Old 12-15-2015, 07:23 PM   #365
Summerwolf
Panda Trueno
Summerwolf's Avatar
Drives: No twin now.
I am really interested in these cams and what people truly gain.
Old 12-16-2015, 08:21 AM   #366
celek
Resident Gear Head
celek's Avatar
Originally Posted by solidONE View Post
They're going to swap the cams but not dyno the things.... ooookkkay
A lot of companies are hush hush on results, or do not bother reporting to the manufacture when using a product as they fine tune it. Unlike myself I will post numbers.
celek is offline   Reply With Quote
The Following 2 Users Say Thank You to celek For This Useful Post:
BatStig (12-16-2015), GT86_PRAGUE (12-17-2015)
Old 12-16-2015, 08:23 AM   #367
celek
Resident Gear Head
celek's Avatar
Originally Posted by Hyper4mance2k View Post
You should take that manifold and make a 4 barrel carb adapter.
Won't make as much power without the DI. Would lose the high end timing. Also not customizing the fuel pump setup for lower pressures.
Old 12-16-2015, 12:08 PM   #368
Tim Radley
Drives: None
I tried an early soft version and with other changes gained 25bhp.
Have got a hotter set to try but just not had time to fit them. I'll most likely wait until I fit a turbo to be fair as my time with the car is very limited.
Tim Radley is offline   Reply With Quote
The Following 3 Users Say Thank You to Tim Radley For This Useful Post:
BatStig (12-16-2015), celek (12-16-2015), solidONE (12-17-2015)
Old 12-16-2015, 01:18 PM   #369
sato
sato's Avatar
Drives: Dodge Patitas
Originally Posted by Spartarus View Post
Not that interference problem. Interference as in piston hitting valve during normal operation, necessitating a different piston design with more clearance. New pistons = more cash.
Other issues include losing much/most of your VVT adjustability range due to the same issue, again necessitating new pistons.
Thanks for the gentle reminder
Originally Posted by Summerwolf View Post
1059.58 currently for the set of four cams..... wow.
I know there are four cams instead of two, but wow
Sent using tapatalk
sato is offline   Reply With Quote
Old 12-16-2015, 01:57 PM   #370
DocWalt
DocWalt's Avatar
Drives: '22 BRZ
Seems like a reasonable price for cams IMO, especially if manufactured in a similar fashion to OEM with the hollow shafts and pressed on lobes.
The Following User Says Thank You to DocWalt For This Useful Post:
sato (12-16-2015)
Old 12-16-2015, 02:15 PM   #371
HUNTERANGEL121
HUNTERANGEL121's Avatar
Drives: Red Toaster(Dodge Nitro)
Sent using tapatalk
You're paying for four cams but if you them to each other it's the same size as one normal cam on an i4. That's how it works, right?
I mostly lurk, still don't own an 86...
HUNTERANGEL121 is offline   Reply With Quote
Old 12-16-2015, 06:37 PM   #372
Summerwolf
Panda Trueno
Summerwolf's Avatar
Pretty much, just two cylinders next to each other instead of four.
Unfortunately, coming from the "LSx" community.... 1000+ for cams is rediculous, lol.
Old 12-16-2015, 08:10 PM   #373
celek
Resident Gear Head
celek's Avatar
Much better option than HKS at $1800 though
The Following User Says Thank You to celek For This Useful Post:
Summerwolf (12-17-2015)
Old 12-17-2015, 04:43 PM   #374
solidONE
solidONE's Avatar
Drives: FR-S Whiteout
It would be nice to know how much gains yielded by the cams themselves. I've gained about 30whp on "other changes" with stock cams, so when you say +25bhp with cams and 'other mods' its not saying too much.
Intent > Content
Old 12-18-2015, 01:01 PM   #375
celek
Resident Gear Head
celek's Avatar
1. Brake Horse Power (bhp)
This is the power output of any engine measured at the engine's flywheel. (A flywheel is a disc with teeth on it. It's connected to the rear of the engine and its purpose is for the smooth transfer of power to the transmission from the engine.)
2. Wheel Horse Power
Unlike bhp, whp is the power output measured at the wheels. This is the information a dyno run provides and usually reads around *15 per cent less than the power measured at the engine (bhp) - this is because power is lost in the driveline (including clutch and transmission). *Four-wheel drive cars lose between 20-25 percent of their quoted bhp figure because of the increased friction.
Advanced info
The term brake horsepower (bhp) refers to a device called ‘Prony Brake’ (invented by Gaspard de Prony), which was used to measure engine power in the early 1900s. 2. You don't need to increase an engine's bhp to get an increase in a vehicle's whp. You can achieve higher whp by reducing the rotational mass in your drivetrain, such as the wheels, tyres, brakes, clutch, flywheel, etc.
In short BHP is an actual increase of output at the engine, whereas WHP can be changed not only by BHP but also mass reduction.
solidONE (12-18-2015)
Old 12-18-2015, 01:32 PM   #376
Gear_One_Performance
Gear_One_Performance's Avatar
Drives: 2014 BRZ SCCA STU endurance car
The other nice benefit is being able really ring the motor out without losing efficiency. Being able to stay in gear 1000 rpm longer than your competition is a nice plus.
Gear_One_Performance is offline   Reply With Quote
Old 12-18-2015, 10:48 PM   #377
solidONE
solidONE's Avatar
Advanced info
ORLY? lol
The WHP I yielded form "other changes" over baseline use the same or similar drive-line components. Same model clutch, flywheel, driveshaft, diff, halfshaft, hubs, studs etc. Tire and wheels were slightly different. 17x8 RPF1 with 225 tires for baseline, 17x9 RPF1 with 255 tires used when measuring WHP gained from (other mods). I'm sure if BHP was measured with the baseline and after my "other mods" on stock cams it would still be more than +25bhp.
Point is I'd like to see the gains from the cams alone, with all else the same or with only cams and tune being different.
Intent > Content
Old 12-19-2015, 03:03 AM   #378
jarnojvv
jarnojvv's Avatar
Drives: 86|Fortuner|FJ|Mustang|SwiftSport
Just a question: how does weight reduction increase whp? It surely only improves response and feeling. It would be interesting to see how much focused mods can reduce the driveline friction to increase the real whp.
-JvV-
jarnojvv is offline   Reply With Quote
2.3ltr, all motor, helpful, hks, hks stroker, informative, na brz
Beginner STX Build Whiteout FRS Build Thread Hachi86Roku Tracking / Autocross / HPDE / Drifting 21 03-31-2020 07:52 PM
Ultimate coilover thread, What do you run on your car? got REVIEWS post it up! THMotorsports.com Suspension | Chassis | Brakes -- Sponsored by 949 Racing 0 12-11-2013 05:25 PM
The *ULTIMATE* Exhaust Thread by ECS Motorsports! | Over 2 Dozen Options! + FREE S&H! AJ@ECSMotorsports Engine, Exhaust, Bolt-Ons 27 09-05-2013 09:14 AM
*--->>ULTIMATE COILOVER THREAD<<---* The Best Deals + Free Shipping FT-86 SpeedFactory Brakes, Suspension, Chassis 95 01-30-2013 07:48 PM
Who's in for the long haul? Laika BRZ First-Gen (2012+) — General Topics 47 07-09-2012 09:48 AM
