Old 02-14-2014, 09:32 PM   #15
LFA.Baby
LFA.Baby's Avatar
Drives: Frs 2014 MT whiteout
You should report this to Winjet, so they can fix it for future production and replace one of your headlight.
[[ ]=(86)=[ ]]
instagram - afong.86
Automotive Art
Commission me! for Virtual Tuning & Design
LFA.Baby is offline   Reply With Quote
Old 02-14-2014, 10:17 PM   #16
Ryan86
Road Warrior
Ryan86's Avatar
Drives: Toyota 86 Satin Pearl White
Is this problem unique to the recent GB or across by GB. Just want to establish if its a batch or common problem with the Winjets.
Ryan86 is offline   Reply With Quote
Old 03-02-2014, 04:50 PM   #17
beaver_scott
beaver_scott's Avatar
Drives: 2013 FRS hot lava
Update--I installed my winjets. They were aimed very low. After adjusting the lights to the correct height the projectors are more rigid. I experience no bouncing of the light cutoff while driving and/or hitting bumps. I like these lights!Name:  ImageUploadedByTapatalk1393796953.801161.jpg
Size:  140.5 KBName:  ImageUploadedByTapatalk1393796975.035139.jpg
Size:  225.7 KBName:  ImageUploadedByTapatalk1393796991.884885.jpg
Size:  137.2 KBName:  ImageUploadedByTapatalk1393797005.951278.jpg
Size:  299.6 KBName:  ImageUploadedByTapatalk1393797019.135121.jpg
beaver_scott is offline   Reply With Quote
Old 07-28-2014, 05:26 AM   #18
Eightysexy
GBC [HI]
Drives: Haole FRS
bump for this, due to me having the same issue....any else as well?
Eightysexy is offline   Reply With Quote
Old 11-24-2014, 01:59 PM   #19
wrussi
wrussi's Avatar
Drives: 2013 frs
noticed my projector a bit loose on my driver side headlight as well. they are installed and aligned properly but the driver's projector seems a bit more loose than the passenger's... any way to tighten it?
wrussi is offline   Reply With Quote
Old 03-30-2015, 08:52 PM   #20
unclefarkus
Drives: scion fr-s
anybody ever figure this out?
unclefarkus is offline   Reply With Quote
Old 03-31-2015, 09:10 PM   #21
unclefarkus
Drives: scion fr-s
so i've come to the conclusion that my wobble is the reason i can't adjust the cutoff on my driver side. turning the bolt does nothing to raise or lower the light. and the light came too low to drive with. so i'm going to remove all the stuff again and try to fix this. i tried tonight, but there's just not enough clearance while installed to really see what's happening in there.
i have small window of daylight after work tomorrow to get this done. does anybody have any advice on what to look for? my best guess is that the harness for the bulb is detached from the piece that adjusts the cutoff (which explains the wobble). any ideas what to look for so I can fix it quickly and get the car put back together? thank you.
Old 06-14-2015, 12:04 AM   #22
Fang
Fang's Avatar
Drives: '13 Asphalt FR-S
Any updates on this? Having the same issue. Going to email winjet tonight
Fang is offline   Reply With Quote
Old 12-10-2015, 05:25 AM   #23
mike7792
mike7792's Avatar
Drives: 2014 Scion FR-S
Any solution to this problem? I am having the same problem on the passenger side. The light appears as if I am high beaming cars that I am following (according to someone driving ahead of me while I was following them)
mike7792 is offline   Reply With Quote
Old 12-10-2015, 05:37 PM   #24
FRSBRZGT86FAN
FRSBRZGT86FAN's Avatar
Are the headlights aimed properly? Any wobble I had disappeared once I messed with the set screw and aimed them properly. If you can find an empty parking lot with a wall that you can get 25 feet away from you can do it properly, it's imperative especially if you have HIDs.
Old 12-15-2015, 02:17 PM   #25
Nitro22
Nitro22's Avatar
Drives: Scion FR-S (Hot Lava)
I just installed winjets and did notice the actual projectors inside wobble. As some have stated, once you start adjusting the aim there should be sufficient tension to eliminate most of the wobble. I didn't want to take that risk, so I did something about it.
I painted the inside of my winjets, so I had mine open anyways. I found that the plastic inserts that the (2) long adjuster screws thread into are the culprit for the wobble. I ended up removing the projector & base from the housing and adding small pieces of electrical tape. I put the tape in the hole that the plastic insert clips in making the fit tighter and creates some drag if they do move. After doing this, the wobble is gone even without creating any tension with the adjuster screws. Like I said, it may not be needed, but I just wanted piece of mind knowing they weren't going to wobble after I got everything back together.
Nitro22 is offline   Reply With Quote
Old 12-15-2015, 10:48 PM   #26
FRSBRZGT86FAN
interesting, while you had the winjets apart you could've done a dope projector retrofit
Old 12-16-2015, 11:20 AM   #27
Nitro22
Nitro22's Avatar
Yeah, that would have been a good mod to do. But I would have had to buy the projectors and HID kit which was more than I wanted to pay at the time. Luckily the Winjet lights are easy to open up.
Old 12-16-2015, 11:48 AM   #28
FRSBRZGT86FAN
Understandable, the stock projectors imho are pretty good with hids anyway, the cutoff is quite good
Crank Pully Wobble... With video Norcalmav23 Engine, Exhaust, Transmission 33 09-25-2019 07:26 PM
Wobble, falling apart, loose joints? imravenit Issues | Warranty | Recalls / TSB 25 03-29-2015 10:02 PM
Winjet HID Size? Jeremehh Cosmetic Modification (Interior/Exterior/Lighting) 9 03-10-2014 02:28 AM
FS: Winjet Chrome Headlights civicdrivr Exterior Parts (Aero, Lighting, Etc.) 6 01-16-2014 11:33 PM
Custom Purple Winjet and Black Winjet Headlights xclusive_brett Cosmetic Modification (Interior/Exterior/Lighting) 35 12-17-2013 08:28 AM
