Old 01-06-2016, 08:29 AM   #1
chris86
Drives: 2013 Dark Gray BRZ
MT Stick does not return to center neutral on its own
Hi guys,
I've noticed past two weeks or so, that the stick is really slow to return to center when I take it out of gear. To the point where out of 5th/6th is like "stuck" for a second or two before it ends up close to center again, and coming out of Reverse it won't return unless I force it to.
I can still drive it fine, I just have to move the stick around myself, which seems really odd.
Curious if anyone has had anything similar or heard of anything like this.
Thanks
chris86 is offline   Reply With Quote
Old 01-06-2016, 08:42 AM   #2
If it is cold there the grease could just be thickened a bit. Could also be the return spring has broke or stuck. Both of these would be a pretty easy fix I would think.
humfrz (01-06-2016)
Old 01-06-2016, 02:25 PM   #3
Sony
Sony's Avatar
Drives: 2013 Subaru BRZ MT Limited
I would bet you have a broken return spring. Sounds like it's time to upgrade to some MTec springs.
http://www.ft86speedfactory.com/mtec...l#.Vo1qOvkrKUk
Dark Blue 2020 Subaru Forester Sport, Name: Apollo - God of Music
WRB 2013 Subaru BRZ Limited MT, Name: Zeus - Father of all God's and God of Sky and Thunder
Perrin Cat-Back, ECUTek Tune by Kaizen Tuning, Perrin Silicone Radiator Hoses, Perrin Master Cylinder Brace, Perrin True Cold Air Intake
Sony is offline   Reply With Quote
The Following 2 Users Say Thank You to Sony For This Useful Post:
humfrz (01-06-2016), Tcoat (01-06-2016)
Old 01-06-2016, 03:04 PM   #4
Does it still "stick" after the transmission is warmed up ....... ??
Old 01-06-2016, 05:54 PM   #5
chris86
Thanks for the responses.
So, after reading these and having mentioned it to my more car-savvy boss, I am a smidgen more knowledge, and it does seem possible that something is up with the return springs. It's worth noting that it would be BOTH springs, because both right and left sides do it.
It feels like the springs are gunked up to me when I play with it.
I was reading about these today at lunch, and I am interested, but I'm nervous about the stories of ruining the passenger side bolt/threads. Plus it's winter and I don't have a garage.
I'm thinking I'll try and get the dealer to look at it.
Oh, and
yes, I had that same thought. I thought maybe it was just too cold or something, but even after 5 minute warm up in the driveway and a 15 minute drive, it still does it.
Old 01-06-2016, 06:11 PM   #6
It isn't warming up at all in the driveway and even a 15 minute drive may not be enough if really cold. It is possible that it is still just cold related. The fact that it is both ways is sort of telling since the likely hood of both springs getting broken is probably pretty remote (not impossible but it would be weird if they were).
Old 01-06-2016, 06:16 PM   #7
chris86
Okay.
Agreed
manual, manual transmission, stick
My idea for a center arm rest / console cover / center cup holder ravenblackfrs Cosmetic Modification (Interior/Exterior/Lighting) 67 02-13-2016 03:00 PM
Rattling Sound In Neutral tekFRS234 Issues | Warranty | Recalls / TSB 5 07-16-2015 10:23 AM
Neutral to 1st clunking sound wallace03 Issues | Warranty | Recalls / TSB 3 01-10-2013 09:50 PM
Car rattle at neutral. IloveBaldEagles Issues | Warranty | Recalls / TSB 3 12-23-2012 06:55 PM
Weird rattle when put into neutral SleekMachine Issues | Warranty | Recalls / TSB 1 10-18-2012 10:25 AM
