| View Poll Results: Have you had any major issues | |||
| Yes |
13 | 10.92% |
| No |
102 | 85.71% |
| Yes, but they are related to somthing I did (i.e. aftermarket parts) |
4 | 3.36% |
| Voters: 119. You may not vote on this poll | |||
#44 |
Drives: '21 Civic Type R
Car's So Good I Bought It Twice
Got an FRS June 2012
![]() After a year I sold it and used the the money I got as a downpayment on a red BRZ Limited. I just hit 33,400 miles driving to work today, and my one major problem with the car is that it still doesn't have a goddamn snail under the hood. Which I'll be fixing Soon™.
"Give a man a match and he'll be warm for a minute. Light a man on fire and he'll be warm for the rest of his life."
Follow me on Instagram! |
| The Following User Says Thank You to Gaiakai For This Useful Post: | go_a_way1 (12-16-2015) |
#45 |
Drives: 2005 Toyota Camry
| The Following 2 Users Say Thank You to mav1178 For This Useful Post: | FRSBRZGT86FAN (12-16-2015), go_a_way1 (12-16-2015) |
#46 |
too much is never enough.
Drives: 2015 FR-S RS1.0, 2005 Corolla XRS
12,500 and NO issues at all!
This warm weather is making me want to take it out of storage. grrrrrrrr
Too much is never enough.......
2016 Colorado Z71 Trailboss, 2005 Corolla XRS, 1987 Cavalier RS Wagon ![]() Nanako's Mod Thread |
#47 | |
Not Bаnned Anymore
Drives: Heavily Modified FRS
#48 | |
![]() ![]() ![]() ![]() ![]() :popc orn:![]() ![]()
| The Following User Says Thank You to Tcoat For This Useful Post: | go_a_way1 (12-16-2015) |
#49 |
Not Bаnned Anymore
#50 | |
Not Bаnned Anymore
| The Following User Says Thank You to go_a_way1 For This Useful Post: | humfrz (12-16-2015) |
#51 |
I'm gonna add to this I only have 4500 miles and so far the issues have been:
1) The AT downshift issue that plagues the 2015 with hard shifts brought it in at 400 miles to a dealer and they didn't do crap and said they would send there info to toyota, took until 4000 miles at the first oil change for a TSB to be applied to fix it Fuel Pump chirp (non issue) Issues essentially caused by me: Front passenger side had a flat tire, a nail was found in the inner sidewall Uber thin paint, my trunk has slight scratches from a tree branch falling on it as well as a barely noticeable scratch on my drivers mirror cap that I'm 90% was from someone brushing against it Front bumper doesn't fit right below the headlight, put it back on in a hurry after installing winjets and I'm waiting on new push pins to replace ones damaged from installing win-jets
#52 |
My 2016 Build thread TRD Exhaust with custom quad tips, TRD Lowering Springs,TRD Quick shifter,LED;DRL, Projectors, and turn signals. Re-badge, 86 Nanny, WinmaxW2 Pads, K&N Drop In, Antenna delete |
| The Following User Says Thank You to stevesnj For This Useful Post: | go_a_way1 (12-17-2015) |
#53 | |
Drives: 2013 SWP BRZ
I bought my BRZ used, someone had previously set a password (prev owner said he hadn't but who else would?) Anyway, I disconnected the battery one day while installing my catch can and when I started the car back up, the HU needed a password to do literally anything other than power up. Did a little internet research, loaded a program onto a microSD and used it to find what password had been set, which let me unlock the thing and reset the password. I still have the files if this is the problem you have with your HU. |
#54 | |
Drives: car
#55 |
No major issues for me so far (23k miles, 20+ track days). List of smaller issues I've had:
- CEL/idle issue. Resolved early on with dealer reflash. - Touchy passenger one-touch window switch. Could have fixed under warranty but it doesn't bother me enough. - Fuel pump chirps. Don't really notice them. - Coil pack failure. Annoying, but happened after numerous track days so I'm not complaining. Relatively easy to fix. - Melted brake piston dust seals. To be expected with track time. Given the amount of abuse this car has seen, I'm pretty happy with its durability. I do change out the fluids pretty often and am using an oil cooler. I will also be upgrading to BBK and hopefully decreasing brake temps. So far so good.
2022 BRZ Build 2013 FR-S Build |
#56 |
Drives: car
Today it sounded like my dash was falling apart, every bump in the road resulted in a squeak or rattle from it.
Also the valvetrain noise can be a little chattery this time of year. |
| The South African Feel Good Thread | Fish Eagle | AFRICA | 666 | 06-16-2018 02:18 PM |
| Anybody know of a mechanic good with thread repairs? | ft86Fan | NY / NJ / CT / PA | 0 | 01-14-2014 07:43 PM |
| Checking in | slicktop | Scion FR-S / Toyota 86 GT86 General Forum | 0 | 05-15-2013 08:55 PM |
| Just checking in | Jaylyons1 | Mid-Atlantic | 1 | 12-02-2012 01:36 PM |
| Checking out your own car | Bu-Tang | Scion FR-S / Toyota 86 GT86 General Forum | 18 | 06-11-2012 10:41 PM |
