#225 | |
Drives: Sterling BRZ Ltd
Just for clarification, your edit when you say 100%. Does that mean your math is for 100% nitrous in the cylinder? This just reads like your saying running nitrous is the same as running 22psi, don't want people to get the wrong idea. I'm pro nitrous, ever since 2001 there has been a severe misunderstanding out there, and yes my car is boosted as well.
#226 |
Drives: FRS,09 370z, 00 CelicaGT-S, 85 300Z
I thought I read that someone in this tread was done?
Can we be done? |
| The Following 2 Users Say Thank You to clayrush For This Useful Post: | SkAsphalt (12-17-2015), Sportsguy83 (12-16-2015) |
#227 |
I think next up is to discuss who is having what for breakfast, this has come so far from the original post
| The Following 4 Users Say Thank You to mrk1 For This Useful Post: |
#228 | |
Drives: 370z
#229 | |
#230 | |
Drives: '15 FRS
#231 |
Road-hole
Drives: 2013 Whiteout FR-S
I was happy just eating my popcorn until this post...
I'm afraid you fail in the logic department...
Failed rods being a fact does NOT logically support your argument that the rods are too weak...It merely supports that rods can fail under boost...There is NO inference of causality there at all... Jaden p.s. this was a quote of FRS Justin saying this/ Per Webster dictionary Definition of fact 1 : something that really exists or has occurred <Space travel is now a fact.> EX. People running high boost have broken rods is now a fact 2 : a true piece of information <“I just know for a fact that she has a huge family to feed!” — Kenneth Grahame, The Wind in the Willows EX. I just know for a fact people have broken rods under high boost. If you can't see it now I can't help you / but the quote button didn't work... |
#232 | |
Road-hole
lol...
UMMM, in direct injection applications fuel pressures can be 1000 bar... does that mean they are F/I?>??lol Jaden |
#233 | |
Road-hole
the stupid is strong in this one...
You are not changing the pressure of the air charge which is necessary for it to be considered F/I, it is the exact same as ambient pressure (just with a richer O2 content because of it's chemical composition). It isn't all motor, which is what you seem to be confusing with F/I vs. N/A... There's a reason people use the term all motor rather than N/A... Jaden |
| The Following User Says Thank You to Jaden For This Useful Post: | CSG Mike (12-17-2015) |
#234 | |||
Drives: 370z
Rods will eventually fail as you increase cylinder pressure * rod temperature. So if you want to run ___ boost, and that brakes the rods, then your rods were too weak for your application. Quote:
Fuel is on the OTHER side of the equation. Car motors are limited by the oxygen. If you inject pure 02 straight into the cylinder instead of N2O, then I would argue that's basically FI. Quote:
I understand CSG Mike is a stand up guy, a pillar of this community, and a wickedly fast driver, but that doesn't mean everyone needs to gang up on the OP. Especially if they can't do it civilly. |
#235 | |
Road-hole
no words mean something...
Rods fail N/A too. The argument that boost exists, rods fail, therefore rods are too weak is flawed logic... You're skipping a step for one thing which would be therefore rods fail because boost, but even THAT is invalid logic. Even if you could show that rods fail ONLY when boosted, it wouldn't show that the rods are too weak, because then the argument would have to be, some rods fail when boosted, the rods that failed only failed when boosted, therefore rods are weak.... still fail of logic. So, the whole premise of the op is a fail of logic. IF he had said, hey if you're planning on F/I, you may want to get different rods because some rods have failed. Then he wouldn't be getting jumped on. But to come on and say "Hey all you people need to shut up about tunes, it's the rods that suck", he should expect to get bashed a little. As far as N/A vs. F/I. There really is no debate to be had. Words MEAN something. Forced induction doesn't mean adding more O2 content. It means forcing more air than 1 bar, whatever bar is at the elevation you're at. So, NO, N2O is NOT F/I. It is not ever adding more than 1 bar of pressure to the combustion chamber. Jaden |
| The Following User Says Thank You to Jaden For This Useful Post: | Dimman (12-18-2015) |
#236 | |
Drives: 370z
Ughhhhhhhhhhhh, I really really, REALLLLLYYYYYY hate arguing with you, because I take the time and effort to research my posts, try to make it as straight forward as possible, and then you always reply in like 10 seconds with the most off-the-wall stuff that I don't know what to say. When I get too annoyed to post you take it as your victory. What annoys me too is that I know there are many people, many well known people, here that bashed the OP in how he said it, and are reading this thread, but who agree that boost could use beefier rods, and who know you are spewing ridiculous nonsensical crap, but who won't call you out on it because you are on "their" side. I hope one of them comes and tries to convince you of things, because you never listen to me. If no one does, I guess I will eventually, but I feel like I will be repeating myself. please re-read this post: http://www.ft86club.com/forums/showp...&postcount=141 I re-read this thread from the beginning, and it is actually starting to really piss me off. I have a theory why this thread went the way it did, and why it made some people super salty, and why some people just want it to disappear, but I don't want to say it because I don't want to piss people off or call people out. |
| The Following 2 Users Say Thank You to totopo For This Useful Post: | FRS Justin (12-18-2015), orangespark (12-17-2015) |
#237 | |
Road-hole
I read that post of yours the first time I read it and there's nothing wrong....
With what you said in it. Yes, the more power you create, the more stresses involved and the greater likelihood of catastrophic failure...we get it. You're still not addressing the points made. rod failure does NOT necessarily infer an inherent weakness of the rods, nor does it mean that at a given power level they will fail. That IS what the op stated. I'm sorry but it is. He said, people need to shut up about the tunes and understand that any F/I needs upgraded rods because they are too weak. Well, that hasn't meted out in a majority of cases. So he got called out on it. Should you upgrade your rods in F/I on a FA20? absolutely. If you're planning on getting the most out of your engine upgrade the rods, get forged pistons, slightly lower the C/R...etc... Is there a greater risk involved in using F/I with stock internals? Yes.. There's a greater risk using stock internals with an E85 tune, or a stage II 93 tune for that matter. Should everyone fore go making sure they get a good tune and upgrade their internals if they're going F/I? NO, it's been proven in many cases to not be necessary even beyond 300 whp. Should they go into it with their eyes shut thinking they're going to get 100K miles out of a used motor after running 15+ psi of boost at 450 whp on E85? Absolutely not, and anyone who does that is a fool who SHOULD be parted from the money he's going to have to spend to replace his shit. I'll tell you one thing that I DO know...A bad tune will cause catastrophic failure a lot sooner than a good tune on E85 at 350WHP will because of stock rods... Jaden p.s. I don't think the twins are the best cars ever... I DO think that they are the best bang for your buck new car for DIY tuners that want high performance newer cars for the least amount of money and the most elbow grease... |
#238 | |
Drives: White Frs AT
Our shop mechanic at work has a 328 (Twin turbo) currently and has been boosting up the turbo compression on his engine for quite a while. He feels very safe doing it on stock. That engine was designed to be F/I. What I'm trying to say is, whoever is working on pushing the boundaries CSG_Mike, etc. Props to you guys. In terms of learning, this forums is awesome. But as my only car, I don't i'll be able to go F/I on this car. Critical info provided by Justin is useful. Also, I was reading someone else's thread and he dissected the FA20 and found the build quality sub-par. Lots of sharp edges, etc. Not sure if that ties into this. |
| Tags |
| kill brain cells, not facts |
| FlexFuel and Facts | Shiv@Openflash | Software Tuning | 74 | 05-07-2025 04:28 AM |
| Anyone Else? Hearters Blowing when off. | Kiske | Issues | Warranty | Recalls / TSB | 7 | 04-09-2014 05:22 PM |
| How cold is your a/c blowing? | jermyzy | Issues | Warranty | Recalls / TSB | 68 | 08-18-2013 03:29 PM |
| Supra Blowing Up | radroach | Off-Topic Lounge [WARNING: NO POLITICS] | 2 | 07-21-2013 09:14 PM |
| Facts you may or may not know about your GT86/BRZ/FR-s | FiRStsc10n | Scion FR-S / Toyota 86 GT86 General Forum | 41 | 07-09-2013 03:05 PM |
