Old 06-08-2012, 09:55 PM   #15
blalor
Drives: WRB BRZ Limited 6MT
Sounds about right. You're surprised or something?
Yes. I think that sounds expensive.
blalor is offline
Old 06-08-2012, 11:11 PM   #16
Vracer111
Vracer111's Avatar
Drives: '13 Nissan Frontier (4.0L 6spd 2WD)
Originally Posted by blalor View Post
It does work, but the manual's wrong. I think the manual says the ignition needs to be in ON, but in fact you need to be in ACC. Possibly even off.
You don't even need the key in the ignition - just unlock and open the door then press the ODO button. Dash and gauges will light up. Cycle through until G-OFF / G-ON come up then put it either on or off as you wish.
As for a physical paper manual, can't wait till one is available - have always bought the factory service manual for my vehicles.
Vracer111 is offline
Old 06-08-2012, 11:52 PM   #17
MannyO
Night Owl
MannyO's Avatar
Drives: 2013 Subaru BRZ
Just want to touch upon the above and add that when you cycle through the menu, you get to "G-OFF" as the default setting. You have to press and hold ODO until it turns to "G-ON".
+1 ... as long as it's not a crazy amount of money.
MannyO is offline
Old 06-09-2012, 01:10 AM   #18
OrbitalEllipses
Drives: Attitude
Can afford 28K car, can't afford $200 manual? They've always cost that much. It's a BIG printed book.
OrbitalEllipses is offline
Old 06-09-2012, 01:29 AM   #19
dsgerbc
Drives: BRZ(sold), STI
What's the purpose of a paper-copy for a lot of dough? The PDF manual for my spec.b is on my home-server and I can access it from my tablet whenever I need it. And if I expect to need it - I have directly on my tablet.
dsgerbc is offline
Old 06-09-2012, 03:41 AM   #20
OrbitalEllipses
Drives: Attitude
The part where I said I don't have space in my man cave, er garage, and don't have a tablet either.
Old 06-09-2012, 08:51 AM   #21
cmspooner
cmspooner's Avatar
Drives: 2013 SWP Limited BRZ - Manual
I fought with this yesterday. To set the Rev Beep/light the car needs to be in Accessory mode, then you press the Disp button and the extra options will show up. To set the Gear indicator and Tach sweep you need to have the car off and then press the ODO/Trip button a few times to cycle through the extra options.
The Gear indicator is not as nice as I hoped, as it only shows the gear once the clutch is fully engaged. This is good if you are on a long stretch of road and somehow forget what gear you are in. I had hoped that it would show what gate you were in before releasing the clutch to help prevent skipped gears due to unfamiliarity with the gearbox. It does show the shift up/down indicator though which is nice, as the car likes to be in a higher gear than I thought it would.
Still getting used to my first stick, but I love it!
cmspooner is offline
Old 06-09-2012, 09:35 AM   #22
Jeff Lange
Jeff Lange's Avatar
Drives: 1986 AE86 GT-S, 2011 Lexus IS250 6M
It calculates the gear you are in based on vehicle speed to engine speed ratios. In order for it to tell which gear you were in before that, you'd have to have several sensors in the transmission or shifter to tell it.
I think it's cool it has it at all, as it's pretty unnecessary.
Jeff
2011 Lexus IS350 F-Sport 6MT with LSD
1986 Toyota Corolla GT-S Supercharged
Jeff Lange is offline
Old 06-10-2012, 11:05 AM   #23
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
This. I prefer paper over digital although I've never tried using a fsm on a tablet. Digital can work I'll just be doing a lot of printing.
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Dave-ROR is offline
Old 06-10-2012, 12:08 PM   #24
Rejor11
Drives: Mini Cooper
Paper books FTW
Rejor11 is offline
Old 06-10-2012, 04:18 PM   #25
OrbitalEllipses
Drives: Attitude
Samesies. Had a lot of grease/dirt covered loose print outs of my last FSM haha.
Old 06-10-2012, 11:12 PM   #26
Hachiroku
Administrator
Hachiroku's Avatar
Drives: Boxster 986
Get the shop / service manual here!
http://www.ft86club.com/forums/showthread.php?t=8374
Hachiroku is offline
The Following User Says Thank You to Hachiroku For This Useful Post:
michaelahess (06-10-2012)
Scion Service Boost NERO BRZ First-Gen (2012+) — General Topics 33 08-15-2012 04:12 PM
Service Parts! Motul Oil / Oil Filters vividracing Mechanical Maintenance and Tools 8 06-20-2012 12:46 AM
Service Manual Availability RYU BRZ First-Gen (2012+) — General Topics 33 06-11-2012 05:00 PM
A Public Service Announcement. Guff Off-Topic Lounge [WARNING: NO POLITICS] 16 04-21-2012 02:26 AM
2001 corolla service manual..? mrtodd Other Vehicles & General Automotive Discussions 3 05-25-2010 01:22 PM
