Old 12-21-2015, 05:14 PM   #3123
SHWNBRZ
Drives: '08 MX5 6MT & '15 BRZ Premium 6MT
Originally Posted by xsnapshot View Post
I've got my original JRSC standard pulley I could sell you. I went with the High boost version. PM me.
Checked this thread too late I ordered one from Jackson half an hour ago
SHWNBRZ is offline   Reply With Quote
Old 12-21-2015, 11:52 PM   #3124
Binary_fission
Binary_fission's Avatar
Drives: FRS
Originally Posted by SHWNBRZ View Post
Got a part number for the said pepboys clamp? :P
Honestly I don't know I threw boxes away. They look like these https://m.pepboys.com/product/details/8560612/00745
Just get few and difference sizes. They are slightly wider than jackson racing ones.
I looked up, people recommend T clamps, but they a bit harder to install specially in hard to reach areas.
Just have few extra in the car just case. I heard some people had issues with clamps around MAF tube so keep an eye on those as well.
Sent from my SM-N910T using Tapatalk
Binary_fission is offline   Reply With Quote
The Following User Says Thank You to Binary_fission For This Useful Post:
SHWNBRZ (12-22-2015)
Old 12-22-2015, 12:12 AM   #3125
SHWNBRZ
So far the clamps around the MAF tube stays on tight.
I was looking at those T-clamps myself. They have this:
Spectre Performance Intake T-Bolt Clamp - 3-Inches
Its available from Pepboys and Autozone. So from what people recommended, I'll be getting a set of new clamps. That T-bolt clamp is 1/2" wide. IIRC, the NORMA 70-90 hose clamp that Jackson Supplies is about 9mm (.35"). I'll see what the mechanic has in mind about the issue. Perhaps adjusting the piping may be in order as well...
So get the beefier clamp(s), then position it closer to the throttle body so the silicone hose does not slip.
Any additional thoughts on the slipping issue?
Will follow up tomorrow.
Old 12-22-2015, 01:31 PM   #3126
Sleepless
Sleepless's Avatar
Drives: 2014 BRZ
The 45 degree silicone hose that goes into the intake manifold seems to be slipping if I drive the car over 6k rpm. Saw that it slipped enough so the silicone hose from the opposite end came into contact with the pulley. The clamp also rubbed which resulted in my pulley being scraped. The belt is totally fine however...no signs of premature wear from the pulley getting scraped.
I'll be sourcing a stock pulley. If anyone can help me finding an OE pulley for the Rotrex blower, that'd be great. Also, thoughts on why the silicone hose slips off? The clamps were properly torqued down (wasn't over torqued so it wasn't damaged).
I am running on the CARB tune.
Just wanted to pick people's brains about this slipping issue. Car goes back to the shop on Tuesday to get looked at.
Thanks!
Had the same thing happen at the track; required a tow to get back to the paddock
Replaced both clamps on that hose since the one near the pulley was almost completely cut by the pulley and the one at the TB end was clearly not keeping the hose from slipping off.
Pretty annoying
Sleepless is offline   Reply With Quote
The Following User Says Thank You to Sleepless For This Useful Post:
Binary_fission (12-22-2015)
Old 12-22-2015, 01:37 PM   #3127
Jackson Racing
Jackson Racing's Avatar
Drives: JR FR-S,
The Norma clamps included are the same used by World Endurance Championship racing teams at the 24Hours of Daytona/LeMans etc. We use the same clamps on all our street and race cars. Norma clamps will hold just fine when installed correctly, T-Bolts are not needed and are more trouble.
Remember the Norma clamps will not "click" when tight. When they stop turning, they are tight. Do not over tighten or you will strip the clamp.
As @SPCorBUST said, put the clamp closer to the throttle body lip. Also, make sure the clamp is on the throttle body all the way around.
-Oscar Jr.
Jackson Racing is offline   Reply With Quote
The Following 2 Users Say Thank You to Jackson Racing For This Useful Post:
Rapiddan45 (12-22-2015), SHWNBRZ (12-22-2015)
Old 12-22-2015, 04:56 PM   #3128
SHWNBRZ
Opted not to use a t-bolt clamp. The hose clamp was readjusted. After a few pulls, it's holding steady.
Tubing/piping were adjusted.
Just waiting for my replacement pulley from Jackson Racing as well as a replacement 45 degree 2.3-3" silicone hose.
For the time being, no slippage...rubbing...or any visible wear on other components.
Old 12-22-2015, 06:31 PM   #3129
Sleepless
Sleepless's Avatar
Drives: 2014 BRZ
Yes, the supplied clamps are fine, if not a bit finicky . On mine, the issue was that the clamp felt tight and didn't seem to want turn any further. Turns out it could be tightened more. I replaced with one that didn't "stick". Guessing it was a manufacturing flaw ..
IMO the clamps with cut slots have a much better feel and aren't as easy to over tighten or strip. Never been a fan of the Norma pressed in grove style
Old 12-22-2015, 06:36 PM   #3130
xsnapshot
Fast enough
Drives: 2013 Subaru BRZ AT
My clamps did the same thing. Went from semi-tight to didnt-want-to-turn-anymore in just a few degrees of rotation. I forced it past that point after contemplating the situation for a bit and sure enough. It tightened down nicely. In my mind it should be a graduated curve of tightness, not a step function like behavior, but apparently these clamps have points where they can hang up as you tighten them.
xsnapshot is offline   Reply With Quote
Old 12-23-2015, 03:27 AM   #3131
Binary_fission
Drives: FRS
Anyone know if i have to tune ecu with custom tune. I have headers, front pipe and exhaust, no cats. I'm running carb tune that came with the kit. One of friends mentioned that I have to get custom tune with those mods otherwise it's bad for the car.
Honestly I don't want more hp or boost, im still gettin used to the car with its current set up, i just want to make sure car runs good and it won't have problems with those mods. Also future mods are lightweight pulleys, lightweight driveshaft, flywheel and clutch. Are those mods will require tune as well or nah?
Thanks
Old 12-23-2015, 01:07 PM   #3132
ApolloSki
Stealth
ApolloSki's Avatar
Drives: Ultramarine FR-S
Thanks
If you remove any cats, you need a custom tune.
ApolloSki is offline   Reply With Quote
The Following User Says Thank You to ApolloSki For This Useful Post:
Binary_fission (12-23-2015)
Old 12-23-2015, 01:26 PM   #3133
JDMChris
Drives: 2016
Send a message via AIM to JDMChris
Thanks
GET A TUNE NOW! CATASTROPHIC ENGINE DAMAGE MAY OCCUR!
JDMChris is offline   Reply With Quote
The Following User Says Thank You to JDMChris For This Useful Post:
Old 12-23-2015, 01:37 PM   #3134
Binary_fission
Drives: FRS
Got this message the other day and floor panel fell off.
But no for real Chris do I need to or carb tune is fine
BR-ZED (12-27-2016)
Old 12-23-2015, 01:41 PM   #3135
Rapiddan45
Rapiddan45's Avatar
Drives: 2013 FR-S M/T Ultramarine
Yes, you for real need a tune. The carb setup is strictly for a car that is stock+the supercharger.
2013 Ultramarine 6MT- Feal 441 coils, Whiteline 20mm front/18mm rear swaybars.
RPF1 17x9 +35. 245/40/17 RS-3 V2.
OFH, Invidia OP, Spencer Fab HFC FP, Invidia N1
C38 JRSC, JROC, Delicious Tune, Radium PCV Catch Can
Rapiddan45 is offline   Reply With Quote
The Following User Says Thank You to Rapiddan45 For This Useful Post:
Old 12-23-2015, 04:39 PM   #3136
JDMChris
Drives: 2016
You absolutely need a tune. The car will run lean if not, and will cause damage in time if not tuned.
Jackson Racing Rotrex Supercharger System Info and Discussion Jackson Racing Forced Induction 827 04-06-2020 04:56 PM
Jackson Racing Supercharger Press Release and Info CounterSpace Garage Forced Induction 110 01-03-2017 09:04 PM
jackson Racing engine oil cooler - modular to fit the Jackson Racing Supercharger! CSG Mike Forced Induction 24 04-27-2016 12:59 PM
Jackson Racing supercharger NoppyNop Forced Induction 241 06-26-2014 03:05 PM
Jackson Racing Supercharger Pre-Order Sale, $200 off! Xero-Limit Forced Induction 2 03-05-2014 04:14 PM
