Old 01-06-2016, 04:31 PM   #29
Astroboy
Astroboy's Avatar
Drives: None
Originally Posted by Kiske View Post
nope that is grinding, lw flywheel chatter mostly sounds like something lightly rattling.
What could cause it to grind? I did everything correctly and torqued everything up to spec..... I'm mad.
Sent from my LG-D850 using Tapatalk
Astroboy is offline   Reply With Quote
Old 01-06-2016, 08:12 PM   #30
Kiske
Kiske's Avatar
Drives: RX-7 / BRZ
Dry pilot bearing, inproper install, glazing, tob incorrect install, bent fork, insufficient pressure plate.
When it is grinding can you feel it though the clutch pedal?
When dose it happen? Coasting? Accel, Decel? Idle
The Following User Says Thank You to Kiske For This Useful Post:
Astroboy (01-06-2016)
Old 01-06-2016, 08:49 PM   #31
Astroboy
Astroboy's Avatar
Drives: None
Only when I decelerate in gear. Don't hear it during idle. Don't hear anything during idle. Hear it when accelerating in fourth on low rpms tho. I don't feel the grinding.
Old 01-07-2016, 11:55 PM   #32
weederr33
Airborne at your service
weederr33's Avatar
Drives: '17 BRZ Series.Yellow
Have you had a chance to see if it was grinding?
MS, CSCS, TSAC-F, CPT
Old 01-08-2016, 01:17 AM   #33
Astroboy
Astroboy's Avatar
Drives: None
Suppose to meet up with someone who is more informed on these clutch tomorrow. Hopefully it's nothing major. I can take out the transmission again, I just don't want to go through the hassle again
Old 01-09-2016, 11:20 PM   #34
Astroboy
Astroboy's Avatar
Drives: None
A good source told me it was the springs on the clutch disc Because the noise stops when I pop it in neutral, or press on the clutch pedal
The Following User Says Thank You to Astroboy For This Useful Post:
weederr33 (01-10-2016)
Old 01-10-2016, 02:08 AM   #35
weederr33
weederr33's Avatar
So do you need to replace the clutch or just grease them up? And at least it's not grinding or out of wack.
Old 01-10-2016, 11:01 AM   #36
Astroboy
Astroboy's Avatar
Drives: None
I was told that exedy clutch disks were notorious for this. He told me that if I were to remove the trans again to see what was up with the noise, all I would have to do is shake those springs to confirm that it is the springs.
Old 01-10-2016, 11:03 AM   #37
weederr33
weederr33's Avatar
Hopefully it will be an easy fix
Old 01-10-2016, 11:07 AM   #38
Astroboy
Astroboy's Avatar
Drives: None
It's normal. The only way to fix it is to get a better clutch kit. Oh well
Old 01-10-2016, 07:38 PM   #39
weederr33
weederr33's Avatar
Well shit...
Old 07-18-2016, 12:42 PM   #40
Pneub
Drives: Dark Grey BRZ
I just had this clutch fail on me after 30k miles. This is after my ACT clutch failed almost immediately. Not sure what the issue is with this car.
Edit: I had the Exedy stage 1 fail one me
Pneub is offline   Reply With Quote
Old 07-19-2016, 09:41 PM   #41
weederr33
weederr33's Avatar
I thought you had the stage 1 fail on you?
The Following User Says Thank You to weederr33 For This Useful Post:
Astroboy (07-19-2016)
Old 07-19-2016, 10:47 PM   #42
Pneub
My bad. I meant to include that part. Corrected: Stage 1 failed on me after 30k
Exedy Clutch KAR Engine, Exhaust, Transmission 28 01-03-2016 07:27 PM
exedy clutch questions ft86me Engine, Exhaust, Transmission 8 02-13-2014 09:58 PM
Exedy super twin clutch boostedfrs Transmission and Driveline 0 01-31-2014 12:48 PM
Exedy stage 1 clutch/flyweel - Flywheel weight? wparsons Engine, Exhaust, Transmission 5 01-03-2014 11:58 AM
NEW PRODUCT EXEDY HYPER TWIN CLUTCH! D2BD Motorwerks Transmission and Driveline 4 05-15-2013 03:09 PM
