08-2016, 12:54 PM   #10
go_a_way1
Not Bаnned Anymore
go_a_way1's Avatar
Well I have had mine fail to shift NA and bounce off the limiter before (in the rain) so I can see that happening but I have not tested it further to my anwser is both ?
Old 01-08-2016, 12:59 PM   #11
justatroll
justatroll's Avatar
Drives: Full race 4cyl boxer
I would argue that adding the extra rotational inertia of the SC and then hitting the rev limiter frequently is bad.
You are almost certainly exceeding the max revs each time you do this due to the exrtra inertia of the SC.
justatroll is offline   Reply With Quote
Old 01-08-2016, 01:51 PM   #12
xsnapshot
Fast enough
I know hitting the rev limiter is bad. That's why I'm asking the question.
But that's also not how engine's work. If you have a rev limit set to 7400 RPM, and you cut ignition right at 7400 RPM, then there will be no energy in the engine to INCREASE the RPM. The rotational inertia of the system may keep the engine AT ~7400 RPM for slightly longer than without, but that's it.
Additionally the extra rotational inertia from the supercharger would actually impede the ability for a non-powered system to accelerate. Think of how long/extra energy it would take a 1,000 lb two foot diameter wheel to slow down compared to a 100 lb two foot diameter wheel.
Old 01-08-2016, 02:07 PM   #13
justatroll
justatroll's Avatar
I think you need to rethink your "physics".
If the ignition "Cuts" at 7400, the engine RPMs will continue to climb for a fraction of a second and exceed 7400. that is called inertia.
And the additional rotational inertia of the SC will help the engine to KEEP GOING and overshoot 7400. And since the SC has a belt and possibly internal gearing, the increase in inertia is magnified by the transfer ratio.
That is why it is harder to stop a dump truck on ice than it is to stop a VW beetle. - "Inertia".
Normally hitting the rev limiter is not bad.
Old 01-08-2016, 02:34 PM   #14
Alltezza
Alltezza's Avatar
Drives: WRB Limited BRZ
You know it's raining in our area
You might have wheel slip and your RPMs just jumped while you was drifting(;
Alltezza is offline   Reply With Quote
Where Do You Set Your Rev Limiter? Chad86 Scion FR-S / Toyota 86 GT86 General Forum 38 06-10-2014 04:48 AM
Wheel hitting tie rod? OakmanSmalls Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 6 07-16-2013 05:17 AM
BRZs hitting Tampa, FL! FLHC BRZ First-Gen (2012+) — General Topics 63 07-24-2012 10:20 PM
Rev limiter? feldy Scion FR-S / Toyota 86 GT86 General Forum 4 06-03-2012 10:47 PM
<3 my rev limiter NESW20 Other Vehicles & General Automotive Discussions 1 05-02-2010 11:05 PM
