Old 01-05-2016, 03:24 AM   #1
ItzBidge
ItzBidge's Avatar
New coilover ticking noise
About a week ago I purchased a set of Apexi N1 EXV coils. A friend and I installed them and after a few days of driving on them I've started to hear a clicking/ticking noise from the front left coilover. Does anyone know a potential fix for this issue? Thanks for your help.
ItzBidge is offline   Reply With Quote
Old 01-05-2016, 09:07 AM   #2
go_a_way1
Not Bаnned Anymore
go_a_way1's Avatar
Drives: Heavily Modified FRS
Is everything torqued to spec?
Did you set your preload correctly?
Did you use a screwdriver and hammer on the locking ring so it won't back off?
Old 01-05-2016, 11:13 AM   #3
Gear_One_Performance
Gear_One_Performance's Avatar
Drives: 2014 BRZ SCCA STU endurance car
The biggest culprit I've seen is the top lock nut for the strut to the camber plate working it's way loose, I tend to put some thread locker on there. Other than that jack the car up and double check the torque on everything in that area. It's still possible that it's something internal or binding but this soon after install it's more likely to be an oversight.
Gear_One_Performance is offline   Reply With Quote
Old 01-06-2016, 04:05 AM   #4
ItzBidge
ItzBidge's Avatar
@go_a_way1
I know everything isn't torqued to exact specs because i'm not sure the recommended specs. I didn't touch the preload before I put them in. I didn't use a screw driver and hammer on the locking ring I just used the coilover wrenches and tightened it to what i though was suitable.
@Gear_One_Performance
I'm not sure which top lock nut your speaking about. Are you talking about the one nut under the damping adjustment knob?
Sorry for my ignorance I just a bit confused and new to this. Here is a link to the coils I purchased. LINK
Old 01-06-2016, 10:57 AM   #5
That one, excuse the crude MS paint there but yeah I've seen those loosen up on rare occasions.
Old 01-06-2016, 08:43 PM   #6
ItzBidge
ItzBidge's Avatar
I checked that nut and it wasn't loose. I checked the locking collar and it was also fine.
Old 01-06-2016, 09:01 PM   #7
Cole
Not a troll
Cole's Avatar
When does it happen? All the time? Low speed? High speed? Turning? Going forwards? Backwards? Both?
Are the 3 nuts all tight enough up on top? What about the 2 bottom bolts? What about your end links, good and tight? Set to the proper length?
Video would help too if it's possible.
Cole is offline   Reply With Quote
Old 01-06-2016, 09:18 PM   #8
go_a_way1
Not Bаnned Anymore
go_a_way1's Avatar
@go_a_way1
Sorry for a later response the usual, I didn't get the mention. It could be the preload was not enough from the factory I am not sure if all companies pre set it. Do you get any binding or poping sounds when you turn to full lock and your not moving? Also this probably wont help but it might be worth tightening anything you can while the suspension is loaded i.e. on the ground not jacks. Hammer and screwdriver is just a precaution as it is not unusual for locking rings to back off over use.
And like cole said any more details might help us help you a little more
Old 01-07-2016, 02:51 AM   #9
ItzBidge
ItzBidge's Avatar
The clicking sound is at an speed over 10 mph/16 kph and is usually when i go over small bumps in the road. The clicking sound happens a lot maybe 15 times a minute. I double check the tightness of all the bolts and they are very tight. The only thing i'm not sure about is the sway bar end links. Before I put them in i made sure they were the same or almost exact same length. Ill try to get a video if possible.
Old 01-07-2016, 04:02 AM   #10
swarb
Check the sway bar endlinks. Mine have come loose on two occasions. My other guess is the spring seat and height adjustment collars being loose or not enough preload.
Old 01-07-2016, 04:05 AM   #11
ItzBidge
ItzBidge's Avatar
Ill check the endlinks. Is it possible there too short or too long on both sides?
Old 01-07-2016, 04:16 AM   #12
swarb
Anything is possible. They are supposed to be bolted on when car is on the ground. But you don't have much choice if they aren't adjustable. Many coilover kits come with non-adjustable front end links, and none for the rear, so it is likely that they are not the ideal length.
It is probably the endlinks causing your problem. They are hard to get to, and the hard to torque down then compared to everything else.
Old 01-07-2016, 07:14 AM   #13
vroom4
Get a torque wrench. I'm not sure how you can tell if things are tight without one?
vroom4 is offline   Reply With Quote
The Following User Says Thank You to vroom4 For This Useful Post:
go_a_way1 (01-07-2016)
Old 01-07-2016, 01:12 PM   #14
ItzBidge
ItzBidge's Avatar
I'm not even sure how I would bolt the end links on when the car is on the ground. Also I have a torque wrench I just don't know all the torque specs for everything.
Clicking/Ticking Noise From Front Wheel immaculate Issues | Warranty | Recalls / TSB 8 05-18-2018 10:56 AM
Clicking / Ticking Rear Noise shellslinger Issues | Warranty | Recalls / TSB 19 07-20-2017 10:40 PM
Ticking/Clicking noise when accelerating? Pineapple Issues | Warranty | Recalls / TSB 3 08-28-2014 04:29 PM
Stuttering/ticking noise while car is parked? jermyzy Issues | Warranty | Recalls / TSB 4 03-02-2014 08:35 PM
ticking noise? iHeartmyFR-S Issues | Warranty | Recalls / TSB 13 04-18-2013 06:42 PM
