Old 12-24-2015, 09:41 PM   #15
CSG Mike
CSG Mike's Avatar
Originally Posted by FRS Justin View Post
I ran a N1 and a PPE equal length merge collector, the car went over 200hp on the dyno and 13.47 in the 1/4 mi.
Videos are on this site in the 1/4 mile time thread or go to youtube type
13 47 frs if you want to hear it also 13 52 frs
I was on E85 still am and yes very noticeable. The car ran 15s factory, mods to the 13.5 that's a lot. You have to get a tune with a header have to or it runs like poop.
Go drive a new SI civic and that will give you a idea
I'd be curious to see what you could have done with an Ace header, as it already hits the 200whp mark (rounded up from 199.6) on CA 91.
Old 12-24-2015, 09:46 PM   #16
stevo585
Drives: White 2014 BRZ
A civic Si is alot slower than you. They are maybe slightly faster than a stock 86 see here:
http://www.roadandtrack.com/new-cars...-65-6-roa0214/
Might "feel" faster due to the torquey engine.
stevo585 is offline   Reply With Quote
Old 12-24-2015, 10:29 PM   #17
FRS Justin
Drives: 2013 Asphalt FRS
I was just going after the 205 hp they have, never thought about the torque my bad, good point
Instagram FT86PROJECT9S
Facebook FT86PROJECT9S
710whp
FRS Justin is offline   Reply With Quote
Old 12-24-2015, 10:32 PM   #18
FRS Justin
Ya I would definitely like to know. I still have that motor on a stand I could swap it back in there if I should happen to get some one to lone me a header, then have Bill retune it. Im running 13.47 and the record is 13.32 be nice to take that back again.
710whp
Old 12-24-2015, 10:42 PM   #19
FRS Justin
Is this all the mods you have? I have trouble getting under 14.5 @ 96. My best being 14.3 @ 97. I have borla UEL, catless fp, e85, ecutek by HRI tuning.
13.5 is damn impressive. Are you on slicks? Very cold weather? I'm in Florida so it is warm even now.
Edit: I see you have gears and slicks. That's probably making the difference. Agree? Since I can only do a 2.2x maybe 2.15.
N/A I run a 225 17 hoosier on the stock wheel hit 13.52 Then I switched to a 26x10 slick 13.47 with 4.56 gear. I have gone 13.60s with factory gears. For N/A best times you need a cool night like in the low 70s or more and low humidity. Humidity really hurts this car's performance N/A I have lost 3/10ths because of 90% humidity. I launch at 7800rpm and run a 1.76 60ft
710whp
Old 12-24-2015, 10:49 PM   #20
BRZ_F
BRZ_F's Avatar
Drives: 2013 WRB BRZ
Originally Posted by vitti821 View Post
Hey,
I am sort of new to the mod scheme of the BRZ, and I am looking to replace my stock header. So far I have done exhaust and that really it for mods. ANy suggestions on what header to get.
What I am looking for in header:
- maximum performance/ HP gain/torque increase
- sound increase doesn't matter because My current exhaust sounds good enough
- reasonable pricing because I am not loaded
Thanks for your help
Gruppe-S UEL headers are really good at a great price. They are comparable to the Tomei UEL. You should check them out. The quality is great. I have the coated ones.
I have the Gruppe-S UEL headers and the rest of the stock exhaust with a Stg 2 e85 UEL tune from OFT and it was a very noticeable difference from stock.
BRZ_F is offline   Reply With Quote
Old 12-24-2015, 10:57 PM   #21
stevo585
Thanks for the info. I understand the et now but your top end though 101 is crazy you must have a factory freak! I find it hard to believe that's just the header which I understand a borla is not the best. My tune is from one of the best in the country so that should be comparable.
The Following User Says Thank You to stevo585 For This Useful Post:
FRS Justin (12-25-2015)
Old 12-24-2015, 11:22 PM   #22
vitti821
Drives: 2016 Scion FRS Release Series 2.0
I'm so new to this I have no idea what you guys are talking about but sounds pretty sick lol
vitti821 is offline   Reply With Quote
Old 12-25-2015, 12:35 AM   #23
ollie
ollie's Avatar
Drives: GT86
I think it comes down to where you are going to get your tune from, off the shelf tune use OFT with openflash header. If you are getting your car custom tuned I would go for a ace 4-2-1 running e85.
ollie is offline   Reply With Quote
Old 12-25-2015, 01:05 AM   #24
FRS Justin
I have a stg2 E85 tune from Delicious Tuning and their Flex fuel kit a PPE header and over pipe catless front pipe invidia N1 4.56 gears from weir performance hoosier drag radials 6 puck ACT clutch DSS 600hp axles Airaid cold air intake That is a list of every single mod on the car. And I have hit 104 in the 1/4 max speed. I spun on the launch from shitty track prep. Usually its around 101.82 mph Trust me at the time PPE was the best now I'm hearing great things about ace 4-2-1. You can only tune to what the car can do so if your header doesn't flow you will never see top end performance.
710whp
The Following User Says Thank You to FRS Justin For This Useful Post:
CSG Mike (12-25-2015)
Old 12-25-2015, 01:06 AM   #25
FRS Justin
Its a night and day difference.
710whp
Old 12-25-2015, 04:04 AM   #26
sw20kosh
Drives: 2013 Black FR-S
Ace header comes with an over pipe...so factor that into the price tag.
Old 12-25-2015, 05:26 AM   #27
DarkSunrise
DarkSunrise's Avatar
Hey,
This is a nice comparison between headers. Same day, same dyno, same tuner, but different cars. Has some of the top headers (Ace, JDL, PTuning). The low/midrange gains on the Ace are impressive.
http://www.ft86club.com/forums/showthread.php?t=95271
2022 BRZ Build
2013 FR-S Build
Old 12-25-2015, 08:32 PM   #28
stevo585
Right the header is key. Then the drag radials to get the launch.
In my opinion (and research) these should make no real difference to power output:
over pipe
nvidia N1
6 puck ACT clutch
DSS 600hp axles
Not sure how much timing your able to run but I'm able to run 29 degrees @ redline and afr is ~12.0-12.5 on e85. Which of course is essentially MBT.
brz, header, performance
1320 Performance UEL Header? Ronin Sascha Engine, Exhaust, Transmission 53 06-27-2018 06:39 AM
Ark performance Grip or DTS with unequal length header? RogueBRZ Engine, Exhaust, Transmission 18 06-04-2016 09:24 AM
Top Speed Pro-1 Performance Header golfyankee2121 Engine, Exhaust, Transmission 18 02-23-2016 11:13 AM
FS: Nameless Performance EL header, coated toeout Engine, Exhaust, Bolt-Ons 25 05-07-2014 11:03 PM
Exhaust/Header/Performance Guidance eddieEndo Engine, Exhaust, Transmission 2 09-29-2013 10:48 AM
