Old 07-14-2013, 12:52 PM   #1
Mad1723
Mad1723's Avatar
Drives: Asphalt FR-S
Question Tips and tricks on driving the car
Hey guys,
I just got my new Asphalt FR-S last friday and I'm really happy with the purchase. It's an amazing car and it's already turning a lot of heads.
Now, here's my problem: This is my first manual car. I know some of you would say that learning on a brand new car is not ideal, but this is the situation I am in. I took a few classes before, but never had a full-time manual car. Please bear with me and refrain from hitting me on the head for that.
I'm already getting the hang of it, but there's a problem I can't seem to figure out.
When shifting from 1st to 2nd gear, I can't seem to make it smooth. It's constantly jerking forward. I tried multiple ways to release the clutch and it seems like I can't get it smooth. 3rd, 4th, 5th and 6th are all fine. Any tips on the way to shift properly so it doesn't do that?
Any help would be greatly appreciated!
Thanks!
Mad1723 is offline   Reply With Quote
Old 07-14-2013, 01:01 PM   #2
whaap
whaap's Avatar
For normal driving I would say use first gear just to get moving and then shift into second. Don't accelerate quickly until you're in second gear. That might make it easier for you and as you gain more practice/experience you can deviate more to your liking.
whaap is offline   Reply With Quote
The Following 3 Users Say Thank You to whaap For This Useful Post:
humfrz (07-16-2013), Mad1723 (07-14-2013), scary alien (07-14-2013)
Old 07-14-2013, 01:07 PM   #3
wrxgoose
WUB WUB
Drives: 2013 Firestorm
are you letting off the gas completely when going 1-2? or are you trying to rev match?
wrxgoose is offline   Reply With Quote
The Following User Says Thank You to wrxgoose For This Useful Post:
Old 07-14-2013, 01:07 PM   #4
Wes
Wes's Avatar
Drives: JRSC'd Asphalt FR-S
Try taking it slow getting into second, this happened to me too until I found the right method. Try clutching all the way thenn shift into second and release the clutch a little slower as you would with gears 3 to 6. As you get used to it you'll be able to do it faster. It takes some time
The Following 2 Users Say Thank You to Wes For This Useful Post:
Old 07-14-2013, 01:12 PM   #5
encity5
encity5's Avatar
no real magical explanation, better/smoother will come with experience as you learn and feel the car.
encity5 is offline   Reply With Quote
The Following 2 Users Say Thank You to encity5 For This Useful Post:
Old 07-14-2013, 01:13 PM   #6
Mad1723
Mad1723's Avatar
I'm usually letting go of the gas completely, pressing the clutch pedal fully while switching to second and then I depress the clutch fully at what I think is a steady rate, then slowly get back on the gas.
I will try that later today and keep practicing.
I also read on this forum about a 2nd gear synchro problem with the factory oil. Some people mention switching to Redline oil for the transmission helped their problem. Could that be something to consider in my case or is it only a problem with my inexperience?
Thanks
Old 07-14-2013, 01:54 PM   #7
whaap
whaap's Avatar
Though I don't consider it a problem, the only time I might have a little glitch between first and second is when I first start up the first time after backing out of the garage. The first time I take off forward I notice a little resistance as I shift into second. There after for the rest of the drive things are normal. I don't consider that little hiccup worth doing any thing about it.
If you have any relatives that are experienced in manuals that could drive your car and give you some tips it would help. Be sure they're of a mature nature. You don't need some hot dog trying to show off giving you tips at this stage of your learning. You would benefit from someone who could just gently go thru the mechanics and perhaps give you a few tips. Time and practice will pay off for you. Don't be in a hurry.
The Following User Says Thank You to whaap For This Useful Post:
Old 07-14-2013, 01:54 PM   #8
bkblitzed
is better than you
bkblitzed's Avatar
Drives: 2013 raven FRS
Driving smooth through town, is a lot harder than changing gears fast in a race. Just keep practicing, and you'll pick things up.
bkblitzed is offline   Reply With Quote
The Following User Says Thank You to bkblitzed For This Useful Post:
Old 07-14-2013, 02:11 PM   #9
Mad1723
Mad1723's Avatar
Thanks Whaap, I'll go for a bit of practice with someone I know who's been driving manual transmissions for 20+ years, we'll see how that goes.
Thanks for the answers everyone, I'll report back on the progress
Old 07-14-2013, 03:42 PM   #10
5th 86
Drives: 2013 BRZ SPORT TECH
Let the rpms drop a bit more from 1-2, like wait a sec or half second longer b4 you slowly let the clutch out, and buy some proper driving shoes. Shoes that have next to no padding in the soles so you have better feel. Those $100 puma's work good.
5th 86 is offline   Reply With Quote
The Following User Says Thank You to 5th 86 For This Useful Post:
Old 07-14-2013, 04:03 PM   #11
pmdc
pmdc's Avatar
Drives: Raven FR-S 6MT
With normal city driving, let the clutch out slowly going in to 2nd. I've been driving mt for 11 years and I'm still not perfectly smooth (like auto smooth) going 1-2 at low revs in this car yet.
pmdc is offline   Reply With Quote
The Following User Says Thank You to pmdc For This Useful Post:
Old 07-14-2013, 04:28 PM   #12
Bt216
Bt216's Avatar
Drives: Scion frs
It only happen s to my car when cold... I flushed the fluid and use motul.. its better but still does it when cold and its always 1st and second . I think its a defect
Bt216 is offline   Reply With Quote
The Following User Says Thank You to Bt216 For This Useful Post:
Old 07-14-2013, 04:33 PM   #13
5th 86
I think its how short the ratios are which is why if you dont redline 1st and are driving normal you gotta wait a bit longer for the revs to drop more.
Old 07-14-2013, 04:48 PM   #14
MrSlay
Drives: Gx 460, FRS, Prius
Best advice that I can give is to learn what is actually happening mechanically when your using a manual transmission. Once you understand the actual physical movements of the mechanical peaces, you can use general competency to make adjustments and build a knowledge base that utilizes both factual information as well as dexterity.
15 FRS
12 Prius
12 ISF
15 Gx 460
My YouTube Channel
MrSlay is offline   Reply With Quote
The Following User Says Thank You to MrSlay For This Useful Post:
Tips and Tricks: Disconnecting the Battery Necessary Post Intake Install? ScionFR-S Engine, Exhaust, Transmission 8 12-17-2012 05:39 AM
Test driving an AT in 2 hours, any tips? niharG Scion FR-S / Toyota 86 GT86 General Forum 33 06-13-2012 04:14 PM
Tips and Tricks for reconditioning your car for trade in? SteelReign Other Vehicles & General Automotive Discussions 17 06-04-2012 11:53 AM
Tips, tricks, techniques to improve driving? Buggy51 Off-Topic Lounge [WARNING: NO POLITICS] 15 08-01-2011 04:17 PM
