Old 12-11-2015, 02:28 PM   #1
phantasticity
Ricer
Evo3 Exhaust Y pipe leaks
phantasticity is offline   Reply With Quote
Old 12-11-2015, 02:30 PM   #2
go_a_way1
Not Bаnned Anymore
go_a_way1's Avatar
Drives: Heavily Modified FRS
Originally Posted by phantasticity View Post
Hey guys, I just recently bought a used Evo3 Exhaust for my Frs, but there is some leaks on the y pipe, any suggestions on how can i fix it or do you guys know where can i find a thicker gasket for it?
Thank you,
Can you weld?
Edit: I guess I should ask if it is the gasket or a joint on the pipe?
Old 12-11-2015, 02:41 PM   #3
Cole
Not a troll
Cole's Avatar
Definitely a new gasket if you haven't tried that yet, or you could try using 2 gaskets at once. I've never tried that, but I hear it works.
Cole is offline   Reply With Quote
Old 12-11-2015, 04:48 PM   #4
If it's leaking at the welded "Y" joint, I suggest you take it to a muffler shop and they can weld it for you.
If it's leaking at the flange, either get a new gasket (or as suggested above, use two gaskets) or "make" a gasket out of thicker material.
Old 12-11-2015, 06:39 PM   #5
phantasticity
Ricer
Its at the flange, do you know where can i get a new gasket or a thicker gasket for it?
Old 12-11-2015, 06:49 PM   #6
RobertPaulson
Hisnamewasrobertpaulson
RobertPaulson's Avatar
Drives: 2017 Golf R
your local autoparts store or amazon or another online retailer.
This is your life and it's ending one minute at a time.
RobertPaulson is offline   Reply With Quote
Old 12-11-2015, 08:05 PM   #7
OK, it's leaking at the flange.
I have to ask, when you tighten the nuts on the flange, are you tightening each side alternately, till they are tight ..... ??
When the two sides of the flange are butted up against each other, in a relaxed fashion, do they meet squarely .. ?? If not, try to "bend" the longer side till the two sides meet flush and the flange is secured.
You're sure the "flange onto the pipe" weld is good ... ??
Like @RobertPaulson suggested, you could take the gasket into the auto parts store and ask them for a new one. OR maybe buy some exhaust gasket material and make your own.
If it's a small leak, some exhaust sealer goop may stop it up.
RobertPaulson (12-14-2015)
Finding header/exhaust leaks JB86'd Engine, Exhaust, Transmission 8 10-14-2015 10:12 AM
FS: Greddy Evo3 and HKS Dual Res. Front Pipe Miami, Fl Trmx2 Engine, Exhaust, Bolt-Ons 10 09-24-2015 01:23 PM
EVO3 w/ Perrin Front Pipe? BigJyoungblood Engine, Exhaust, Transmission 13 04-09-2013 02:37 PM
New exhaust leaks Vukodlac Engine, Exhaust, Transmission 35 02-27-2013 12:41 PM
***GREDDY EVO3 EXHAUST ONLY ONE AVAILABLE!*** genometuning Engine, Exhaust, Bolt-Ons 9 11-12-2012 01:20 PM
