Old 12-14-2015, 11:25 AM   #15
nickmerronesucks
Ned flanders
nickmerronesucks's Avatar
Drives: 13 BRZ, 16 Hellcat, 22 Ram 2500
Technically they can suggest whatever the hell they want, that's why its a suggestion, "Based off the mileage", I think they say every 15k you can do a fuel system cleaning/throttle body service.
When i was a tech that was an easy thing to sell on cars that didn't need any major work or needed nothing at all. And you can do it and walk away and work on another car. Or what most techs do is just throw it in the trash and not do anything to your car sadly I've seen it happen numerous times. I am out of the automotive field and a big part of that was because we had to rip customers off and up-sell them just to get a decent pay check, unfortunately.
797Performance.com
nickmerronesucks is offline   Reply With Quote
Old 12-14-2015, 11:27 AM   #16
stevesnj
stevesnj's Avatar
He didn't pay for a service not rendered.
I know, this is just a general statement.
My 2016 Build thread
Old 12-14-2015, 11:29 AM   #17
strat61caster
strat61caster's Avatar
Drives: '13 FRS - STX
But...
At the same time telling him that his "throttle will stick" due to build up is just as dishonest. Not only that but it shows a deep lack of knowledge on how these cars even work since he apparently didn't know it is drive by wire with no throttle linkage to jamb up.
No matter how the valve is actuated I can see it sticking over time.
My 25 year old pickup truck with 205,000 miles on it had a throttle valve I wouldn't mind eating off of, I doubt it was ever cleaned, certainly not in my 5 year 25,000 miles of ownership.
Edit: I guess throttle cleaning has changed over time from cleaning the cable and actuator to cleaning the interior of the body, sticky throttle is usually attributed to the linkage which on older cars needs regular maintenance vs. newer cars electronic bodies that probably aren't able to be serviced at all.
ineedyourdiddly
Old 12-14-2015, 11:29 AM   #18
AHHHH sounded like he should report them for that in your post. Since it didn't happen then it is not reportable.
Old 12-14-2015, 11:33 AM   #19
The valve can stick yes, but if that clogged up you would probably have other symptoms well before that happened.
Besides:
The OP was told "I have a lot of carbon buildup on my throttle body and if I don't clean it my gas pedal will stick.
FRSBRZGT86FAN (12-14-2015), strat61caster (12-14-2015)
Old 12-14-2015, 11:36 AM   #20
stevesnj
stevesnj's Avatar
Erratic idle for one.
The Following User Says Thank You to stevesnj For This Useful Post:
Tcoat (12-14-2015)
Old 12-14-2015, 11:52 AM   #21
YamahaR86
JDM Vaping Stance Nation
YamahaR86's Avatar
Drives: 2013 White
I've read round the internets from a mechanic that they usually fix carbon buildup by driving the car, hard. Typically people baby their car but once in a while it needs to be opened up to clean out the carbon.
Not sure if it's true or not being the internet.
Edit: Here's the quote I originally read.
Actual mechanic here. I will say one thing I see quite a bit that you may not know, is when people almost exclusively take short trips, never allowing their vehicles to get up to temp, and always babying their car. ESPECIALLY direct injection engines. It's important for your vehicle to get up to operating temperature, and also for you to flog it from time to time. Failure to do so will result in large amounts of carbon deposits on your intake valves. Carbon deposits can build to the point where your car will not run correctly. This can be dealt with by driving the hell out if it from time to time. Some customers end up paying us good money to take their car out for them, and beat the hell out of it, knocking the carbon off the valves. If it's too bad, we have to take off the intake and clean them manually. Happens about once a week.
Source: Professional mechanic, Went to college for automotive technology, ASE Certified Master Technician.
YamahaR86 is offline   Reply With Quote
The Following User Says Thank You to YamahaR86 For This Useful Post:
Tcoat (12-14-2015)
Old 12-14-2015, 01:01 PM   #22
Zyo81
Drives: '13 Firestorm FR-S, 99 Mustang GT
Besides:
Yes, she actually said gas pedal, not throttle. And yes, she. I suppose we shouldn't be surprised.
Zyo81 is offline   Reply With Quote
Old 12-14-2015, 02:13 PM   #23
FRSBRZGT86FAN
FRSBRZGT86FAN's Avatar
italian tune up
The Following 2 Users Say Thank You to FRSBRZGT86FAN For This Useful Post:
soulreapersteve (12-14-2015), Tcoat (12-14-2015)
Old 12-14-2015, 02:14 PM   #24
mav1178
mav1178's Avatar
Drives: 2005 Toyota Camry
Originally Posted by Zyo81 View Post
Almost makes me look forward to my warranty being expired so I don't have to take it in anymore.
But you don't have to. Yet you still do.
Old 12-14-2015, 02:44 PM   #25
Zyo81
I've had enough legal issues not go my way that I don't leave it to chance. Really I would have bought used and saved money and avoided the warranty situation, but after already waiting years for the car to come out I wasn't about to wait several more.
Old 12-14-2015, 02:50 PM   #26
mav1178
mav1178's Avatar
Leave what to chance? If you go to a decent 3rd party mechanic that you can trust and is properly certified, there is ZERO ISSUE with warranty coverage.
-alex
Old 12-14-2015, 03:03 PM   #27
Zyo81
-alex
If I didn't take it to the dealer I'd do the work myself. Why would I pay a 3rd party mechanic.
Old 12-14-2015, 03:07 PM   #28
Teseo
Drives: frs
They voided my warranry because i changed the axleback muffler
Is it crooked? becauseracecar1 Cosmetic Modification (Interior/Exterior/Lighting) 18 05-10-2014 09:59 PM
License plate light crooked? (diode dynamics) Vincenttam Cosmetic Modification (Interior/Exterior/Lighting) 7 01-07-2014 11:17 PM
dealership kasoneblaze1024 NY / NJ / CT / PA 12 05-02-2013 03:39 PM
My 86 Experience at Tokyo Dealership. Full TRD trim 86 on display TuxedoCartman Scion FR-S / Toyota 86 GT86 General Forum 75 05-16-2012 06:13 AM
got the last one at mt dealership! Mtc46jw CANADA 2 05-12-2012 09:26 PM
