Old 12-17-2015, 07:46 PM   #533
86fun
Drives: 2013 FRS
Originally Posted by Kodename47 View Post
Load the B01C as it's the most up-to-date compatible C series file.
That newer stock calibration seems smoother but not as much power, maybe it's doing some "learning" just after reflash? It's going to make the SC upgrade feel that much more!
86fun is offline   Reply With Quote
Old 12-18-2015, 11:46 AM   #534
toast
Drives: 14 BSP Edelbrock BRZ
In every drive by wire car I've owned doing a reset makes it feel sluggish, especially the throttle response. It's like the first few mm of pedal travel do nothing. Give it a day or so of driving. Definitely all of your learned parameters have been reset, so if you have 93 octane you will lose any timing advance the ECU had.
toast is offline   Reply With Quote
Old 12-18-2015, 01:26 PM   #535
86fun
Drives: 2013 FRS
This make sense, I suppose one aspect is that it needs to recalibrate all the sensors so it knows the sensor limits correctly.... during that time I'm sure it's preprogrammed with some very conservative values to ensure the safe running of the engine.
Old 12-18-2015, 01:51 PM   #536
BigFatFlip
sleep, drive, eat, repeat
BigFatFlip's Avatar
Drives: '13 BRZ, '12 Outback
To get this back on topic (this is the Edelbrock owners thread right?), you will feel the same "dead pedal" feeling after the ecu flash/SC install, so don't be too disappointed when you pull out of the shop/your driveway excited to do some pulls.
The Following User Says Thank You to BigFatFlip For This Useful Post:
CxG (12-18-2015)
Old 12-18-2015, 01:54 PM   #537
86fun
Drives: 2013 FRS
That's a really good point! I wonder how many people who have installed have faced this same thing and not understood and posted reviews based on that initial experience. I wonder how long I should drive it before dyno and other performance testing.
The Following User Says Thank You to 86fun For This Useful Post:
CxG (12-18-2015)
Old 12-18-2015, 10:36 PM   #538
BigFatFlip
BigFatFlip's Avatar
Oh you won't be disappointed. It will still pull hard, it just won't be as responsive initially.
Old 12-20-2015, 08:10 AM   #539
Paulo86
Paulo86's Avatar
Drives: Toyota GT86 euro version
Ok just some question, i will order mine mid-january.
Everyone seems to say "it feel like stock with more power", when i'm looking at the torque curve, i just can see that it will absolutely not fell like the great canyon torque dip.
There is some miles to do before go WOT after installing it ?
Some miles to do before having the full power from the supercharger ?
In straight line do you feel a real difference ? Ok it's not for what we bought the frs/gt86/brz but i can't understand how can you say that is not what you expect from this supercharger, maybe because you're living in the US and have lot of v8, v6 cars that pulls hard, and get you stucked in the seat ... but will it feel a little bit like that ?not that mutch of course...
The gt86 is my daily and i'm driving an AT. I'm living in Strasbourg and i go often to germany driving on the autobahn with no limit speed ^^
I've seen a german tuner with a sprintex supercharger hit the 170mph !!
I hope that i will feel what i see on the dyno results and that i will it some serious speed just for fun ^^
Paulo86 is offline   Reply With Quote
Old 12-20-2015, 11:35 AM   #540
shiumai
shiumai's Avatar
Drives: 2013 DGM BRZ, 2020 C8 Corvette
Absolutely yes. You can't not feel a difference. With an AT (which i have as well), you can't rev it up and launch it from a full stop, so at the low end of the revs (under 3000) it'll still feel almost stock. But once you get past that, it's a huge difference. If I'm cruising along and just do roll-ons, there's a big difference in acceleration. If I keep in the power band, then even more so.
shiumai is offline   Reply With Quote
The Following User Says Thank You to shiumai For This Useful Post:
Paulo86 (12-21-2015)
Old 12-20-2015, 12:15 PM   #541
BigFatFlip
BigFatFlip's Avatar
If you are asking about a "break-in" period similar to when the car is new, then no, there isn't one, you can go WOT right out of your driveway/shop. You will, on the other hand, have the same "dead pedal" as discussed earlier, but that is mainly due to the ECU flashing and having to relearn parameters and should go away after a few hundred miles of driving.
Old 12-20-2015, 02:31 PM   #542
Kodename47
Kodename47's Avatar
Drives: UK GT86
Or you just do the pedal/throttle learning before you start the car for the 1st time and then you don't get any dead pedal at all
.: Stealth 86 :.
Kodename 47 DJ:
The Following 2 Users Say Thank You to Kodename47 For This Useful Post:
BigFatFlip (12-20-2015), Paulo86 (12-21-2015)
Old 12-20-2015, 06:30 PM   #543
Paulo86
Paulo86's Avatar
Everything is answerd for me ! Thanks a lot guys !
Old 12-21-2015, 11:21 AM   #544
Paulo86
Paulo86's Avatar
i need to learn how to do that so ^^
Old 12-21-2015, 11:49 AM   #545
Porcupint
Drives: 13 GBS BRZ
Turn car on without starting the engine, fully press and release gas pedal 5 times, turn car off, turn on without starting again, press and release 5 times again, then start engine.
If I recall correctly.
Porcupint is offline   Reply With Quote
The Following 2 Users Say Thank You to Porcupint For This Useful Post:
KoreanJesus (12-04-2018), Paulo86 (12-21-2015)
Old 12-21-2015, 12:59 PM   #546
switchlanez
Glorious BRZ Master Race
switchlanez's Avatar
Drives: Subaru Libird
Yes, the dead pedal fix works. I've had to disconnect my battery on two occasions... once when I installed a CAI and another when I installed a steering wheel. Noticed sluggish throttle response, did the procedure I saw others posted about, and instantly felt better throttle response. Still curious if this is published anywhere by the OEM. Here's more detailed discussion: http://www.ft86club.com/forums/showthread.php?t=39480
Edelbrock E-Force Supercharger itsibarra Forced Induction 938 07-31-2021 04:48 PM
Most annoyingly over-asked questions on FT86 forums mit_peid Off-Topic Lounge [WARNING: NO POLITICS] 36 01-16-2014 02:48 PM
