Old 12-22-2015, 01:31 PM   #15
JazzleSAURUS
Drives: 15 BRZ LTD, 05 FXT
This is a perfect example of not researching what you want costing you money.
You have a catless header with a loud catback, and removed the only other restriction.
A stock catback with some nice tips should make the volume much more reasonable, or swapping the catback for something quieter, (Greddy Supreme SP, Invidia Q300, Perrin 2.5", HKS Legamax, FT86 Speed Factory, etc.)
You can do a lot, but if you do catless headers expect having to work hard to keep the volume down, or very, very loud. I would start with the stock catback since that has the least restriction. If it sounds good, leave it. If it's too quiet, swap the J2 for another option.
This is all a part of 'tuning' a car to your liking. If a part is too much, you didn't research, or the wrong idea about a part. Try and ride along in cars to find out what you like.
JazzleSAURUS is offline   Reply With Quote
The Following User Says Thank You to JazzleSAURUS For This Useful Post:
wparsons (12-22-2015)
Old 12-22-2015, 02:36 PM   #16
86kahl
86kahl's Avatar
Drives: whiteout, dark tint
Actually afraid? Damn I must be getting old. I for one love the unrestricted rumble, sharp raspy note and machine gun cold starts... My neighbors, not so much😅😅😅
In any case, I have stock exhaust parts taking up space and would be willing to take that loud set up off your hands😁
86kahl is offline   Reply With Quote
Old 12-22-2015, 02:43 PM   #17
wparsons
wparsons's Avatar
Originally Posted by KoolBRZ View Post
What do you have for a tune? I have no Cats at all, and my wife never complains about the noise. I tune with an OFT and use the quiet start fix. I've also found better acceleration with milder AVCS exhaust timing. Your exhaust change has also changed your back-pressure and exhaust flow dynamics, so your tune should be changed to make the most of this. In the meantime you could reduce the noise without losing all your gains by just swapping out your front pipe with the OEM one. The Cat will reduce the noise you are hearing without impeding the flow as much as other options. One other thing, make sure to plug the opening on the passenger side floor mat where the sound tube comes through. and flip your rear seats up.
What exhaust do you have?
The tune is going to have very little effect on volume of noise from an axle back exhaust.
You're better off running the stock cat-back with an aftermarket front pipe than the stock front pipe with an aftermarket cat-back. There's more power held back by the front pipe than the cat-back.
flickr
Old 12-22-2015, 04:49 PM   #18
twag4
Drives: frs
I had a crazy stupid extremely loud exhaust with an ace header, catted resonated front pipe, and Corsa cat back. I sold the Corsa and got the invidia q300. It sounds great now, not that loud at all. The stock cat back was quiet too, but it sounded like crap. Very buzzy, plus it is ugly. I am extremely happy with the q300, great purchase!
twag4 is offline   Reply With Quote
Old 12-22-2015, 04:56 PM   #19
stockysnail
Just the tip
stockysnail's Avatar
Originally Posted by svnintl View Post
The Invidia Q300 fits the FR-S/BRZ ? or did you have to make some mods ? Looks to be a good system if I can solve this noise problem.
Yes they make one for the BRZ/FR-S and I have it. Check it out in my build thread if you'd like.
Old 12-22-2015, 10:21 PM   #20
svnintl
Drives: scion frs
Update: I put back the stock front catted pipe. Noise level is down, but still driving on freeway 3-4k rpm still makes it uncomfortable. Only when gassing though, there's that raspy noise that gives me a pressure head feeling. The midpipe can't be replaced back to stock because that won't fit the j2 exhaust system.
So now it's either put back stock exhaust or remove the Tomei headers....any opinions? I did do some research but didn't hear much about noise level of j2 tunes being too loud for the users. So either they didn't have headers like mines or....maybe my ear drums are getting old.
svnintl is offline   Reply With Quote
Old 12-22-2015, 10:33 PM   #21
twag4
Drives: frs
Put the aftermarket front pipe back on, then try the stock cat back. If it makes you happy, but still sounds crappy- then the q300 will make you happy and sound good. It is free to try the stock catback too. If you need them, you can buy exhaust gaskets at oreilly auto parts or the equivalent. The oreilly part number is EG24685. It'll work between header and front pipe. Under $3 when I bought them.
Old 12-23-2015, 09:55 AM   #22
svnintl
Drives: scion frs
I was thinking if getting http://www.furiouscustoms.com/toms-b...s-subaru-br-z/ . + front pipe . Shouldn't produce any raspy noise? Hopefully...hate that's raspy noise above 3000k
Old 12-23-2015, 10:58 AM   #23
twag4
Drives: frs
That is a huge amount of money for what if...
Old 12-23-2015, 11:20 AM   #24
svnintl
Drives: scion frs
I've been doing a lot more research now. The Q300 exhaust system seems to produce no rasp, even with full catless setup. Very nice....very safe with the sound point.
Vs the Tom barrel W...looks distinct. It's an axel back so keep all pipes stock it shouldn't be anywhere that bad as this j2 exhaust. I drive long trips needless say at high speed bringing rpms to 4000+ so noise and esp rasp is big factor. Low drone and loud is ok but that rasp makes my head want to split. Wonder if anyone can comment on the tom W pipes with UEL headers, any raspy at high rpm?
I've learned my lesson. Good thing the j2 wasn't that much
Old 12-23-2015, 08:03 PM   #25
svnintl
Drives: scion frs
So finally: Tomei UEL headers and stock pipes, exhaust. Almost quiet like factory, can hear headers flow at higher RPM. Prob take advice from those and get the Q300! thanks everyone.
The Following User Says Thank You to svnintl For This Useful Post:
JazzleSAURUS (12-31-2015)
quiet and loud exhaust both in 1 JonMotoring Engine, Exhaust, Transmission 28 04-24-2020 02:22 PM
Loud exhaust / Buddy Club Spec II exhaust help! chiefshayan Engine, Exhaust, Transmission 26 12-06-2019 05:59 PM
How loud is the n1 exhaust? ( in db) jon2 Scion FR-S / Toyota 86 GT86 General Forum 7 02-22-2015 03:04 AM
My exhaust is loud mike2100 Mid-Atlantic 1 08-25-2013 09:13 PM
Looking for a loud exhaust Itssrayyxd Engine, Exhaust, Transmission 66 04-01-2013 03:53 PM
