Old 07-30-2013, 05:41 PM   #1
brillo
Drives: 2013 Firestorm FR-S
moldable/cuttable plastic for DIY projects
So I'm looking for a type of plastic I can source at home depot / lowes etc... that is somewhat moldable and cuttable. Think the thickness and denesty of our airbox. Also willing to explore online purchase options.
I'm trying to create a block off "plate" or cover for my oil cooler in the winter.
any suggestions? have some other various ideas that such plastic would be useful for as well.
2013 Firestorm FR-S, MTX, build date 1/13.
brillo is offline   Reply With Quote
Old 07-30-2013, 10:58 PM   #2
post_break
Professional Smartass
post_break's Avatar
Drives: White Out FRS
Plexiglass and sugru. Keep in mind that radiator might get quite toasty.
post_break is offline   Reply With Quote
Old 07-30-2013, 11:18 PM   #3
Gunman
Drives: 2019 Mazda Miata RF
http://www.mcmaster.com/ anything you can imagine, and all kinds of plastic sheet:
http://www.mcmaster.com/#standard-pl...sheets/=nur0kd
The Following User Says Thank You to Gunman For This Useful Post:
Anthony (08-05-2013)
Old 07-31-2013, 06:46 PM   #4
BigFatFlip
sleep, drive, eat, repeat
BigFatFlip's Avatar
Drives: '13 BRZ, '12 Outback
You can also pay Tap Plastics a visit. I've used HDPE sheets from them for under body cladding, I'm sure you can use thicker sheets for your application.
Old 07-31-2013, 10:41 PM   #5
1stGenBRZ86
1stGenBRZ86's Avatar
umm if you're going to put plastic in the engine bay, please look at the temp range before you do so. Off the top of my head, two plastics that work well under the hood are delrin and phenolic.
1stGenBRZ86 is offline   Reply With Quote
Old 08-05-2013, 05:10 AM   #6
notout86
Drives: GTS 86 auto
I find the plastic of soft-drink bottles handy. Very tough and light weight, heat resistant, see-through, areas cut out are often the shape you already want, ducting, tubes etc. , crimp, secure with duct tape . Lasts for > 17 years in engine compartments.
Dunno how to glue it successfully yet.
Old 08-13-2013, 09:01 PM   #7
antlers
White Guy
antlers's Avatar
Drives: 2005 Subaru WRX STI
Look into kydex. It's a thermo plastic used a lot in the firearms industry among other things. Heres a few things i've made with it:
This won't work if the radiator is over like 150* F.
antlers is offline   Reply With Quote
Old 08-14-2013, 10:49 AM   #8
mid_life_crisis
Drives: FR-S 10 #103 AT
Why does it have to be plastic? Sheet metal at the thickness you're talking about is still very light and easily shaped. Clean it good and coat it with some high temp paint.
“Sex is like Bridge. If you don't have a good partner, you'd better have a good hand.” - Mae West
Papa said, "son there's a lot of evil temptations out there. Best to try 'em all so you know which ones to avoid."
mid_life_crisis is offline   Reply With Quote
Old 08-14-2013, 11:43 AM   #9
brillo
doesn't have to be plastic, guess I'm just more scared to shape/cut metal. What sheet metal would you recommend that is readily available? Does home depot carry aluminum sheets that are small?
Old 08-14-2013, 12:20 PM   #10
mid_life_crisis
I'm pretty sure they have small pieces of the same stuff they make ducting out of.
Old 12-11-2015, 08:52 AM   #11
ZionsWrath
Thanks
ZionsWrath's Avatar
I am using blue tape right now.
I'd switch to cardboard and duct tape for below freezing temps but I won't be driving my BRZ once the roads start getting salted.
The main thing is blocking air flow through the fins. Your car is still going to cool oil more than a stock car because of the extra pathway it is taking.
Old 12-11-2015, 09:08 AM   #12
go_a_way1
Not Bаnned Anymore
go_a_way1's Avatar
Drives: Heavily Modified FRS
I wanted to do something like this as well, but I just ended up taking the thermostat completely out of the sandwiched plate and now oil temps are find in -10C (coldest its been so far, but I am expecting to see -35C) to doesn't take much longer then with no oil cooler to warm up and it runs at 190 under normal driving
Old 12-13-2019, 08:55 AM   #13
gtpvette
Drives: 2015 FRS - FFR GTM
Used this for wheel wells....
https://www.ebay.com/itm/HDPE-High-D...72.m2749.l2649
2015 FR-S - One Day I'll Finish The Swap
gtpvette is offline   Reply With Quote
OKADA PROJECTS PLASMA DIRECT ahaghshenas Engine, Exhaust, Transmission 14 06-21-2017 10:41 AM
One of my other projects...K24 Miata Swap :) aCab Other Vehicles & General Automotive Discussions 16 06-30-2014 10:43 AM
FRS/BRZ: D3PE Projects and products! Evan@D3PE BRZ Photos, Videos, Wallpapers, Gallery Forum 24 08-12-2013 11:42 AM
Projects and Gallery Dezoris Member's Car Journals 0 10-26-2012 06:30 PM
Trade my black dash plastic for your silver dash plastic thread. F3dzo Southeast 0 07-17-2012 11:06 PM
