#211 |
Drives: Sterling BRZ Ltd
Yes when I wrote 33% i was referring to volume sorry I didnt specify, by weight its 36%
To cite my source, Nitrous Oxide High-Performance Manual by Trevor Langfield. Trevor owns the UK based Wizard of NOS company.
#212 |
Not Bаnned Anymore
Drives: Heavily Modified FRS
BRB getting more popcorn
| The Following User Says Thank You to go_a_way1 For This Useful Post: | Rapiddan45 (12-16-2015) |
#214 |
Not Bаnned Anymore
Don't worry I got lots
#215 | |
Drives: blue - Cosworth SC stage 3.0
if you use a 0.5 to 4.5V power supply and feed it into the rear O2 sensor plug and then assign a custom map to apply an offset to the parameter you want say spark timing with 0.5V its -10 degrees and 4.5V its + 10 degrees fro example then its case of turning the power supply up and down to offset your spark and then use the mode switch to assign other parameters to your rear o2 so you can use it to map cam timign, gdi timing etc |
#216 | |
Drives: 2013 Asphalt FRS
Edit: The weight of the molecules will change according to temperature and state of molecules. (Gas vs Liquid) Source Purdue University chemistry dept.
Instagram FT86PROJECT9S
Facebook FT86PROJECT9S 710whp Last edited by FRS Justin; 12-16-2015 at 06:15 PM. |
#217 | |
Drives: 2013 DGM BRZ, 2020 C8 Corvette
http://www.noswizard.com/nos-technic..._nitrous_oxide
My DGM BRZ vid: https://www.youtube.com/watch?v=0OL9OhxexAA
My car journal thread: http://www.ft86club.com/forums/showthread.php?t=43402 |
#218 | |
Nitrous itself is 33% oxygen by molarity, or 36% oxygen by mass. Thing is, you can't displace all atmospheric air with N2O. |
| The Following User Says Thank You to CSG Mike For This Useful Post: | FRS Justin (12-16-2015) |
#219 |
Drives: 2013 Ultramarine FR-S
If nothing else I'm learning a shit ton about nitrous
| The Following 4 Users Say Thank You to Freeman For This Useful Post: |
#220 |
Not Bаnned Anymore
+1 to that and that!
#221 |
I agree 100% but whatever is replaced will have a higher o2 content and still raise the cylinder charge o2 percentage in the given volume.
Facebook FT86PROJECT9S 710whp |
#222 | |
Drives: 370z
So let's say you ran on 1 atm of pressure of PURE NOSS!!!!Z!!11! (/s). In effect, since each mole of N20 dissociates into half a mole of 02, that would equate to 50% atm partial pressure of 02. So depending on your mixture of air vs N20 it would be somewhere between 20 and 50% effective 02. edit (because math is fun!!!): 100% N2O would be 7.35 PSI of O2. To get that much with FI, given 20% of O2 in air you would need 2.5 atm worth of air, so an extra 1.5 atm of boost, which equals 22 PSI of boost!!!! just from the oxygen alone! |
| The Following User Says Thank You to totopo For This Useful Post: | FRS Justin (12-16-2015) |
#223 | |
#224 |
Drives: 22RE, FA20, 4G63
| Tags |
| kill brain cells, not facts |
| FlexFuel and Facts | Shiv@Openflash | Software Tuning | 74 | 05-07-2025 04:28 AM |
| Anyone Else? Hearters Blowing when off. | Kiske | Issues | Warranty | Recalls / TSB | 7 | 04-09-2014 05:22 PM |
| How cold is your a/c blowing? | jermyzy | Issues | Warranty | Recalls / TSB | 68 | 08-18-2013 03:29 PM |
| Supra Blowing Up | radroach | Off-Topic Lounge [WARNING: NO POLITICS] | 2 | 07-21-2013 09:14 PM |
| Facts you may or may not know about your GT86/BRZ/FR-s | FiRStsc10n | Scion FR-S / Toyota 86 GT86 General Forum | 41 | 07-09-2013 03:05 PM |
