#3123 |
Drives: '08 MX5 6MT & '15 BRZ Premium 6MT
#3124 |
Drives: FRS
Honestly I don't know I threw boxes away. They look like these https://m.pepboys.com/product/details/8560612/00745
Just get few and difference sizes. They are slightly wider than jackson racing ones. I looked up, people recommend T clamps, but they a bit harder to install specially in hard to reach areas. Just have few extra in the car just case. I heard some people had issues with clamps around MAF tube so keep an eye on those as well. Sent from my SM-N910T using Tapatalk |
| The Following User Says Thank You to Binary_fission For This Useful Post: | SHWNBRZ (12-22-2015) |
#3125 |
So far the clamps around the MAF tube stays on tight.
I was looking at those T-clamps myself. They have this: Spectre Performance Intake T-Bolt Clamp - 3-Inches Its available from Pepboys and Autozone. So from what people recommended, I'll be getting a set of new clamps. That T-bolt clamp is 1/2" wide. IIRC, the NORMA 70-90 hose clamp that Jackson Supplies is about 9mm (.35"). I'll see what the mechanic has in mind about the issue. Perhaps adjusting the piping may be in order as well... So get the beefier clamp(s), then position it closer to the throttle body so the silicone hose does not slip. Any additional thoughts on the slipping issue? Will follow up tomorrow. |
#3126 | |
Drives: 2016 FR-S
![]() Replaced both clamps on that hose since the one near the pulley was almost completely cut by the pulley and the one at the TB end was clearly not keeping the hose from slipping off. Pretty annoying
| The Following User Says Thank You to Sleepless For This Useful Post: | Binary_fission (12-22-2015) |
#3127 |
Drives: JR FR-S,
The Norma clamps included are the same used by World Endurance Championship racing teams at the 24Hours of Daytona/LeMans etc. We use the same clamps on all our street and race cars. Norma clamps will hold just fine when installed correctly, T-Bolts are not needed and are more trouble.
Remember the Norma clamps will not "click" when tight. When they stop turning, they are tight. Do not over tighten or you will strip the clamp. As @SPCorBUST said, put the clamp closer to the throttle body lip. Also, make sure the clamp is on the throttle body all the way around. -Oscar Jr. |
| The Following 2 Users Say Thank You to Jackson Racing For This Useful Post: | Rapiddan45 (12-22-2015), SHWNBRZ (12-22-2015) |
#3128 |
Opted not to use a t-bolt clamp. The hose clamp was readjusted. After a few pulls, it's holding steady.
Tubing/piping were adjusted. Just waiting for my replacement pulley from Jackson Racing as well as a replacement 45 degree 2.3-3" silicone hose. For the time being, no slippage...rubbing...or any visible wear on other components. |
#3129 |
Drives: 2016 FR-S
Yes, the supplied clamps are fine, if not a bit finicky . On mine, the issue was that the clamp felt tight and didn't seem to want turn any further. Turns out it could be tightened more. I replaced with one that didn't "stick". Guessing it was a manufacturing flaw ..
IMO the clamps with cut slots have a much better feel and aren't as easy to over tighten or strip. Never been a fan of the Norma pressed in grove style
#3130 | |
Fast enough
Drives: 2013 Subaru BRZ AT
#3131 |
Drives: FRS
Anyone know if i have to tune ecu with custom tune. I have headers, front pipe and exhaust, no cats. I'm running carb tune that came with the kit. One of friends mentioned that I have to get custom tune with those mods otherwise it's bad for the car.
Honestly I don't want more hp or boost, im still gettin used to the car with its current set up, i just want to make sure car runs good and it won't have problems with those mods. Also future mods are lightweight pulleys, lightweight driveshaft, flywheel and clutch. Are those mods will require tune as well or nah? Thanks Sent from my SM-N910T using Tapatalk |
#3132 | |
Stealth
Drives: Ultramarine FR-S
| The Following User Says Thank You to ApolloSki For This Useful Post: | Binary_fission (12-23-2015) |
#3133 | |
| The Following User Says Thank You to JDMChris For This Useful Post: | Binary_fission (12-23-2015) |
#3135 |
Drives: 2013 FR-S M/T Ultramarine
Yes, you for real need a tune. The carb setup is strictly for a car that is stock+the supercharger.
2013 Ultramarine 6MT- Feal 441 coils, Whiteline 20mm front/18mm rear swaybars.
RPF1 17x9 +35. 245/40/17 RS-3 V2. OFH, Invidia OP, Spencer Fab HFC FP, Invidia N1 C38 JRSC, JROC, Delicious Tune, Radium PCV Catch Can Last edited by Rapiddan45; 12-23-2015 at 02:41 PM. |
| The Following User Says Thank You to Rapiddan45 For This Useful Post: | Binary_fission (12-23-2015) |
#3136 |
| Jackson Racing Rotrex Supercharger System Info and Discussion | Jackson Racing | Forced Induction | 827 | 04-06-2020 04:56 PM |
| Jackson Racing Supercharger Press Release and Info | CounterSpace Garage | Forced Induction | 110 | 01-03-2017 09:04 PM |
| jackson Racing engine oil cooler - modular to fit the Jackson Racing Supercharger! | CSG Mike | Forced Induction | 24 | 04-27-2016 12:59 PM |
| Jackson Racing supercharger | NoppyNop | Forced Induction | 241 | 06-26-2014 03:05 PM |
| Jackson Racing Supercharger Pre-Order Sale, $200 off! | Xero-Limit | Forced Induction | 2 | 03-05-2014 04:14 PM |
