Old 12-16-2015, 10:49 AM   #575
twag4
Drives: frs
Originally Posted by bfrank1972 View Post
Try driving a winter up north
No thanks! But they are stainless, they have been through some biblical rain storms. I am a transplant from Oklahoma, don't miss winters at all..!
twag4 is offline   Reply With Quote
The Following User Says Thank You to twag4 For This Useful Post:
bfrank1972 (12-16-2015)
Old 12-16-2015, 12:30 PM   #576
FrX
Drives: 2013 Scion FR-S, 1993 Lexus SC300
Originally Posted by twag4 View Post
Just wanted to show you how good these look after a month and a half of use. Very pretty still...
Did you drill out the header/overpipe connection for new hardware? It looks like yours uses nuts/bolts. Mine came with studs and nuts, like a turbo header.
FrX is offline   Reply With Quote
Old 12-16-2015, 01:15 PM   #577
twag4
Drives: frs
No drilling. I didn't use the studs, those are just bolts. I put the nuts on the back with lock washers to help keep the bolts from backing out. It is an old technique from the old muscle car days. The bolts are threaded and tightened into the threads on the flange, then the nuts tightened on back to keep the bolts from backing out.
FrX (12-16-2015)
Old 12-16-2015, 02:17 PM   #578
FrX
No drilling. I didn't use the studs, those are justbolts. I put the nuts on the back with lock washers to help keep the bolts from backing out. It is an old technique from the old muscle car days. The bolts are threaded and tightened into the threads on the flange, then the nuts tightened on back to keep the bolts from backing out.
That's not a bad idea at all. Using bolts rather than the studs would probably give a bit more clearance when trying to get the overpipe in, too. I'll keep that in mind the next time it is apart.
Old 12-16-2015, 02:49 PM   #579
twag4
Drives: frs
And I used a higher grade bolt. O
CSG Mike (12-16-2015)
Old 12-16-2015, 07:33 PM   #580
07jazzrs5gt86
Drives: Firestorm 86
What size bolt did you use? Also what grade is the bolts?
I was planning on doing the same
Thanks
07jazzrs5gt86 is offline   Reply With Quote
Old 12-16-2015, 08:08 PM   #581
twag4
Drives: frs
Thanks
It is m6 x 30 mm, I forget thread pitch. (Maybe 1.25) and the grade is 10.9. When you see 8 or 8.8, that is the softest- compares to grade 3 in SAE hardware. Th 10.9 compared to grade 5, and 12.9 compares to grade 8. The numbers are from softest to hardest, or tensile strength. There are lower grades on smaller hardware, but for all of the bigger stuff, m6 and on I believe, these numbers are the same. Someone correct me if I am wrong. Just take one of the studs with you to get correct thread pitch. I bought these at lowes. They were out of stock on the m6 hardware I needed in stainless steel, otherwise I would have gotten stainless. The bolts started life shiny, but the heat has dulled them. I have all stainless hardware from there back that I bought at lowes. These are flange bolts due to the cramped space, makes it possible to get the 12mm box end wrench on them. If I get to lowes anytime soon, I will update with the thread pitch for sure.
The Following 2 Users Say Thank You to twag4 For This Useful Post:
07jazzrs5gt86 (12-17-2015), JimmyMac (12-16-2015)
Old 12-16-2015, 08:15 PM   #582
twag4
Drives: frs
Photos of a spare bolt like I used:
07jazzrs5gt86 (12-17-2015), CSG Mike (12-16-2015)
Old 12-16-2015, 08:15 PM   #583
twag4
Drives: frs
And another
Old 01-01-2016, 11:53 PM   #584
Wayno
Wayno's Avatar
Drives: Toyota 86 GTS
How many people are using OFT with this header so far?
Besides hawk.
Old 01-02-2016, 06:44 AM   #585
churchx
churchx's Avatar
Drives: 2014 GT86
Given strong discouragement for OFT voiced many times in favor of Ecutek in Ace's related threads, imho not too many. I'd also ask Shiv, if someone hadn't asked to do custom tune with this header state-side.
Old 01-02-2016, 06:59 AM   #586
Wayno
Wayno's Avatar
Yes, I myself have said to people to get custom tune, not to switch platforms, least of all to the ridiculously priced ecu-tek.
That's not what I asked though. Anyone with actual OFT can pm me.
The Following User Says Thank You to Wayno For This Useful Post:
solidONE (01-02-2016)
Old 01-07-2016, 12:27 AM   #587
AceHeader-MT
AceHeader-MT's Avatar
Drives: 2012 FR-S
Ace Header is halting production.
Our staff (now up to 7 members!) has been working flat-out to fulfill orders and now it's time to switch back to R&D.
If you have any open orders with us we will complete them and then go into hibernation for a while.
When we emerge we will have some new goodies that we think will help make these cars even more awesome.
We'll still be around so if anyone has questions just let us know.
Happy Driving,
Team ACE
AceHeader-MT is offline   Reply With Quote
The Following 12 Users Say Thank You to AceHeader-MT For This Useful Post:
86 South Africa (01-08-2016), Calum (01-07-2016), chaoskaze (01-07-2016), ck-GT86 (01-08-2016), Cop (01-07-2016), Hawk77FT (01-08-2016), Kotu100 (01-12-2016), MaximeT (01-07-2016), MisterSheep (01-07-2016), new2subaru (01-07-2016), Teseo (01-08-2016), ThatAsianBradah (10-31-2017)
Old 01-07-2016, 07:10 AM   #588
Calum
That Guy
Drives: 2013 asphalt FRS MT
Happy Driving,
Team ACE
I can't wait to see what else you guys come up with.
Who has Open Flash Header (or aftermarket UEL header) in the GTA with stock exhaust? alanhung85 CANADA 6 10-21-2014 10:41 PM
RevWorks UEL Header + Nameless Catted Front Pipe VS Stock Gutted Header + FP NickFRS Engine, Exhaust, Transmission 44 04-19-2014 05:42 PM
Top Gear Solutions| HKS Header |Borla EL & UEL Headers| Agency Power Header| + MORE! TopGearSolutions Engine, Exhaust, Bolt-Ons 82 04-14-2014 08:16 PM
Gutted cat stock header vs aftermarket catless header NA application stevo585 Engine, Exhaust, Transmission 8 04-04-2014 04:12 PM
Wanted: UEL header with Perrin header back and tune. skye67 Engine, Exhaust, Transmission 7 12-21-2013 10:34 PM
