Old 12-18-2015, 12:22 PM   #617
ButeraFRS
Guest
Posts: n/a
I redid it and I'm getting mid 60s now.
The Following User Says Thank You to For This Useful Post:
EAGLE5 (12-18-2015)
Old 12-18-2015, 12:40 PM   #618
Vladimir Tutin
Vladimir Tutin's Avatar
Drives: '13 Hot-Lava FR-S
Run Prime95 and stress test your CPU. See what temps you get from that.
Vladimir Tutin is offline   Reply With Quote
Old 12-18-2015, 12:56 PM   #619
fumanchu1
Drives: 2013 Brz C38 (bought not built :P)
Do not run prime 95, that program is complete shit now. For the last several years they have been changing it so that it causes more stress(every update) to a point where running it is so demanding(latest version) that a very stable build/oc may overheat or be unstable when running prime 95 as it is just too demanding and really is too much overkill. So much so that it can no longer be used to determine stability efficiently and can even damage a perfectly working non overclocked cpu (ask me how I know).
If you decide to get prime 95 do a bit of research and you'll quickly find a consensus on when the last decent/acceptable version of it was. There are also several better suited alternatives these days (unfortunately I can't remember their names and they are on my desktop at home so I can't look them up atm)
fumanchu1 is offline   Reply With Quote
Old 12-18-2015, 01:00 PM   #620
fumanchu1
Originally Posted by ButeraFRS View Post
I'm getting CPU temps of 70 on r6 siege on ultra settings. Running a cool master evo 212, Intel i7 4790k and a msi 970
Is this good, bad or normal?
70c is fine for cpu temp under full load, could be lower but that could also only be the type of cpu you are running. I see it's a haswell i7 so yeah your temps are pretty normal, you could probably get slightly lower temps but haswell's are well known to run up to 80c.
Reason for this is that intel stopped using solder between the lid and processor and now just use thermal paste which is not able to xfer the heat as well resulting in higher cpu temperatures. You can delid the cpu but at the temps you are running I see little to no point.
In a few years if your temps start to raise gradually then you may want to consider it (the paste will dry and be even less effective as dissipating heat)
Old 12-18-2015, 01:02 PM   #621
fumanchu1
No just no, I have a fully stable non overclocked 4670k and running prime 95 cause my cpu to heat up to the throttling and emergency shut off temp within 10 minutes, it has now become way too over the top with it's stress test that it is no longer reliable to determine real world conditions.
Old 12-18-2015, 01:22 PM   #622
Vladimir Tutin
That's because the newer versions use adaptive voltage if I remember correctly. I should have stated but forgot, use version 26.6.
Aida64 is a good alternative though.
The Following User Says Thank You to Vladimir Tutin For This Useful Post:
fumanchu1 (12-18-2015)
Old 12-18-2015, 03:04 PM   #623
Icanfaptothis86
tickle fight referee
Icanfaptothis86's Avatar
Drives: 2015 Subaru BRZ
awesome username ... respekt
Celery man
Electrical space wizard
Icanfaptothis86 is offline   Reply With Quote
The Following User Says Thank You to Icanfaptothis86 For This Useful Post:
Vladimir Tutin (12-18-2015)
Old 12-18-2015, 03:11 PM   #624
fumanchu1
Yeah didn't want to can your suggestion but I couldn't remember off hand what the problem with recent versions were. I agree aida 64 is great, prime 95 pre v26.6 would be goo also
Old 12-18-2015, 03:38 PM   #625
ButeraFRS
Guest
Posts: n/a
I'm trying a new exhaust fan. I was using a bitfenix spectre and I could barely feel it blow air out. I got a cool master 120 red led fan with an rpm of 2k and so far it's keeping everything a lot cooler. I might upgrade the spectre intakes on this case to the same fan because I'm liking it so far.
It's louder, but it's definitely doing its job and I don't really care for noise I usually have headphones on anywau
Old 12-18-2015, 03:53 PM   #626
Vladimir Tutin
Get Noctua fans if you want performance and for them to be quiet.
My personal experience with Spectres were great. My old build had a 3770k OCed to 4.4Ghz and was cooled with EVGA Superclock CPU cooler and a bitfenx spectre fan. Under load I wouldn't go over 65c.
Old 12-18-2015, 04:09 PM   #627
ButeraFRS
Guest
Posts: n/a
I had 3 spectres and I couldn't even feel them blowing any air. This one though I feel the punch from it and I haven't gone over 65 under load. I think if I get new intake fans I'll be at 60 under load.
Does thermal paste have a break in time by any chance?
Old 12-18-2015, 04:50 PM   #628
Vladimir Tutin
It depends on the brand. Artic Silver 5 claims 200 hours which will result in a 2-5c degree drop. Pastes like Noctua NT-H1 don't have one.
Old 12-18-2015, 05:12 PM   #629
EAGLE5
Dismember
EAGLE5's Avatar
Drives: 2013 Red Scion FR-S
Damn, overclocking has gotten weird since the days of the 300a. Thermal paste break-in? Just shoot me.
Yes, the CPU gets throttled some before 90c. More specifically Turbo Boost doesn't run as much as temperatures go up. I think you start losing performance around 40-50C with the big drop happening around 90C. I think 90C is when the base CPU speed is throttled too.
Old 12-18-2015, 05:13 PM   #630
DylanFRS
Lost in Kansas
DylanFRS's Avatar
Drives: 2013 Scion FRS (Raven)
I used arctic silver and it definitely has had a break-in time. Seems like it still is in fact.
DylanFRS is offline   Reply With Quote
pc master race, u no have 3080
gamers lounge Touge_ninja Off-Topic Lounge [WARNING: NO POLITICS] 25 01-21-2014 05:32 PM
GT Acadamy Gamers Banned from Britsh GT Pro-Am WingsofWar Off-Topic Lounge [WARNING: NO POLITICS] 16 02-11-2013 07:37 PM
