Old 12-15-2015, 06:19 PM   #43
MrDinkleman
Drives: 2016 Oceanic, "base" model
Originally Posted by Dake View Post
I discovered on tire rotations, dealers no longer do (what I consider) the standard rotation either, they just move back to front front to back on the same side vs what I was taught which is back to front, front to opposite side back so your tires truly rotate through every corner of the car.
That was SOP back in the days of bias ply tires. Radials have always been front to back, same side.
MrDinkleman is offline   Reply With Quote
The Following User Says Thank You to MrDinkleman For This Useful Post:
Dake (12-15-2015)
Old 12-15-2015, 06:26 PM   #44
Originally Posted by fumanchu1 View Post
I had such a good picture response for what a good Gauge is but am at work and searching for Gauge pics would probably have brought quite a few NSFW result that could get me relieved from my position if you know what I mean.
Overall pretty safe.
Old 12-15-2015, 06:36 PM   #45
What kind of wheels are they ....... ??????????
Cole (12-15-2015), Eighty 6 (12-16-2015)
Old 12-15-2015, 07:28 PM   #46
stugray
Drives: 2013 GBS BRZ Limited
Plus many performance tires are unidirectional so cant swap sides.
The Following User Says Thank You to stugray For This Useful Post:
Tcoat (12-15-2015)
Old 12-15-2015, 08:42 PM   #47
mav1178
mav1178's Avatar
Drives: 2005 Toyota Camry
Originally Posted by justin6280 View Post
They checked my car for leaks and found out that the gasket needed to be replaced.
Gasket needed to be replaced? Or they double stacked the washer on the drain plug?
Old 12-15-2015, 09:08 PM   #48
FRSBRZGT86FAN
FRSBRZGT86FAN's Avatar
UPDATE: So after about 10 phonecalls of going straight to voicemail since Saturday, I decided to just drive up there myself and talk to them in person.
They checked my car for leaks and found out that the gasket needed to be replaced. So they did that and filled my car with new oil as well. I'm satisfied since it only took about 45 minutes
Gasket my ass, they definitely screwed up the drain bolt
Old 12-15-2015, 09:24 PM   #49
Yep, most likely. So, the re-tapped it and put a bigger one in ...... now, you're oil will drain out faster ......
FRSBRZGT86FAN (12-15-2015)
Old 12-15-2015, 09:30 PM   #50
Oh the 1800s what a simpler time
Yes! Like taking the horse in to get it re-shoed and discovering they used the same old nails .........
Old 12-15-2015, 09:33 PM   #51
And the same horse!
Old 12-15-2015, 09:38 PM   #52
fumanchu1
Drives: 2013 Brz C38 (bought not built :P)
these are not the gauges we are looking for
I meant her: http://www.imdb.com/name/nm0310024/
fumanchu1 is offline   Reply With Quote
The Following User Says Thank You to fumanchu1 For This Useful Post:
Tcoat (12-15-2015)
Old 12-16-2015, 11:53 AM   #53
justin6280
justin6280's Avatar
Drives: 2015 FRS
Yeah that's what I'm saying, but I guess they were just trying to make an excuse to not look bad on the lack of quality service on something so simple.
justin6280 is offline   Reply With Quote
Old 12-16-2015, 12:04 PM   #54
FRSBRZGT86FAN
You didn't have to pay a dime did you?
Old 12-18-2015, 06:43 PM   #55
justin6280
justin6280's Avatar
Drives: 2015 FRS
Yes you are correct, free service
Which dealership for service? Drive Northern California 23 01-25-2015 05:37 PM
First service from dealership JayDee Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 24 04-02-2014 02:41 PM
Best dealership for service?? booyaka Northwest 6 01-17-2014 10:14 AM
Oil Leak and Dealership Service hellyvin Northern California 9 03-19-2013 02:33 AM
Which dealership for first service? randomweather CANADA 1 12-23-2012 01:57 PM
