| Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack Specific topics relating to wheels and tires. |
#1625 | |
Drives: FR-S 10 series
IG: @Lucky_FatPat
10 series // TRD x Turbo Build: http://www.ft86club.com/forums/showthread.php?t=79474 |
| The Following User Says Thank You to mmmcambelsoup For This Useful Post: | FR-Shred (01-07-2016) |
#1626 | |
Drives: 2013 Nissan GT-R, 1985 Porsche 944
And i was running 225 and 245 previous set up on stock wheels and it worked quite well. Also if you're right I still might be able to compensate for it by adjusting the swaybars.
#1627 |
Drives: 10 Series #974 6m/t
#1628 |
Completely Lost
Drives: 2015 CBS BRZ Limited
Meaty Tire Thread
255/40/17 on a 17x9 +42 needed a 5mm spacer in front Stock springs Sent from my iPhone using Tapatalk
#1629 |
Grip>Drift
Drives: FRS
Sway bars are the very last thing you should tune when trying to set-up a car. Trust me the car needs more front grip not rear grip.
#1630 |
Drives: 15' FRS
Been wanting to play in this thread for a while!
18x9.5 et38 265/35/18 Dunlop DZ102
| The Following 6 Users Say Thank You to koukiboss For This Useful Post: | funwheeldrive (01-22-2016), Hicklinc (02-25-2018), JoeHK (12-28-2015), mmmcambelsoup (01-08-2016), number1Tango (01-08-2016), slow15frs (01-21-2016) |
#1631 | |
Drives: Raven Toyota GT86
h
That looks spot on! Nicely done sir ![]() Sent from my Potato using Tomato
Toyota Corolla E12 Hatchback (2005) - GONE
Toyobaru GT86 ハチロク - CURRENT |
#1632 |
Tennis Pro
Drives: '13 DGM BRZ. '07 600RR
This setup is GORGEOUS!!
Cool shot bro. Hit it again.
| The Following 2 Users Say Thank You to ClintimusPrime For This Useful Post: | mmmcambelsoup (12-30-2015), pcporo (01-17-2016) |
#1633 |
Drives: Asphalt 2013 FR-S
Anyone got thoughts on running a 245/40/18 on an 18x8.75 wheel? There will defs be some meat to it, but any negatives this could cause? Understeer possibility? Love the meaty look just don't want to sacrifice drivability for it.
| The Following User Says Thank You to BDotG For This Useful Post: | gMit (01-19-2016) |
#1634 |
Drives: Mario
Does anybody put 255/30r19 on 8.5J? Now I have 245/30r19 but I want moar meat!
#1635 |
Killed Scion
Drives: 2013 FR-S Whiteout
I should be joining this thread shortly....
Miyuki みゆき "Beautiful Snow" The Whiteout FR-S Instagram: trevor.parque Last edited by MisterSheep; 01-20-2016 at 11:31 AM. |
| The Following User Says Thank You to MisterSheep For This Useful Post: | Hicklinc (02-25-2018) |
#1636 | |
Read the tire specs from the manufacturer. Every tire is made different. Not many people run 19's, but you should be ok if tire specs are reasonable. Offsets matter. Only real way to find out is go outside and check for clearances. |
#1637 | |
Drives: 2012 Grey TRD GT86, 2015 VW Golf R
http://www.lvvta.org.nz/documents/in...lity_Guide.pdf These are guidelines for our country but as mentioned they are conservative as are the government approved combinations.
My fully loaded TRD86
http://www.ft86club.com/forums/showt...760#post582760 Last edited by nzer; 01-10-2016 at 02:25 AM. |
#1638 |
@koukiboss are you using natural camber? I had to raise mine and roll fenders from what it was on 245/35/18 to avoid baconing fenders and rubbing.
IG: @Lucky_FatPat
| Winter Tire Review Thread (Please contribute) | pastuch | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 344 | 03-13-2024 06:49 PM |
| Wheel Directory: Forgestar F14 18x8.5 +38/18x9.5 +38 | ScionFR-S | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 97 | 09-09-2015 07:32 PM |
| Meaty rubber on flush spoke rims? | red_comet | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 16 | 06-14-2013 01:21 PM |
| Official wheel/tire fitment thread needed | empower-auto | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 4 | 06-22-2012 02:40 AM |
| The Wheel and Tire Fitting Thread | EvoFanatic | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 2 | 03-15-2012 04:05 PM |
