Old 12-21-2015, 11:33 AM   #1625
mmmcambelsoup
mmmcambelsoup's Avatar
Drives: FR-S 10 series
265 square? Geeze, that's like the porter house of meaty tires lol
got tired of running stretched tires. Go big or go home?
IG: @Lucky_FatPat
10 series // TRD x Turbo Build:
http://www.ft86club.com/forums/showthread.php?t=79474
mmmcambelsoup is offline   Reply With Quote
The Following User Says Thank You to mmmcambelsoup For This Useful Post:
FR-Shred (01-07-2016)
Old 12-21-2015, 12:35 PM   #1626
Jayela
Drives: 2013 Nissan GT-R, 1985 Porsche 944
Originally Posted by BlaineWasHere View Post
Why not run square 255s? Your creating extra under steer for no reason.
I'm just testing that setup, if it won't work for me I'll know for future And i was running 225 and 245 previous set up on stock wheels and it worked quite well. Also if you're right I still might be able to compensate for it by adjusting the swaybars.
Jayela is offline   Reply With Quote
Old 12-21-2015, 03:55 PM   #1627
NyC Zn6
NyC Zn6's Avatar
Drives: 10 Series #974 6m/t
same here bro...hopefully i can change my setup in a couple weeks to something meaty.
Old 12-22-2015, 10:44 PM   #1628
VADERR
Completely Lost
VADERR's Avatar
Drives: 2015 CBS BRZ Limited
Meaty Tire Thread
255/40/17 on a 17x9 +42 needed a 5mm spacer in front
Stock springs
Size:  383.2 KBName:  ImageUploadedByTapatalk1450842291.572208.jpg
VADERR is offline   Reply With Quote
Old 12-25-2015, 07:33 PM   #1629
BlaineWasHere
Grip>Drift
BlaineWasHere's Avatar
Drives: FRS
Sway bars are the very last thing you should tune when trying to set-up a car. Trust me the car needs more front grip not rear grip.
Old 12-28-2015, 09:54 AM   #1630
koukiboss
Drives: 15' FRS
Been wanting to play in this thread for a while!
18x9.5 et38
265/35/18 Dunlop DZ102
koukiboss is offline   Reply With Quote
The Following 6 Users Say Thank You to koukiboss For This Useful Post:
funwheeldrive (01-22-2016), Hicklinc (02-25-2018), JoeHK (12-28-2015), mmmcambelsoup (01-08-2016), number1Tango (01-08-2016), slow15frs (01-21-2016)
Old 12-28-2015, 09:55 AM   #1631
JoeHK
JoeHK's Avatar
Drives: Raven Toyota GT86
h
18x9.5 et38
That looks spot on! Nicely done sir
Sent from my Potato using Tomato
Toyota Corolla E12 Hatchback (2005) - GONE
Toyobaru GT86 ハチロク - CURRENT
JoeHK is offline   Reply With Quote
Old 12-29-2015, 12:16 PM   #1632
ClintimusPrime
Tennis Pro
Drives: '13 DGM BRZ. '07 600RR
ST coils, 265/35/18 on 18x9.5 et38
This setup is GORGEOUS!!
Cool shot bro. Hit it again.
ClintimusPrime is offline   Reply With Quote
The Following 2 Users Say Thank You to ClintimusPrime For This Useful Post:
mmmcambelsoup (12-30-2015), pcporo (01-17-2016)
Old 12-29-2015, 01:22 PM   #1633
BDotG
BDotG's Avatar
Drives: Asphalt 2013 FR-S
Anyone got thoughts on running a 245/40/18 on an 18x8.75 wheel? There will defs be some meat to it, but any negatives this could cause? Understeer possibility? Love the meaty look just don't want to sacrifice drivability for it.
BDotG is offline   Reply With Quote
The Following User Says Thank You to BDotG For This Useful Post:
gMit (01-19-2016)
Old 01-07-2016, 05:40 PM   #1634
EdiVip
Drives: Mario
Does anybody put 255/30r19 on 8.5J? Now I have 245/30r19 but I want moar meat!
EdiVip is offline   Reply With Quote
Old 01-07-2016, 05:45 PM   #1635
MisterSheep
Killed Scion
MisterSheep's Avatar
Drives: 2013 FR-S Whiteout
I should be joining this thread shortly....
Instagram: trevor.parque
Old 01-07-2016, 06:35 PM   #1636
swarb
245/40's are slightly tall, so you might have problems with it depending on how low you are. Offsets matter. +35-40 you should be good.
Read the tire specs from the manufacturer. Every tire is made different. Not many people run 19's, but you should be ok if tire specs are reasonable. Offsets matter. Only real way to find out is go outside and check for clearances.
Old 01-07-2016, 10:36 PM   #1637
nzer
nzer's Avatar
Drives: 2012 Grey TRD GT86, 2015 VW Golf R
Should be fine @EdiVip. Have a look on the below link. These are the approved tire widths by our authorities for different wheels. They are conservative and if you scroll down to 19" you'll see it says the 255/30/19 are suitable for 8.5" to 9.5" wheels in the 19" size
http://www.lvvta.org.nz/documents/in...lity_Guide.pdf
These are guidelines for our country but as mentioned they are conservative as are the government approved combinations.
nzer is offline   Reply With Quote
Old 01-08-2016, 09:24 AM   #1638
mmmcambelsoup
@koukiboss are you using natural camber? I had to raise mine and roll fenders from what it was on 245/35/18 to avoid baconing fenders and rubbing.
IG: @Lucky_FatPat
Winter Tire Review Thread (Please contribute) pastuch Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 344 03-13-2024 05:49 PM
Wheel Directory: Forgestar F14 18x8.5 +38/18x9.5 +38 ScionFR-S Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 97 09-09-2015 06:32 PM
Meaty rubber on flush spoke rims? red_comet Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 16 06-14-2013 12:21 PM
Official wheel/tire fitment thread needed empower-auto Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 4 06-22-2012 01:40 AM
The Wheel and Tire Fitting Thread EvoFanatic Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 2 03-15-2012 03:05 PM
