Old 12-08-2015, 07:57 PM   #3235
ravisraval
Drives: 2013 FRS
What pads would you recommend for the rears? Rr racing b20 up front, assume stock rotors in back. Stock power on kw v3.
ravisraval is offline   Reply With Quote
Old 12-08-2015, 07:59 PM   #3236
Blizzard
Drives: '13 FR-S Whiteout
We need to fix your pad situation.
What's at the rear?
BP-20 F and R
Blizzard is offline   Reply With Quote
Old 12-08-2015, 08:04 PM   #3237
CSG Mike
CSG Mike's Avatar
Originally Posted by Blizzard View Post
BP-20 F and R
Sounds like the RR kit actually is not balanced at all...
Old 12-08-2015, 08:23 PM   #3238
Blizzard
Front vs. rear...
Maybe time to go back to Winmax or try Carbotech haha. These came with the kit though.
Old 12-08-2015, 09:43 PM   #3239
CSG Mike
CSG Mike's Avatar
Front vs. rear...
Wait what? Same pads front and rear?
Old 12-08-2015, 09:47 PM   #3240
LOLS2K
/scion
LOLS2K's Avatar
Drives: '13 86 M/T
Front vs. rear...
WTF
LOLS2K is offline   Reply With Quote
Old 12-09-2015, 01:11 AM   #3241
Uplink
Uplink's Avatar
Drives: anything you let me
Front vs. rear...
Are you noticing significant rotation in the car or the rear getting squirrely under hard braking? That seems like a LOT of rear bias.
Uplink is offline   Reply With Quote
Old 12-09-2015, 10:24 PM   #3242
Blizzard
Yes, I have the stage iv front and stage i rear kit. So I get to use the same size pads front and rear. It is actually very nice. When I get pads I like, if the fronts still wear fast I just put the rear pads up front and buy new rears.
The brakes do feel very well balanced. I admittedly don't have a ton of experience with a ton of different braking systems, but I have enough seat time in this car to know. I can also attest to the fact that this kit (as well as the AP kits) is so much better at heat management and is well worth the cost in the long run.
Old 12-09-2015, 10:48 PM   #3243
CSG Mike
CSG Mike's Avatar
Can you take a picture of the pistons for me when you take the pads out? Same angle of each caliper if possible.
Old 12-09-2015, 11:10 PM   #3244
Blizzard
Yeah, it might be a while though.
Old 12-10-2015, 11:06 AM   #3245
LOLS2K
/scion
LOLS2K's Avatar
Drives: '13 86 M/T
This is what my P.mu CR pads look like after one track day. Sorry bout the poor pictures:
Old 12-10-2015, 03:50 PM   #3246
drift86
Drives: GT86, 22 BRZ
I've got a question around spring rates (apologies if it has been asked before).
The stock rates are something like 2.3KG front and 3.3KG rear, making the rear about 50% stiffer than the front.
It seems most aftermarket coilovers are running the same rate front and rear, or very similar rates. eg. 6kg/6kg, 8kg/9kg, 8kg/7kg. Its certainly not 50% heavier on the rears like the stocks.
Doesn't this change the balance of the car towards much more understeer?
Or are you gaining a lot more front grip with the coilovers via the other improvements (greater camber etc) and negating this?
drift86 is offline   Reply With Quote
Old 12-10-2015, 04:45 PM   #3247
Lynxis
Lynxis's Avatar
Drives: 2013 WRB BRZ 6MT
BP-20 F and R
I've read a lot of people complain that the BP20s don't last and seem to wear faster the farther you get into them. I'm planning to get the RR Racing sport front kit but I don't plan to run BP20 pads.
RR Racing claims stock bias is retained with the front kit but recommends running their rear kit to move bias to the rear vs OEM. I don't plan to get the rear kit so with that in mind, it looks like I may want to consider running a more aggressive pad in the rear? I was thinking of trying something like Carbotech XP8 in the front and XP10 in the rear, would this be advised or should I use similar compound front and rear? Note that I don't have any aero at all, not even a spoiler.
Lynxis is offline   Reply With Quote
Old 12-10-2015, 04:56 PM   #3248
EAGLE5
Dismember
EAGLE5's Avatar
Drives: 2013 Red Scion FR-S
Suspension works as a system between dampers, springs, tires, inflation, valving, settings, bump stops, roll bars, bushings, etc. You cannot just look at the spring rate of one setup and compare it directly to a completely different setup. You should look at the total product. Please, correct me if I'm wrong.
Simple question, hard to find answer... Mango22 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 5 05-16-2013 06:23 PM
Silly question about protecting track rims sw20kosh Tracking / Autocross / HPDE / Drifting 16 04-25-2013 12:34 PM
Asking the question that I already know the answer to. Are the engines the same? Bigmaxy Engine, Exhaust, Transmission 10 01-19-2013 07:47 PM
Random dog-related question for those who have their BRZ GMU-BRZ BRZ First-Gen (2012+) — General Topics 11 05-31-2012 07:48 AM
Got my answer - BRZ comes with HID headlights as STD Z_Rocks BRZ First-Gen (2012+) — General Topics 20 01-10-2012 09:54 AM
