Old 01-04-2016, 08:12 AM   #57
ChrisD
ChrisD's Avatar
Drives: GT86
Originally Posted by #maverick# View Post
Yea I was mobile and I didn't look at the dates. Honestly, I think you should get a bigger turbo. You will make more power with less boost at the expense of a little lag.
Well at least the CR is now a bit lower than it was and the new rods can handle more torque, so if I want to throw a bigger turbo on it in the future then the engine is ready for it anyway.
To be honest though I don't really want lots of lag then huge power spike when the boost kicks in - I'd rather have less lag and a bit less power. This is a car for fast road driving and doing occasional drift days in, not a dyno queen, so I couldn't really care less what the peak power output is. I just want it to be fast and fun to drive
My GT86 build so far:
AVO Stage 4 Turbo, Carrillo forged con rods, 10:1 CR Carrillo pistons, AVO 3 inch turbo back exhaust, Helix clutch, TheDriveShaftShop drive shafts, lightweight flywheel, NamelessPerformance hydraulic hand brake, KW V3 coilovers... and lots of other little bits
ChrisD is offline   Reply With Quote
Old 01-04-2016, 08:13 AM   #58
ChrisD
ChrisD's Avatar
Drives: GT86
Be careful with this; this comes at a very, VERY high thermal cost.
Can you elaborate?
Old 01-04-2016, 08:15 AM   #59
ChrisD
ChrisD's Avatar
Drives: GT86
Originally Posted by killboy View Post
FWIW we have almost this exact same setup on our BRZ...AVO stage 3, billet wheel, race intercooler, forged internals, lower compression pistons, upgraded fuel injectors/pump, 93 octane. (no E85 around here)
Your original post asked about max boost and where it comes on, so to answer, ours is set to 14.9lbs and gets there at about 3300rpm, tapers a couple of psi near 6000 on. We make about 380whp on this one. We don't have upgraded springs though, (should have done that while in there but forgot) and I forget the CR of the pistons...try to get back with you on that. We have a built, supercharged FRS also and I get them confused.
Thanks for the info, that's nice to know how someone else is getting on with a very similar setup. I'd be interested to know what CR you're actually running if you could find out.
Old 01-04-2016, 12:29 PM   #60
killboy
killboy's Avatar
Drives: 1FRS, 1 BRZ, 2S2000s, Evo8, Dak.R/T
10:1
killboy is offline   Reply With Quote
The Following User Says Thank You to killboy For This Useful Post:
ChrisD (01-04-2016)
Old 01-04-2016, 01:36 PM   #61
ChrisD
ChrisD's Avatar
Drives: GT86
10:1
Cheers. Exactly the same setup as me then. At least I know roughly what to expect now then. How have you found it to drive? Happy with it? Any issues?
Old 01-04-2016, 02:19 PM   #62
CSG Mike
CSG Mike's Avatar
Can you elaborate?
Pulling timing to reduce output, enough to function as a traction control, involves a very, very high EGT. Doing it more than momentarily (e.g. being dependent on the traction control), will result in skyrocketing temps across the board; a minor amount of that combustion heat is conducted into the engine, but it adds up quickly.
I see cats blow out all the time on the 458 cuz that's part of how the car's traction control functions, and the bursts of heat just destroy the cats. Then again there's nothing wrong with a catless 458 (except being deafeningly loud).
ChrisD (01-05-2016), lamawithonel (01-04-2016)
Old 01-04-2016, 04:48 PM   #63
#maverick#
#maverick#'s Avatar
Drives: 2006 Pontiac GP (SOLD), 2014 FR-S
I can respect that. I have a 5858 on my car and I hit 18 lbs at about 3900 rpm stock motor though and make close to 500 hp
"Project cars are like New Years Eve. Endless preparation, hype, a sleepless night of fun, followed promptly by massive headaches and regret." - Anonymous
#maverick# is offline   Reply With Quote
The Following User Says Thank You to #maverick# For This Useful Post:
ChrisD (01-05-2016)
Old 01-04-2016, 04:50 PM   #64
#maverick#
#maverick#'s Avatar
I have been looking into the Hyperaktive boost controller which adjusts boost based on wheel spin. Seems pretty neat.
Old 01-04-2016, 08:00 PM   #65
killboy
killboy's Avatar
Stupid fun...thing is so stinkin' fast it's ridiculous. Running 265s and it will spin them up in 1st and 2nd on dry, 3rd and sometimes 4th in the wet. (careful, but it's so fun) I was going 60mph on the highway in the wet and gave it some juice to change lanes and it just did this sweet little power-over slide/drift into the next lane.
Only issue we are having is what appears to be a slow/sticking internal wastegate valve. After beating on it for a few miles, I start to get very slow boost response...takes several seconds to build up peak boost, as opposed to the normal instant response once above 3k rpm. Started happening about a month after install, and had the kit for about 2 months now.
Turbo is coming out next week for inspection, and we'll decide how to proceed from there, but I have been leaning toward going to external wastegate setup anyway, so I'm pretty sure we're going to do that either way.
ChrisD (01-05-2016)
Old 01-04-2016, 09:10 PM   #66
FRS Justin
Drives: 2013 Asphalt FRS
AMS 2000 is rock solid
Instagram FT86PROJECT9S
Facebook FT86PROJECT9S
710whp
FRS Justin is offline   Reply With Quote
The Following User Says Thank You to FRS Justin For This Useful Post:
#maverick# (01-05-2016)
Old 01-05-2016, 03:09 AM   #67
#maverick#
#maverick#'s Avatar
Yea another rock solid boost controller. Both of these are for people who know what they are doing and want the most out of their car!
FRS Justin (01-05-2016)
Old 01-05-2016, 06:16 AM   #68
ChrisD
ChrisD's Avatar
Drives: GT86
is that on E85 or normal unleaded?
Old 01-05-2016, 06:20 AM   #69
ChrisD
ChrisD's Avatar
Drives: GT86
What's making you want to go external wastegate (if you weren't having the problems with the AVO one) ? Funnily enough I did have an issue with the wastegate on my AVO turbo too... hasn't quite been resolved yet so I'm not sure exactly what the problem is.
Old 01-05-2016, 07:25 AM   #70
Matt@Cosworth
Drives: blue - Cosworth SC stage 3.0
I'd say you're going to struggle to flow enough through an integral wastegate for anything over 400Bhp on a single turbo
obviously this depends on what level you're happy the 'base' boost level is at
if you can't get any less than 0.5 bar of boost then some people like that
Matt@Cosworth is offline   Reply With Quote
The Following 2 Users Say Thank You to Matt@Cosworth For This Useful Post:
ChrisD (01-06-2016), killboy (01-05-2016)
VIDEO GUIDE - Installing Boost/Vaccuum/Oil Pressure/AFR Gauges The Sentinel DIY (Do-It-Yourself) Guides 3 04-25-2016 04:43 PM
WV: 04 STI Low miles Built 400+ AWHP 33K on chassis 1500 on engine $25K dakjones Cars for Sale/Trade 6 09-03-2014 08:05 PM
Anyone has Stroked and Built FA Engine yet ? Whitigir Engine, Exhaust, Transmission 11 03-14-2014 05:31 PM
Boost Pressure Leak Tester whitefrs Forced Induction 32 02-18-2014 02:51 PM
What is the best turbo for a fully built engine scion frs SUB-ZERO Forced Induction 41 09-18-2013 06:41 PM
