Old 12-24-2015, 01:39 AM   #1
dumbforcrumbs
Question Any tips or tricks on how to get your exhaust tips exactly where you want them?
I just installed a Ark Grip catback exhaust on my FRS and it hangs a little too far to the right. I had my friend hold it in place while I did the final torquing to it but it seems to just slide a little on the rubber hangers once all is said and done. What am I doing wrong?
dumbforcrumbs is offline   Reply With Quote
Old 12-24-2015, 01:59 AM   #2
Mr.ac
[insert cool phrase here]
Mr.ac's Avatar
Drives: BRZ Premium
Sounds to me like the bends where screwed from the get go. You could try bending it your self or taking it in to a muffler shop.
Old 12-24-2015, 03:56 AM   #3
swarb
Pics?
Not all cars are made the same, same with the exhaust. If it is off by a little bit, it is probably normal. Many people are very anal about tip alignment, they want it perfect, and if it is 5mm off they aren't happy.
You can try-
-messing around with the rubber hanger like using two of them so there is rubber stop holding it from moving any further as it would be bottomed out. Or getting new ones that are harder(?) or have more grip.
- bolting down one side of the flange, then holding it in place and then the other side. Similar to what your friend said.
-create a small angle on the flange with a belt sander, but make sure it is flat afterwards. be careful as a little goes a long way.
-exhaust shop
-look at pics of the same exhaust and realize that some are off by a little, and just live with it.
Pics?
The Following User Says Thank You to swarb For This Useful Post:
Cole (12-24-2015)
Old 12-24-2015, 11:27 AM   #4
WhiteFRS69
WhiteFRS69's Avatar
Drives: 2014 Scion FRS
mine stuck out to far for my liking so i used some large hose clamps... rapped it around the rubber exhaust hanger and pulled mine back in
could try doing something like this
Old 12-24-2015, 12:18 PM   #5
dumbforcrumbs
Old 12-24-2015, 01:04 PM   #6
Vracer111
Vracer111's Avatar
Drives: '13 Nissan Frontier (4.0L 6spd 2WD)
Just cut off the rear fake diffuser and it won't be noticed...plus you get to show off the exhaust and gain better high speed stability with an aftermarket split muffler setup:
Or go with a single center exit exhaust system...
Had a '13 FR-S Asphalt 6spd manual (bought new 5/25/12, sold 6/10/20) but needed to let her go... she will be missed.
Vracer111 is offline   Reply With Quote
Old 12-24-2015, 01:34 PM   #7
dumbforcrumbs
Looks too naked for me without it, also do you not have a reverse light now?
Old 12-24-2015, 01:37 PM   #8
First, invite a friend over.
Have a couple of beers.
Have your friend push it over with their foot to a little past straight ...... then you get under there and "wire" the whole muffler over a bit.
Yep, baling wire and duck tape will fix most everything .....
Finish off the 6-pack .......then it will be straight .........
The Following 3 Users Say Thank You to humfrz For This Useful Post:
Cole (12-25-2015), DAEMANO (12-24-2015), Tcoat (12-24-2015)
Old 12-24-2015, 01:54 PM   #9
As much as it sounds like Hum is joking that is exactly what I would do. It is off to the right the same on both sides so push and wire it would be. Nobody will see it hidden up there.
humfrz (12-24-2015)
Old 12-24-2015, 03:05 PM   #10
DJCarbine
Thupercharged
DJCarbine's Avatar
Did this with my N1 exhaust when I had it. Some metal pipe strapping and used an existing tapped hole. Can't see it unless you were under the car.
Could also use wire and a turnbuckle to get it lined up perfectly/adjustment, but I'm not that classy
2013 FRS
Vortech V3 11psi
Revworks UEL - PLM Overpipe - MOTIV catted frontpipe - Invidia Q300
2019 Series.Grey STI - Stage1+ SF
DJCarbine is offline   Reply With Quote
The Following User Says Thank You to DJCarbine For This Useful Post:
Tcoat (12-24-2015)
Old 12-24-2015, 04:57 PM   #11
Vracer111
Vracer111's Avatar
Yeah cutting out the rear is personal preference - I cut mine because the offset exhaust actually melted the passenger side cutout so the fake diffusor was messed up. I really like it though as it slims the rear down. For reverse lighting what my FRS has is better than the weak stock setup, Diode Dynamics Tail-as-Turn module with XP-80 LED bulbs. Basically rear facing headlights...
Old 12-24-2015, 05:15 PM   #12
Clipdat
Proud of BOXER
Clipdat's Avatar
Drives: Subaru Boxer
Use a few of these on the exhaust's metal hangers, so that they can't side in or slide in further to the rubber hangers and then stay in place. Hard to describe but once you get under there with a few of these ready to go it makes sense.
Originally Posted by humfrz
I'm old and lazy
Old 12-24-2015, 06:29 PM   #13
dumbforcrumbs
Thanks for all of the advice guys! I'll try out the suggested methods and post the results.
Old 12-24-2015, 07:14 PM   #14
mav1178
mav1178's Avatar
Drives: 2005 Toyota Camry
Zip ties.
Tips and tricks on driving the car Mad1723 Scion FR-S / Toyota 86 GT86 General Forum 31 07-17-2013 05:22 AM
Tips and Tricks: Disconnecting the Battery Necessary Post Intake Install? ScionFR-S Engine, Exhaust, Transmission 8 12-17-2012 06:39 AM
Tips and Tricks for reconditioning your car for trade in? SteelReign Other Vehicles & General Automotive Discussions 17 06-04-2012 12:53 PM
Tips, tricks, techniques to improve driving? Buggy51 Off-Topic Lounge [WARNING: NO POLITICS] 15 08-01-2011 05:17 PM
