#211 | |
| The Following User Says Thank You to JDMChris For This Useful Post: | CSG Mike (12-17-2015) |
#213 |
Drives: 2013 FR-S M/T Ultramarine
2013 Ultramarine 6MT- Feal 441 coils, Whiteline 20mm front/18mm rear swaybars.
RPF1 17x9 +35. 245/40/17 RS-3 V2. OFH, Invidia OP, Spencer Fab HFC FP, Invidia N1 C38 JRSC, JROC, Delicious Tune, Radium PCV Catch Can |
#214 | |
Drives: 2013 FRS / 2013 427 Vert
What would be the purpose for using this?
[SIGPIC][/SIGPIC]
2013 FR-S Asphalt BC Coils/Rev Works UEL header/HKS Front Pipe/Racing Brake BBK/Shorai LW Battery/ACT 6 Puck Clutch/FBM Radiator & Oil Pan/JR Oil Cooler/Jackson Racing High Boost C30/Rev Works Built Motor 2016 Audi TTS APR Tuned |
#215 |
#216 | |
Drives: '23 BRZ Limited
A double whammy. |
#217 |
#218 | |
The High Boost pulley should only be used if you have 93 octane, race fuel, or ethanol readily available to you. We do not recommend it for 91. |
#220 | |
Thanks for supporting CSG! |
| The Following User Says Thank You to CSG Mike For This Useful Post: | dj2020 (12-19-2015) |
#221 |
Drives: frs
Hey I have the delicious 11psi MAP sensor. Would this need upgraded if one got the new high boost pulley?
#223 |
Drives: Subaru BRZ / Toyota 86 Experts
| The Following User Says Thank You to CounterSpace Garage For This Useful Post: | twag4 (12-23-2015) |
#224 |
Drives: 2014 BRZ
When will the CSG site have the upgrade kits you mentioned earlier?
| Jackson Racing Supercharger Press Release and Info | CounterSpace Garage | Forced Induction | 110 | 01-03-2017 10:04 PM |
| jackson Racing engine oil cooler - modular to fit the Jackson Racing Supercharger! | CSG Mike | Forced Induction | 24 | 04-27-2016 01:59 PM |
| Jackson Racing BRZ | Parikh1234 | Member's Car Journals | 31 | 12-29-2015 10:26 AM |
| Why no high rpm boost for Phantom ESC? | stevo585 | Forced Induction | 11 | 02-11-2014 08:51 PM |
| Jackson Racing FR-S | Unleashed | FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum | 3 | 11-18-2012 03:29 PM |
