Old 12-30-2015, 01:50 PM   #43
babydriver
Hit the road and I'm gone
babydriver's Avatar
Originally Posted by mav1178 View Post
That's part of your problem. You are using 1/2" drive on something that is only a 14mm bolt.
List price is $120. Much easier to just put on a new one than to take off, clean, fix, and reassemble... especially if the mechanic guarantees their work.
http://parts.subaru.com/a/Subaru_201...10-031-01.html
Just be careful not to overtorque the oil pan bolts and break off the bolt!
Slip, slidin' away.
Old 12-30-2015, 05:31 PM   #44
Packofcrows
hey you, yeah you <3
Packofcrows's Avatar
Drives: 2014 37J FR-S
Get a craftsman!
Old 12-30-2015, 05:43 PM   #45
RobertPaulson
Hisnamewasrobertpaulson
RobertPaulson's Avatar
Drives: 2017 Golf R
to the OP, I suggest you invest in a fumoto quik valve to replace your drain plug during your next oil change.
you will thank me
[ame="http://www.amazon.com/Fumoto-F-106-Engine-Drain-Valve/dp/B003OXUPOQ/ref=sr_1_9?s=automotive&ie=UTF8&qid=1451515247&sr= 1-9&keywords=fumoto+quick"]Amazon.com: Fumoto F-106 Engine Oil Drain Valve: Automotive[/ame]
This is your life and it's ending one minute at a time.
RobertPaulson is offline   Reply With Quote
The Following 2 Users Say Thank You to RobertPaulson For This Useful Post:
kthxbai (12-30-2015), Ultramaroon (12-30-2015)
Old 12-30-2015, 11:38 PM   #46
KoolBRZ
KoolBRZ's Avatar
Drives: Silver 2013 BRZ Ltd Auto 45,000 mi
you will thank me
Do it. I did. No more leaks or fear of stripping bolts.
If I say yes, will that make you think I understand?
KoolBRZ is offline   Reply With Quote
The Following User Says Thank You to KoolBRZ For This Useful Post:
RobertPaulson (12-31-2015)
Old 12-30-2015, 11:52 PM   #47
you will thank me
Finally bit the bullet. Your link made it too easy.
Old 12-31-2015, 01:12 AM   #48
........and @Ultramaroon screams into the 21st Century ......
Old 12-31-2015, 01:28 AM   #49
humfrz (12-31-2015)
Old 12-31-2015, 03:18 PM   #50
RobertPaulson
Drives: 2017 Golf R
about time man, the best "mod" I installed on my car.
The Following User Says Thank You to RobertPaulson For This Useful Post:
Ultramaroon (12-31-2015)
Old 12-31-2015, 03:26 PM   #51
Ashikabi
Ashikabi's Avatar
That fumoto valve it's so RICE. Why would any one need to drain their oil without tools. Damn honda ricer scrubs ricing up and down the street. Makes me sick. You'd think it was a rice factory or something
The Following User Says Thank You to Ashikabi For This Useful Post:
sroby (05-30-2020)
Old 12-31-2015, 03:45 PM   #52
ayau
Drives: Some rust bucket
Practice getting a feel for the torque wrench with the lug nuts. Most lug nuts will be in the 70-90 ft lbs range, and most bolts won't require more than that. If you feel like you're putting more force than tightening a lug nut, then you're probably overdoing it.
Also, bolt sizes will give you a hint on the torque specs. A typical 10mm bolt will require a lot less torque than a 17mm bolt. This may or may not be intuitive.
On the other hand, you can never have enough torque when loosening bolts, especially rusty/seized ones. So feel free to go crazy when loosening bolts, lol.
Old 12-31-2015, 03:59 PM   #53
Not gonna lie. I'm cheap & lazy.
Old 12-31-2015, 04:48 PM   #54
babydriver
babydriver's Avatar
A seized or especially a rusted bolt is a big problem. It is all too easy to just snap it off. Always use a penetrating oil (B'laster is one of the best) to loosen the bolt first. If it does break off, you may have to drill it out to remove it. Not fun.
If it is taking too much effort to break loose a bolt that is ordinarily torqued at about (say) 40 lb/ft, then STOP and try the penetrating spray before going any further.
Slip, slidin' away.
Old 12-31-2015, 04:54 PM   #55
Ashikabi
Ashikabi's Avatar
Impact wrench
Old 12-31-2015, 05:56 PM   #56
Impact wrench
You're joking, right?
damage, oil change
FR-Sandwhich: Total or not total? Joshwahhhs Scion FR-S / Toyota 86 GT86 General Forum 51 10-03-2015 08:11 PM
Looking for a set of OEM BRZ DRL Strips s0sl0w Cosmetic Modification (Interior/Exterior/Lighting) 7 04-13-2015 09:18 PM
What headlights to pair with LED strips? l0aded Cosmetic Modification (Interior/Exterior/Lighting) 4 06-24-2014 04:37 PM
Rubber Strips on the top of the car zackcp04 Scion FR-S / Toyota 86 GT86 General Forum 3 05-31-2014 10:44 PM
RGB LED strips help BadLuckZN6 Cosmetic Modification (Interior/Exterior/Lighting) 1 01-21-2014 01:21 PM
