#421 | |
Drives: 2013 Firestorm FR-S
![]() Yeah, I knew when I got the 17x8s I'd have a tough time competing against cars with 17x9s and better prep than me. Especially since I don't have a header and tune yet, although I might end up with those part way through the season. In Chicago Region I might be alright, as consistent STX participation is rather slim. I have a chance to place just by showing up to all the events and driving decently enough. But running somewhere like Milwaukee Region I will have a very tough time, as there are some well-prepped STX cars being driven by very talented folks.
"Shark_Bait88, the man who’s spent the most money modding his stock FR-S and it’s still stock." -@jdnguyen
#422 | |
![]() I got sick of changing tires and being the last person to leave the parking lot at our events and I was really excited about the new street tire rules last year. I think I'm going to go ahead and do either RE71Rs or Rivals - would the 'stones heat cycle out faster? My RS3s totally fell flat right before they corded.
#423 | |
Drives: Toyobaru FRZ
Mine is primarily an autocross car as I have another DD. I leave the RE71Rs on the car and drive to and from events on them. I don't DD it, so I don't worry about the heat cycles. I think that is OK. I wouldn't waste them driving back and forth to work though. |
#424 | |
Drives: 2015 Scion frz
I will be running the stock primacy's for the first few track days to see what I can could do with em. I would like to get a better set of tires for the stock wheel setup for the summer tho. I had my eyes set on 3 tires in the 215/45/17 size: Hankook RS3 v2 Bridgestone RE71R Advan AD08R Originally I was planning to DD the new rubber but I could just get another set of stockers to DD with like mentioned above. I'll only be do open lapping sessions and nothing competitive this season. I do want the best tire I could get regardless tho. For longer stints of course
#425 |
Drives: Honda POS
Hey Icybrzzz,
It sounds to me like you are relatively new to the HPDE game. So if that is the case, I completely agree with you in just trying things out with the stock Primacy tires. As bad as people seem to claim they are, I actually found the stockers to be quite acceptable in the dry even for HPDE use. You just have to be aware of their limits and drive them within what they are capable of doing. With the way the loonie has been tanking, I'd actually recommend you to go for the RE-71R. For some reason, Costco (Canada) has been selling them for dirt cheap prices at the moment -- they are Cdn$146.99/tire, and you just can't get that anywhere at all. They are literally a screaming bargain. I suspect Costco will eventually smarten up and adjust the price so that it is more inline with our loonie-dollar exchange rate. But until they do, I wouldn't bother considering the other tires. As an additional suggestion -- is your car modded at all? If it isn't, I'd wholeheartedly recommend you to pick up some camber bolts and get an alignment done to max out your front (negative) camber. The cost of the camber bolts would more than pay for itself when you aren't killing the tires' outer shoulders at the track. |
#426 |
Drives: '22 BRZ
RE71R is not a tire that will be ideal over long stints. There are people using them in Chumpcar with success, but generally only on cars that are VERY over tired.
I'll be using RE71Rs this year and DDing them and doing at least a couple of track events on them. I'm budgeting for a mid-season replacement though, or maybe just using the Primacies on track events. I drove my GTI a lot of miles this summer on RE71Rs with no noticeable drop off in performance. That said I only got ~25 autocross runs on them spread out over 5 months because the car kept breaking... I've done two track days (2 hours of track time each day) with essentially no abnormal wear from the Primacies. I did more damage to them autocrossing and I wasn't taking it easy on track. They're no actually that bad considering what they're designed for. |
#427 |
If you want a 'good but not great' at everything tire, I would probably do something like a Z2 Star Spec or RS3. Good enough for street, autocross, and track, but not particularly great at any of them. The RE71Rs are perfect for autocross but I think just too sticky for a street tire and will overheat too quickly as a track tire.
If you have the budget for another set of wheels, I would get something like the Nitto NT01 for the track. They are good enough to drive to and from the track, just put em on before the track day. Once the event is over, swap back to your DD tires. |
| The Following User Says Thank You to Jawnathin For This Useful Post: | strat61caster (01-05-2016) |
#428 | |
In terms of mods, mostly bolt ons: JDL UEL header Grimmspeed CAI OFT with stage 2 UEL map Nameless 2.5" track pipe (axleback) Regarding the camber bolts, yes I'll be picking up a set of those as well with possibly the SPC rear LCA to get my alignment in check before I hit the track. I'm more just doing research now so that when I am ready to upgrade I have something in mind. I do want to track the Primacy's just because from the street driving I've done this past summer, they seem like a pretty good tire. It also seems like EVERYONE has been telling me to burn through the primacy's first to learn the car and THEN upgrade to something better Thanks for the quick responses guys ![]() EDIT* Just checked the costco website and they indeed are going for $147/tire! At that price you guys think I should try these out? That is hands down the cheapest quote I got on any of the tires I'm interested in. |
#429 |
Drives: '13 FRS - STX
Fwiw my next DD/HPDE tire will likely be RS3, was really happy with the z2ss as an all rounder and only a few HPDE groups hand out trophies, I'd rather a tire I can beat on all day than something I have to manage and optimize, those days are for fun and seat time over setting a track record imo.
Maybe I'll try the 71rs at a track day but I think that will come near the end of their life someone next year, they may not be of interest to anyone anymore by then, tire tech is a fickle thing. Last edited by strat61caster; 01-06-2016 at 01:09 AM. Reason: there they're their |
#430 | |
The Stig's German cousin
It's obviously up to you to do what you want but you're going to have a very similar experience as with your RS3s if your new tires do double duty, except this new gen of tires is much more expensive and doesn't last as long. I buy tires so I can win events, not to hit 1.2g turning into the grocery store.
#431 | ||
APEXHNTR
Drives: 10 Series FR-S #1867
Thanks for the detailed responses, I'm definitely not gonna be happy with bottom 2/3 of the pack, as I spent the last two years there getting used to the car and getting everything dialed in. Last two local events I finished 8th and then 3rd at the season closer so I definitely want to build upon that. I'm not quite ready for Nats but I'd like to play at one or two Pro Solo events this year and see how I stack up against real STX cars and drivers. Maybe a second set of wheels is the way to go...
2013 Sc10n FR-S 10 Series #1867 of 2500 in the garage...2001 Toyota 4Runner [Solid Axle Rock Toy], 1987 Pontiac Fiero GT [Shitwagon], 2004 Honda Interceptor VFR800 [daily rider], 1978 Suzuki GS750 [Café Racer] |
#433 |
Don't get me wrong, I think you can DD on the RE71R's, I just think they'll be toast by the end of the season and if you're real close with someone on fresh tires while you're DD'ing and they're using a second set they'll start to pull away from you mid season (unless you're improving your skills to compensate and they're stagnant, but that's unlikely) and the last few months will be sketchy in the wintertime.
Shit, I'm a teetotaler... |
#434 | |
APEXHNTR
I guess I'll give the DD/AutoX thing a try with RE-71r. This summer was nice so I put 6500 miles on the bike as my daily, here's hoping for more of the same this year...
| Areddi's Autocross Video Thread | Areddi | Mid-Atlantic | 130 | 05-17-2015 06:19 PM |
| Anyone DD 200 Treadwear Tires? | CraftyObeseCrunchyKitty | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 14 | 01-09-2015 11:44 AM |
| Tire PSI for completely stock autocross? | bladesamurai | Tracking / Autocross / HPDE / Drifting | 16 | 06-11-2013 10:07 AM |
| Autocross Tire Pressure on ZII's | Areddi | Tracking / Autocross / HPDE / Drifting | 6 | 04-12-2013 08:37 PM |
| KW V3 autocross set-up thread | -max- | Tracking / Autocross / HPDE / Drifting | 97 | 10-18-2012 08:02 PM |
