Old 12-15-2015, 09:11 AM   #351
Spartarus
...Just add nauseum
Spartarus's Avatar
Drives: 2003 (AP1) S2000
Originally Posted by sato View Post
But don't we have chains instead of belts for timing? Maybe a noob like me can't think of interference screwing up something else (please elaborate)
Sent using tapatalk
Not that interference problem. Interference as in piston hitting valve during normal operation, necessitating a different piston design with more clearance. New pistons = more cash.
Other issues include losing much/most of your VVT adjustability range due to the same issue, again necessitating new pistons.
There are many ways to displace.
-Spartarus
Spartarus is offline   Reply With Quote
The Following 2 Users Say Thank You to Spartarus For This Useful Post:
sato (12-16-2015), Summerwolf (12-15-2015)
Old 12-15-2015, 09:43 AM   #352
Summerwolf
Panda Trueno
Summerwolf's Avatar
Drives: No twin now.
There will be a steep learning curve with VVT and those cams, but I'm glad someone is bringing an "affordable" cam option to market. Also with a cam upgrade there can be more progress made in the FI arena as well, suiting cams to your power adder since they say custom grinds are available. The base minimum for those cams are bigger than stock so you would have to lose a portion of idle quality and general drivability but with tuning obviously that can be controlled to an extent.
Now I know we have custom piston options for Piston to valve clearance, but do we many options for better valves, retainers and valve springs to take advantage of those cams?
Old 12-15-2015, 09:45 AM   #353
Summerwolf
Panda Trueno
Summerwolf's Avatar
1059.58 currently for the set of four cams..... wow.
Old 12-15-2015, 10:09 AM   #354
Gear_One_Performance
Gear_One_Performance's Avatar
Drives: 2014 BRZ SCCA STU endurance car
Making power NA is always so much more expensive, but much more satisfying.
Gear_One_Performance is offline   Reply With Quote
The Following User Says Thank You to Gear_One_Performance For This Useful Post:
celek (12-15-2015)
Old 12-15-2015, 10:21 AM   #355
Summerwolf
Panda Trueno
Summerwolf's Avatar
Serious question, has anyone tuned with bigger camshafts in the FA20 yet? I did some google work and didn't find anything. The custom cam profiles caveat is interesting.
Old 12-15-2015, 03:35 PM   #356
celek
Resident Gear Head
celek's Avatar
Piper has Springs and retainers as well as a few other companies. the problem area is coil bind if the springs do not support the larger lobe as well.
High RPM is going to need a higher spring pressure as well for High RPM and valve float.
celek is offline   Reply With Quote
The Following User Says Thank You to celek For This Useful Post:
Old 12-15-2015, 03:36 PM   #357
celek
Resident Gear Head
celek's Avatar
Someone on my FB build page commented they had the 272's @Tim Radley has the street cams.
No one has released any gain numbers though.
Old 12-15-2015, 04:58 PM   #358
solidONE
solidONE's Avatar
Drives: FR-S Whiteout
They're going to swap the cams but not dyno the things.... ooookkkay
Intent > Content
The Following User Says Thank You to solidONE For This Useful Post:
Old 12-15-2015, 06:24 PM   #359
Hyper4mance2k
Alexandrino_Auto
Hyper4mance2k's Avatar
Drives: series.Blue
You should take that manifold and make a 4 barrel carb adapter.
Hyper4mance2k is offline   Reply With Quote
The Following User Says Thank You to Hyper4mance2k For This Useful Post:
86kahl (12-22-2015)
Old 12-15-2015, 07:23 PM   #360
Summerwolf
Panda Trueno
Summerwolf's Avatar
I am really interested in these cams and what people truly gain.
Old 12-16-2015, 08:21 AM   #361
celek
Resident Gear Head
celek's Avatar
A lot of companies are hush hush on results, or do not bother reporting to the manufacture when using a product as they fine tune it. Unlike myself I will post numbers.
The Following 2 Users Say Thank You to celek For This Useful Post:
BatStig (12-16-2015), GT86_PRAGUE (12-17-2015)
Old 12-16-2015, 08:23 AM   #362
celek
Resident Gear Head
celek's Avatar
Won't make as much power without the DI. Would lose the high end timing. Also not customizing the fuel pump setup for lower pressures.
Old 12-16-2015, 01:18 PM   #363
sato
sato's Avatar
Drives: Dodge Patitas
Thanks for the gentle reminder
I know there are four cams instead of two, but wow
Sent using tapatalk
sato is offline   Reply With Quote
Old 12-16-2015, 01:57 PM   #364
DocWalt
DocWalt's Avatar
Drives: '22 BRZ
Seems like a reasonable price for cams IMO, especially if manufactured in a similar fashion to OEM with the hollow shafts and pressed on lobes.
The Following User Says Thank You to DocWalt For This Useful Post:
sato (12-16-2015)
2.3ltr, all motor, helpful, hks, hks stroker, informative, na brz
Beginner STX Build Whiteout FRS Build Thread Hachi86Roku Tracking / Autocross / HPDE / Drifting 21 03-31-2020 07:52 PM
Ultimate coilover thread, What do you run on your car? got REVIEWS post it up! THMotorsports.com Suspension | Chassis | Brakes -- Sponsored by 949 Racing 0 12-11-2013 05:25 PM
The *ULTIMATE* Exhaust Thread by ECS Motorsports! | Over 2 Dozen Options! + FREE S&H! AJ@ECSMotorsports Engine, Exhaust, Bolt-Ons 27 09-05-2013 09:14 AM
*--->>ULTIMATE COILOVER THREAD<<---* The Best Deals + Free Shipping FT-86 SpeedFactory Brakes, Suspension, Chassis 95 01-30-2013 07:48 PM
Who's in for the long haul? Laika BRZ First-Gen (2012+) — General Topics 47 07-09-2012 09:48 AM
