Old 12-17-2015, 03:53 AM   #15
ru-x
Drives: brz
everything is closed.
ru-x is offline   Reply With Quote
Old 12-17-2015, 05:06 AM   #16
FRSBRZGT86FAN
FRSBRZGT86FAN's Avatar
I believe a dealer visit is in order then.
The Following User Says Thank You to FRSBRZGT86FAN For This Useful Post:
ru-x (12-17-2015)
Old 12-17-2015, 08:27 AM   #17
stevesnj
stevesnj's Avatar
Press the key fob a second time. My 2016 does exactly this then I press the button a second time. Lights off
My 2016 Build thread
Old 12-18-2015, 08:56 AM   #18
PandaSPUR
PandaPandaPandaPandaPanda
PandaSPUR's Avatar
Drives: 2015 BRZ Limited CWP
Came here to say this ^
Do you press the button twice or only once? My 2015 takes a double click of the lock button to shut off the lights.
Wondering if all these things are just firmware differences across diff years.
Old 12-18-2015, 08:58 AM   #19
vroom4
My 2014 is the same, headlights stay on forever it seems like if I don't hit it twice.
Kind of akward when you pull up to someone's house and the bright HId are shining through their windows
vroom4 is offline   Reply With Quote
Old 12-18-2015, 10:41 AM   #20
stevesnj
stevesnj's Avatar
Its a courtesy light for like walking to your door at night sort of thing.
Old 12-18-2015, 02:09 PM   #21
PandaSPUR
PandaSPUR's Avatar
Kinda what I figured. I always have friends reminding me that I left my lights on though. And I've had valets manually turn off the lights, and then my dumb ass drives around for 5 minutes at night with no headlights before realizing theyre off.
Old 12-18-2015, 02:45 PM   #22
xFury
xFury's Avatar
Drives: '16 Scion FR-S - Oceanic
'16 model with auto lights. Turns off after about 30 seconds, or I can press the lock key twice and it turns off right away.
xFury is offline   Reply With Quote
Old 12-21-2015, 05:11 AM   #23
ru-x
Drives: brz
alright guys. I think i solved the mystery. I noticed that the window isn't auto moving up and down when i'm opening and closing the door...thus the car thinks the door is always closed. That would explain the lack of beeps when i turn off the car or when i have headlights on when the door is open while the engine is off. I'll play around thing and stuff when i get out there tomorrow.
Old 12-21-2015, 09:24 AM   #24
Kaotic Lazagna
Drives: GR Corolla
Check if the door plunger is stuck.
Old 12-23-2015, 07:16 AM   #25
ailikesiliu
Drives: はちろく
almost 100% that is the problem.
ailikesiliu is offline   Reply With Quote
Old 12-23-2015, 09:16 AM   #26
shaynek
shaynek's Avatar
Drives: BRZ Limited; GR86
yea you have to hit the lock button 2 times
shaynek is offline   Reply With Quote
Old 12-24-2015, 02:04 PM   #27
ru-x
Drives: brz
yup, the door switch isn't stuck, but is faulty. it will be replaced. thankyou all for playing!
How to turn BRZ Headlight LED into DRL Lithium DIY (Do-It-Yourself) Guides 184 12-03-2017 01:57 AM
Right headlight wont turn on Matt90 Issues | Warranty | Recalls / TSB 9 11-11-2013 03:56 PM
Passenger Door Courtesy Light Wont Turn Off zex Issues | Warranty | Recalls / TSB 12 10-04-2013 01:31 PM
Does the Toyota Corolla keyfob cover fit the FRS keyfob? FRSHunter Cosmetic Modification (Interior/Exterior/Lighting) 6 07-25-2013 05:04 PM
