Old 11-12-2015, 10:56 AM   #15
JDM Haze
JDM Haze's Avatar
Drives: Whiteout FRS
Originally Posted by Basket Case View Post
How has the handling ben effected by the swap? I really want to go this route, but i do't want to drift. I want the car to handle very similar to stock so that I can still enjoy twisty roads and tracking.
Thanks in advance.
I believe with the LS engine swap the front sway bar has to be removed to fit the engine, so handling isn't going to be like it is with the FA in there. I know there is a company I forgot the name that is making a sway bar for the LS swap.
JDM Haze is offline   Reply With Quote
Old 11-12-2015, 01:16 PM   #16
Spartarus
...Just add nauseum
Spartarus's Avatar
Drives: 2003 (AP1) S2000
Originally Posted by JDM Haze View Post
I believe with the LS engine swap the front sway bar has to be removed to fit the engine.
No. It doesn't. The reason somebody removed it in *another* swap was because it interfered with the factory oil pan on the chosen motor.
You will not have to remove the sway bar if you have a suitable oil pan.
There are many ways to displace.
-Spartarus
Spartarus is offline   Reply With Quote
The Following User Says Thank You to Spartarus For This Useful Post:
Basket Case (11-12-2015)
Old 11-12-2015, 04:37 PM   #17
JDM Haze
JDM Haze's Avatar
Ahh ok, thanks for the correction!
Old 11-13-2015, 01:56 AM   #18
Amir Ghadiri
Amir Ghadiri's Avatar
This is correct. The CX oil pan clears the factory sway bar, subframe, etc. Nothing needs to be cut or removed. The factory crossbars will even clear everything except the rearmost coil pack on the passenger side (which is easily relocated to allow mounting of the crossbar). In the 'other' swap's defense, it is ideal to have a rear sump oil pan (mine is a front sump), but a proper dry sump system (or even wet sump, although less desirable) fixes that problem (and really should be utilized anyways).
The car still drives and handles great. It is very well planted, it will go whereever you point it. I've been driving it for the past few days and it really doesn't feel any different than with the FA, it just has real power.
Amir Ghadiri is offline   Reply With Quote
The Following 5 Users Say Thank You to Amir Ghadiri For This Useful Post:
Basket Case (11-13-2015), pward08 (03-25-2018), raven1231 (01-19-2016), Spartarus (11-13-2015), Ultramaroon (11-13-2015)
Old 12-11-2015, 09:53 PM   #19
mkivalex
Drives: 13 Scion FRS, 93 JDM Toyota Supra
Any other input on the CX swap kit? Thinking about pulling the trigger on it before the CDN dollar gets worse. I'd like to wait for the vorshlag kit but still haven't seen anything yet
mkivalex is offline   Reply With Quote
Old 12-13-2015, 03:35 PM   #20
jwvand02
Drives: 2013 SWP BRZ Limited
Whats involved from the electrical side?
jwvand02 is offline   Reply With Quote
Old 12-14-2015, 12:53 PM   #21
Spartarus
...Just add nauseum
Spartarus's Avatar
Standalone ECU, custom wiring for the engine, appropriate tuning.
Only CANBUS enabled ECU's with a preconfigured profile for the FRS are viable (without a ridiculous amount of extra work). That leaves you with MoTeC, Haltech, and very few others.
-Spartarus
DAEMANO (02-02-2016)
Old 12-14-2015, 04:48 PM   #22
cf6mech
Drives: FRS Silver LS1 swapped.
Can-bus integration is everything for this swap,..the steering is sluggish when its in the default mode and having the big tach on the dash to work would be nice....abs..traction control...everything else is pretty straight forward and fundamental....There are fixes in the work as we speak using stock ECU which will be.....yes... a retail product..i.e.less costly. And I'm sure others,.....because this car screams for more power that's reliable and N/A and I'm sure many will hit the streets before long....
cf6mech is offline   Reply With Quote
The Following User Says Thank You to cf6mech For This Useful Post:
wparsons (12-17-2015)
Old 12-15-2015, 12:23 AM   #23
Drift&Drag
TURBOLICIOUS
Drift&Drag's Avatar
Drives: a machine :]
I am honestly surprised we do not see more LS-swapped 86s running around the streets here in Dallas.
Drift&Drag is offline   Reply With Quote
Old 12-15-2015, 05:42 PM   #24
cf6mech
I predict we will once warranties run out and the used prices go done and more kits are available
Old 12-15-2015, 06:11 PM   #25
Drift&Drag
TURBOLICIOUS
Drift&Drag's Avatar
I totally agree
Old 12-15-2015, 06:33 PM   #26
cf6mech
I totally agree
Off subject.....I sure would like to buy your differential......just don't have the cash right now......its the last weak link in my set up....have DSS drive shafts....but need your diff for a complete bullet proof drive train.
Old 12-16-2015, 02:14 PM   #27
Drift&Drag
TURBOLICIOUS
Drift&Drag's Avatar
Come on get it bro. I'm right next to Plano lol
Old 12-16-2015, 04:23 PM   #28
cf6mech
I'm in Keller.....love to....Christmas an all....hopefully you have it in a month or two....then I will.
Pentosin Trans Fluid Swap | Motul 300 Diff Swap | Impressions Dezoris Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 15 06-06-2017 10:54 PM
SOLD MisterSheep Brakes, Suspension, Chassis 8 11-23-2015 11:34 AM
$1500 to spend sixthree BRZ First-Gen (2012+) — General Topics 40 03-11-2015 01:47 AM
