Old 12-26-2015, 11:09 PM   #379
nelsonzep
Drives: 2013 Scion FRS
Just updating precoous info in switching back to 93 while i was still on e85 tune with 93 in tank right after fill up ltft dropped to about 14% i know when ltft changed i am supposed to switch to the other tune but it dropped to almost normal levels while on e85 i am very co fused here? Can i get your input on this please
nelsonzep is offline   Reply With Quote
Old 12-26-2015, 11:24 PM   #380
phrosty
When switching back to 93, you wait for FTs to go negative. It can take a while for 93 to clear through your fuel lines. Don't trust idle FTs because those tend to fluctuate.
phrosty is offline   Reply With Quote
Old 12-27-2015, 01:46 PM   #381
Texas2016Frs
Bottled FRS
Drives: 2016 manual frs
dont worry about stft it varies widly with throttle and load
ltft is the one to watch and the actual afr
if you have a low e% due residual petrol ltft will trend negitive but as long as afr at wot is mid to low 12 its ok
midrange mid throttle afr arround 13 or high 12
cruising and idle afr arround 14 to 14.7
on your next tank it will likely be less negitive ltft
here's my log could you take a look please? http://www.datazap.me/u/texas2016frs...7-8-9-10-11-12
Texas2016Frs is offline   Reply With Quote
Old 12-27-2015, 04:34 PM   #382
steve99
Drives: FT86
it looks ok from what i can see, some of the parameters like iam are not logging correctly appears the oft logging for the 2015 some parameters not working correctly.
it very light throttle but it looks ok.
maybe do a short full throttle from 2000-5000 and see what that looks like_ You should see afr getting down to 13 and into 12 past 4000 or so.
Texas2016Frs (12-29-2015)
Old 12-27-2015, 05:46 PM   #383
Texas2016Frs
Bottled FRS
afr does get down to 12 anything else i should look for? thank you for your help!
Old 12-27-2015, 06:01 PM   #384
steve99
Drives: FT86
knock, but unlikely on e85
have a read of the logging link below
Old 12-28-2015, 10:39 PM   #385
Texas2016Frs
Bottled FRS
here is a log of a few wot accelerations, if you have time please take a look (:
http://www.datazap.me/u/texas2016frs...7-8-9-10-12-14
Old 12-29-2015, 06:08 AM   #386
steve99
Drives: FT86
mate it look like its settled down now the ltft are max -7% which is pretty normal with residual petrol and the afr wot high rpm is 11.3 bit on the rich side but safe. Being rich costs you some power but is safe
no knock indicated, dont worry about the iam being zero looks like oft logging issue
are you on latest openflash manager and template files from oft downloads site ??
Old 12-29-2015, 01:37 PM   #387
Texas2016Frs
Bottled FRS
Yes I am completely deleted/redownload everything yesterday to make sure. It's very humid and I read somewhere that it can cause the engine to run rich is that true?
Thanks for taking a look!
Old 12-29-2015, 05:10 PM   #388
steve99
Drives: FT86
ambient temps can change fuel trims a bit
with very high fuel trims previouisly its possible the wrong tune was flashed, if all thats changed since last log, ie you havenot refilled tank
Old 12-29-2015, 07:53 PM   #389
Texas2016Frs
Bottled FRS
I know that it's the same tune because I took great care (checked like 5 times) to make sure I put the right tune on and then also checked after it was flashed to the car any ideas?
Old 12-29-2015, 07:54 PM   #390
Texas2016Frs
Bottled FRS
The ambient temps changed about 40+degrees in 2 days
Old 12-29-2015, 08:06 PM   #391
steve99
Drives: FT86
Wow 40 yep you could expect the lower end fuel trims to vary maybe 5% with uch a big change, it probably the residual petrol in tank as well and trims averaging out but looks ok now, the lower end fuel trims vary more as at idle and low speed temps vary widly under bonnet especially in hot weather.
Old 12-29-2015, 08:56 PM   #392
Texas2016Frs
Bottled FRS
Do you think that once the ecu learns the trims again it will run less rich?
Stock FR-S Tune Just Done Zach3794 Engine, Exhaust, Transmission 67 11-05-2017 02:01 PM
stock BR-Z, much detonation during shifts: tune? elefunkd Engine, Exhaust, Transmission 69 07-26-2013 04:20 PM
Anyone have a stock tune from Visconti? Bleevin CANADA 3 07-03-2013 01:01 AM
My Initial (all stock) BRZedit tune mad_sb Engine, Exhaust, Transmission 6 02-16-2013 12:20 PM
Save stock tune with ecutek? gdrider77 Engine, Exhaust, Transmission 7 01-06-2013 12:50 AM
