Old 12-11-2015, 05:06 PM   #113
swarb
is Tsudo pronounced the same as pseudo? hmmm
The Following User Says Thank You to swarb For This Useful Post:
bfrank1972 (12-11-2015)
Old 12-11-2015, 05:08 PM   #114
ryoma
ryoma's Avatar
Originally Posted by X00 View Post
Ok great thanks. Yeah I went fairly cheap on the full exhaust ($780) so I wasn't expecting top of the line stuff. Funny how they could just forget about the 2nd bung for the sensors but owell. Since its virtually the same CEL as one would get regardless I don't mind. For anyone else wanting to order this header, I ordered it from Speed Element.
you'll have a dangling connector though if you remove the 2nd O2 sensor. have you contacted your vendor to see if they can replace it for you?
Old 12-11-2015, 05:09 PM   #115
mav1178
mav1178's Avatar
Drives: 2005 Toyota Camry
Frankly it's absurd, as it requires the end user to do more to make the product work properly.
Just exchange it so you are not stuck with something you can't sell later...
-alex
Cole (12-11-2015)
Old 12-11-2015, 05:19 PM   #116
invaliduser
Drives: 2017 86
-alex
Might be the header for the 2.0 used in another Subaru.
Sent from my Nexus 6P using Tapatalk
invaliduser is offline   Reply With Quote
The Following User Says Thank You to invaliduser For This Useful Post:
Cole (12-11-2015)
Old 12-11-2015, 05:27 PM   #117
Cole
Not a troll
Cole's Avatar
I feel like it is.
On topic, bargain bin parts are always a bit of a gamble. I've lost on 2 of them. A cheap exhaust I had didn't hang evenly and my CNT header was off by about 1/16th of an inch, so I had to hammer it with a rubber mallet to get one side to slip onto the studs.
Cole is offline   Reply With Quote
Old 12-11-2015, 07:44 PM   #118
X00
Drives: 2013 Frs:Full Exhaust, NA etc
Well I disconnected the sensor from the ECU female connector that is mounted by the battery. Fully removed the sensor and its wire from the car. TBH I didn't notice it was missing the 2nd sensor hole until I pulled the factory header off. At that point I figured I could just do without the second sensor, assuming I could take care of the CEL by tuning. User preference I suppose.
X00 is offline   Reply With Quote
Old 12-11-2015, 07:55 PM   #119
X00
-alex
Thanks! Yeah I will check with the return policy and whatnot. I love the way the car sounds now, if I can't resolve the CEL I will try and get a replacement.
Old 12-11-2015, 10:30 PM   #120
B-R-Z
I love peanut butter
B-R-Z's Avatar
Drives: 2013 SWP BRZ Limited
I'd definitely return it. I think they will fix their mistake, they responded to my inquiry quickly and even let me use a coupon code that expired.
If all else fails you could buy an o2 bung and have it welded to your header. It sucks, but if that is the only issue you have with the header then it may be an easy fix.
As for the CEL, you will have it even with both o2 sensors. A tune can disable it though.
B-R-Z is offline   Reply With Quote
Old 12-11-2015, 10:43 PM   #121
Teseo
Drives: frs
"Zudo" if its kanji
Old 01-09-2016, 02:27 PM   #122
dar3d3vil
dar3d3vil's Avatar
Drives: 2015 BRZ Limited
Ordered one on December 19th, when it arrived it had only 1 O2 bung, I think it's a bad/defective batch. They apologised profusely to me and are shipping a new one out to me already. Also, worth noting that the one that I had also had part of the pipe sticking out of the top of the section to bolts to the engine. We tried a test mount just for a try and it was rough as hell. Lots of leaks to say the very least
2015 DGM BRZ/Gruppe-S UEL/Gruppe-S Overpipe/Invidia N1 Catback/AEM Strut/TEIN Street Basis/Cusco AOS
dar3d3vil is offline   Reply With Quote
Old 01-14-2016, 11:57 AM   #123
X00
Just an update for future potential buyers. OFT stage 2 removed the CEL, so I had no reason to return the product (my preference). Virtually nothing was different with only 1 bung, aside from disconnecting the unneeded 02 sensor. As for my mounting experience, I chose to install, run it for 100 miles, then tighten up the bolts. No exhaust leaks or issues from my experience. One thing to note, installer has to use a swivel deep socket for 1 of the bolts, that resides in-between the driver side runners.
Old 01-14-2016, 12:24 PM   #124
Cole
Not a troll
Cole's Avatar
This is just my experience, and from what I understand, it does happen in some ROMs. But, you may need to put your ROM in ROMRaider and disable P0420 CEL (cat efficiency or something). At least for my ROM (D00D) it wasn't already disabled and I got that code after I flashed the Stg 2 ROM.
The Following User Says Thank You to Cole For This Useful Post:
FRSBRZGT86FAN (03-17-2016)
Old 01-15-2016, 10:09 PM   #125
B-R-Z
B-R-Z's Avatar
In the A01C stage 2 ROM it was disabled by default. I'm surprised they would leave this enabled in any stage 2 ROM.
Old 03-17-2016, 07:36 PM   #126
B-R-Z
B-R-Z's Avatar
I think my header is cracked or something. I started getting like a clicky and more airy of a sound when accelerating, slightly worse gas mileage and when I pop the hood I can smell exhaust. I'm going to remove the skid plate this weekend and take a better look to confirm.
I contacted semotors.com and they said they only warranty for 1 year. I have a friend who welds who said he will attempt to fix it.
Have to reflash a stage 1 OFT rom too until this is resolved.
Has anyone else had issues?
Tsudo Header and Overpipe boredom.is.me Engine, Exhaust, Transmission 70 11-04-2014 02:14 AM
For sale: Tsudo UEL header jupillam Engine, Exhaust, Bolt-Ons 10 07-08-2014 01:40 PM
Anyone have the Tsudo header? Iam-Naimless Engine, Exhaust, Transmission 8 07-02-2014 02:55 PM
New Tsudo UEL header Fast_Freddy Engine, Exhaust, Transmission 1 05-11-2014 02:33 AM
Tsudo Header ML Engine, Exhaust, Transmission 7 01-11-2014 02:31 PM
