Old 12-15-2015, 10:33 PM   #127
rosol16
Not A Member
rosol16's Avatar
Drives: 2014 Mustang GT
If I were to want to go FI and be safe I assume I should go forged rods and pistons with a 9:1 or 10:1 compression and I should then be relatively safe with 400whp+?
rosol16 is offline   Reply With Quote
The Following User Says Thank You to rosol16 For This Useful Post:
FRS Justin (12-15-2015)
Old 12-15-2015, 10:34 PM   #128
#maverick#
#maverick#'s Avatar
Drives: 2006 Pontiac GP (SOLD), 2014 FR-S
Originally Posted by FRS Justin View Post
Stock rods? If so you got a good one and I agree about the tune. If you don't go crazy on the timing it will help along with setting your cam timing to bleed off cylinder pressure some
but if you go all out its another story....
Like I said in my first post I have friends pushing 500 hp and are living there tune is moderate
and then the guys that went all out with 350hp go poof
edit for the guys that are going to ask 500hp on E85 350hp pump gas because of E85 availability 500 drives with sense 350hp total hazard if on the same block
500 completely stock motor. I run about 20 degrees timing advance at WOT iirc, on e85 its pretty safe.
"Project cars are like New Years Eve. Endless preparation, hype, a sleepless night of fun, followed promptly by massive headaches and regret." - Anonymous
#maverick# is offline   Reply With Quote
Old 12-15-2015, 10:42 PM   #129
LOLS2K
/scion
LOLS2K's Avatar
Drives: '13 86 M/T
"Practice makes better. Only Senna is perfect." - CSG Mike
LOLS2K is offline   Reply With Quote
The Following User Says Thank You to LOLS2K For This Useful Post:
itsibarra (12-16-2015)
Old 12-15-2015, 11:02 PM   #130
FRS Justin
Drives: 2013 Asphalt FRS
With a good tune from a reputable tuner you would be good to go
Instagram FT86PROJECT9S
Facebook FT86PROJECT9S
710whp
FRS Justin is offline   Reply With Quote
Old 12-15-2015, 11:17 PM   #131
FRS Justin
Originally Posted by Draco-REX View Post
I keep spot checking this thread for "facts" and I can never find any... Is this thread beneficial at all, or is it just a flame fest?
Per Webster dictionary
Definition of fact
  1. 1 : something that really exists or has occurred <Space travel is now a fact.> EX. People running high boost have broken rods is now a fact
  2. 2 : a true piece of information <“I just know for a fact that she has a huge family to feed!” — Kenneth Grahame, The Wind in the Willows EX. I just know for a fact people have broken rods under high boost.
If you can't see it now I can't help you
710whp
Old 12-15-2015, 11:26 PM   #132
#maverick#
#maverick#'s Avatar
Depends on the fuel, there is no reason in hell to go that low of a compression on a direct injection motor if you are running E85, lowering compression is only to compensate for bad fuel. On E85 the lowest CR I would go is 10.5:1. I personally am getting an 11.5:1 built motor.
Old 12-15-2015, 11:44 PM   #133
FRS Justin
He could push 600hp on E85 and a good build with his planned setup with a high boost big turbo. I don't know what his plans or gas availability is, maybe he wants to go 400hp and last 50 to 100k. So it hard to answer without knowing his needs.
You sound like me in it to win it personality not someone that's happy just to be there. So for you yes higher compression and not being afraid if it breaks works
Maverick what turbo do you run
710whp
Old 12-15-2015, 11:49 PM   #134
VitViper
Drives: '15 FRS
I feel like this thread might give my 500hp stock motor FRS aids, so I probably shouldn't read it all.
VitViper is offline   Reply With Quote
The Following 6 Users Say Thank You to VitViper For This Useful Post:
Apoc (12-16-2015), BRZoomTX (12-16-2015), clayrush (12-16-2015), CSG Mike (12-16-2015), johan (12-16-2015), ravisraval (12-16-2015)
Old 12-16-2015, 12:20 AM   #135
FRS Justin
Sounds like your car already has aids in first gear, WTH is that sound during the first 40 to 50 feet
[ame="https://www.youtube.com/watch?feature=player_embedded&v=ix8v0uxodME"]Turbo FRS Launch Control - YouTube[/ame]
and that bog when it gets traction in first gear wow I have never seen a 450hp frs bog in first gear on stock tires
710whp
Old 12-16-2015, 12:32 AM   #136
johan
Drives: '14 981CS, '99 NB1
LOL it's called ignition cut traction control...lol. It's how a real ecu actually keeps you moving forward.
johan is offline   Reply With Quote
The Following 4 Users Say Thank You to johan For This Useful Post:
BRZoomTX (12-16-2015), clayrush (12-16-2015), CSG Mike (12-16-2015), Slysdexia (12-16-2015)
Old 12-16-2015, 12:37 AM   #137
FRS Justin
Dude why would you use launch control with traction control. smh
boost control will also keep you moving forward be easier on the engine and not bog
710whp
Old 12-16-2015, 12:54 AM   #138
johan
The Following User Says Thank You to johan For This Useful Post:
Old 12-16-2015, 12:58 AM   #139
totopo
Drives: 370z
Can someone explain to me the animosity? why is everyone so instinctively butt-hurt? It's not like there is anything that shocking presented? can someone, instead of snarky comments, use words and explain why they are so offended?
Maybe it's because people have this wrong concept of mechanical failure where there is this magical HP number, where everything under it is hunky-dory safe, and everything over is immediately OMGWTF it's going to fall apart and brake. That's not how the world works, unless you are going to ridiculousness on either side. Ignore the shape of the curve, and the actual values, but the survival curve based on HP with stock internals assuming you don't have a retarded tune should look something like:
Note that this is % surviving. So are there 300whp engines that survive longer than stock engines? Most likely! Since up to whatever time point, it's not 100% failure, where as some stock engines start failing at low miles. Are there 500 whp engines that will survive longer than 350hp? sure. But I don't think it's necessarily economically wise to plan for a 300hp engine lasting 100,000 miles...
So the real question that only people with big pockets like subaru or maybe the big tuners know, is what the actual shape is at what hp level, and what are the components that brake, in order of likelyhood.
So if I understand properly, since FRS Justin has an n greater than 1, he believes in his personal experience, that it is the rods that break first, and if I understand him properly, he believes that the failure rate past 300-325 whp is uncomfortably high for his personal values.
If you are willing to take the risk and boost to 500whp, so be it, but I don't understand why you would be mad if someone told you that your engine PROBABLY will fail more quickly. And when it blows, don't assume it's the tune and would have been perfectly safe with a different tune.
totopo is offline   Reply With Quote
The Following User Says Thank You to totopo For This Useful Post:
FRS Justin (12-16-2015)
Old 12-16-2015, 01:02 AM   #140
VitViper
Drives: '15 FRS
Do you comprehend the difference between bogging and launch control? Do you understand what true launch control is?
Here's a hint: the engine RPM never went down (IE: bogging).
Boost control alone will never give you optimal acceleration when launching a vehicle, you will either have not enough slip, or too much slip (riding the rev limiter, must be your version of launch control).
By your definition the engineers at MoTeC are retarded and got it all wrong?
Or maybe in your attempt at a cute retort you made it apparent how little you actually understand and instead how truly ignorant you really are. What are you, 12?
The Following 3 Users Say Thank You to VitViper For This Useful Post:
BRZoomTX (12-16-2015), CSG Mike (12-16-2015), Dimman (12-18-2015)
kill brain cells, not facts
FlexFuel and Facts Shiv@Openflash Software Tuning 74 05-07-2025 04:28 AM
Anyone Else? Hearters Blowing when off. Kiske Issues | Warranty | Recalls / TSB 7 04-09-2014 05:22 PM
How cold is your a/c blowing? jermyzy Issues | Warranty | Recalls / TSB 68 08-18-2013 03:29 PM
Supra Blowing Up radroach Off-Topic Lounge [WARNING: NO POLITICS] 2 07-21-2013 09:14 PM
Facts you may or may not know about your GT86/BRZ/FR-s FiRStsc10n Scion FR-S / Toyota 86 GT86 General Forum 41 07-09-2013 03:05 PM
