Old 12-29-2015, 05:28 AM   #1
JoshVDS01
Drives: Toyota 86 GTS Perl White
Unhappy Burning clutch smell on resonantly new 86?!?
Hi everyone!
I have recently started to notice a burning clutch smell in my 2012Toyota 86 GTS which has only 8000km!
I purchased the car 5 months ago second hand and it only had 6500km on the clock. The car was in pristine condition and the only damage on the car was a few stone chips.
The other day I parked my car in the garage and I noticed a subtle but defianate burnt clutch smell. I have noticed it every time I drive it now.
I let my dad drive my car today (car enthusiast) and he said it drives just fine.... He can smell the clutch but he passes it off as my just riding it.
Sorry for the rant but I would appreciate you're help.
I will also add I still have warranty and also an extra 3 ur ectended warranty.
Thanks in advance!!
Cheers
JoshVDS01 is offline   Reply With Quote
Old 12-29-2015, 05:49 AM   #2
steve99
Drives: FT86
Unless you are feeling the clutch slip esecially in higher gearsor you have been launching the car at 6000 rpm its probably not the clutch.
I suspect you might have an oil leak, the most common one is the cam plate oil leak and it leaks onto overpipe causing a smell
google brz cam plate leak or frs cam plate oil leak
humfrz (12-29-2015)
Old 12-29-2015, 05:56 AM   #3
JoshVDS01
Thanks mate. I will check it out. Never dropped the clutch / launched it.
I hope it's an oil leak and not a screwed clutch!
Old 12-29-2015, 06:28 AM   #4
steve99
Drives: FT86
if its an oil leak it should be a warantee job, in addition to the cam plate leak the early cars can leak from near the can actuators and sometimes the rocker covers it generally makes it way onto the exhaust causing burning smell. just take off the alluminium skid plate and have a look
Old 12-29-2015, 08:19 AM   #5
go_a_way1
Not Bаnned Anymore
go_a_way1's Avatar
Drives: Heavily Modified FRS
Just a FYI the clutch is not covered under warranty
Old 12-29-2015, 08:37 AM   #6
Chenslee
Chenslee's Avatar
Drives: 2015 Halo FR-S
Mine stunk for about a month.
I trac off too much
Chenslee is offline   Reply With Quote
Old 12-29-2015, 12:46 PM   #7
Hi everyone!
I have recently started to notice a burning clutch smell in my 2012Toyota 86 GTS which has only 8000km!..............
Thanks in advance!!
Cheers
Hi ya, JoshVDS01 and welcome to ye ol forum ......
If you suspect the clutch is slipping, I suggest the following indicator test:
Set the emergency/parking brake
Put the car in 2nd gear
Rev to about 3,000 rpms
Slowly let out on the clutch
If the engine dies .... the clutch still has life
If the engine keeps on running, either your clutch and/or pressure plate is bad
Can you tell the difference between burnt clutch and burnt oil .. ??
(burnt clutch smells like ........ well, burnt clutch ..... )
Old 12-29-2015, 01:56 PM   #8
JoshVDS01
Thanks mate!
Just tried that and it didn't slip!
I'm glad it didn't!
I could still smell clutch after that as expected but I have been instructed to wash ms engine block / bay and tranny to remove any clutch dust / smell by Totota.
I think I might be a pit paranoid as I let my mum drive the 86 when I needed her ute. Maybe she did burn it a bit and some dust it in the engine and it smells every time I drive it?? Idk.
Yeah I'm sure I know the difference between burnt clutch and burn oil. It kinda smells like brakes... But worse.
Anyway. Thanks for youre help!
The Following User Says Thank You to JoshVDS01 For This Useful Post:
humfrz (12-29-2015)
Old 12-29-2015, 05:55 PM   #9
jcw99
Drives: swp mt '14 brz premium
I think I saw her leaving the grocery store
jcw99 is offline   Reply With Quote
Old 12-29-2015, 07:59 PM   #10
So, you're the one that told her that she had left the parking brake on .....
Old 12-29-2015, 08:03 PM   #11
That's funny. I was considering something along those lines.
humfrz (12-29-2015)
Old 01-02-2016, 02:02 AM   #12
Hi everyone!
So, @JoshVDS01 ...... is this case closed ......
Your mum did it ..... ??
Ultramaroon (01-02-2016)
burning, clutch, problem
Weird Burning Smell? t00n3wb Issues | Warranty | Recalls / TSB 27 05-21-2018 03:58 PM
Burning smell PLease help! Chase1996 Issues | Warranty | Recalls / TSB 62 11-02-2015 01:11 PM
Anyone smell burning outside the car? DarrenDriven Scion FR-S / Toyota 86 GT86 General Forum 115 01-13-2015 01:31 AM
Did I smell my clutch burning...? Ultra marine Scion FR-S / Toyota 86 GT86 General Forum 13 10-08-2013 08:27 PM
Burning smell Boofneenee Issues | Warranty | Recalls / TSB 6 09-30-2013 06:28 PM
