| Software Tuning Discuss all software tuning topics. |
Drives: 2013 GBS BRZ
OFT error, help needed
I got an error shows an error occured while writing to the ECU Please try again. I think it may cause dislodging of the OBD2 cable. My car cannot start right now and there is no (*) on my current file. I think the ECU file may broken so OFT cannot identify the current file in ECU. Does anyone know how to solve this problem? Thanks!
#2 | |
Drives: FT86
try putting some forwards or backwards pressure on obd connector on car bay use rubber band to get a connection, then look at fixing obd socket. make sure cable is plugged in propertly at oft end as well. make sure car battery is charged and the your turning ingnition full on (do not start) when flashing not just accessory position |
| The Following User Says Thank You to steve99 For This Useful Post: | Cole (12-13-2015) |
#3 | |
Thanks man! I'll check them tomorrow. But I think there is no problem with obd connector because all other functions are worked. Do you think there have some other problems cause the OFT cannot flash the ECU? |
#4 | |
Drives: FT86
Try reflashing your stock rom back to car. oft will be interactive if it get power from car via obd port but logging and flashing will not work if rom is incomplete or no data communication with ecu due mayne the data pins not making good contact in obd connector but power pins ok |
#5 |
Drives: FT86
did you make any changes to the tuned rom with romraider ??
#6 |
Yes, I just did launch control before. I changed UEL header today, and then I try to flashing oft stg2 uel 93oct file into the ECU. OFT shows I complete flashing but I can't start my car. After that I try to reflashing to the stock file, then OFT shows error.
#7 | |
#8 |
You use OFT, it should've read the stock one at the beginning
#9 |
#10 | |
Drives: FT86
http://www.ft86club.com/forums/showthread.php?t=79152 when you changed lc\ffs parameters were the boxes on romraider black with no data or green ????? post up the definition and your rom file |
#11 |
Drives: FT86
If you have used incorrect def file to edit it likely written a corrupt rom to ecu.
Use the oft to write bact the Original File to the ecu the one in the top slot. if it still wont write try this Switch off ignition Remove positive battery terminal With battery disconnected, depress brake pedal to bleed off and redidual power Replace battery terminal Flash your original tune to car on first turn on of ignition Ie plug in oft turn ignition on go to write , wtite original tune without turning ignition off even if oft asks you to. After that i think you got big problem, contact the oft guys. |
#12 | |
File in my computer, I'll post later. I think is green and lc works fine before. I just try to flashed original stg2 uel 93oct file that I download from openflash website, I didn't edit anything in that stg2 file. |
#13 | |
Thank you so much, I'll try it tomorrow. Wish I don't get a big problem. |
#14 | |
| error | sokol | Cars for Sale/Trade | 9 | 12-09-2014 03:22 AM |
| ECUtek error 37 | NickFRS | Software Tuning | 5 | 06-29-2014 04:14 PM |
| Unichip Error Code | Ingeberger | Engine, Exhaust, Transmission | 5 | 12-29-2013 01:09 PM |
| Paperwork error | Rob_g | Scion FR-S / Toyota 86 GT86 General Forum | 4 | 05-24-2012 11:38 PM |
| Driver error | Midship Runabout | Off-Topic Lounge [WARNING: NO POLITICS] | 5 | 07-14-2010 07:25 PM |
