Old 04-15-2014, 06:05 PM   #71
Propaganda
Diamonds & Cadillacs
Drives: '13 fr-s, 1974 911s
Mine started making the chatter sound recently... Need to see if it goes away with the clutch pressed in. Hmm
Propaganda is offline   Reply With Quote
Old 04-21-2014, 08:03 PM   #72
Young_makaveli
Young_makaveli's Avatar
Drives: 2013 frs
Here is sound clip
[ame]http://youtu.be/4zmGh-qqYh0[/ame]
Sent from my SM-N900W8 using Tapatalk
Young_makaveli is offline   Reply With Quote
Old 05-03-2014, 11:56 AM   #73
Young_makaveli
Drives: 2013 frs
Still no updates from anyone ?
Old 05-15-2014, 04:28 PM   #74
Young_makaveli
Drives: 2013 frs
Bump ..I'm having this noise some times at cold start
Old 05-22-2014, 08:55 PM   #75
bakerr6
Drives: 2013 raven black fr-s
I'm having this noise constantly. I'm going to be going FI,s o I'll update if this alleviates the problem. We shall see (going to replace clutch assembly also)
bakerr6 is offline   Reply With Quote
Old 12-10-2015, 02:23 PM   #76
Scracho
Drives: 2018 Subaru BRZ
Any updates on this issue?
I and a friend have noticed the same thing on both of our cars. I have had my FRS to 3 different dealers and the last compared mine to 3 other vehicles in their inventory and they said all of them seemed to suffer from the same noise.
On my fourth 86... and everything in between
Scracho is offline   Reply With Quote
Old 12-10-2015, 02:54 PM   #77
Sigh-on-Rice
Waited 5 years for this
Sigh-on-Rice's Avatar
Drives: '18 MX-5 Club
Are you talking about the clutch making a rattling noise when idling cold and in neutral? And when you depress the clutch, the noise stop? It does it for about 20 minutes. After a transmission oil change, it gets noticeably louder. If so, then I believe it's normal.
Old 12-10-2015, 02:56 PM   #78
Scracho
I suppose that would be the noise lol.
Old 04-18-2019, 04:49 PM   #79
Lakitu
Lakitu's Avatar
Drives: 2017 Halo 86
I have this issue, directly related to possibly 4 things: clutch, idle, gear oil, and AC
1. Cold start the car with AC off = gentle knocking sound
2. Press clutch = noise goes away
3. Release clutch = gentle knocking noise returns
4. Turn on AC = noise increases in loudness
5. Press clutch = noise goes away
6. turn off AC = noise returns to gentle knocking
7. Drive car through all gears = can't hear noise if its there (car exhaust probably masking the sound)
No matter how long I drive the car for the noise persists, as long as upwards 3 hours at stops and in idle.
It sounds like ice cubes sloshing around in a huge cup.
Was told this sound is completely normal specifically if you have Motul300 in the transmission, so I've been ignoring it for about 10K miles. Someone told me that the input gear is smacking the teeth on the idler gear because Motul300 is apparently much thinner than OEM gear oil. No associated issues with shifting or driving. Car is as smooth as butter. Just noisy.
It is a bit concerning as it is very audible from outside. It makes me not want to run the AC at all and suffer. I might switch back to OEM gear oil to experiment and see if it goes away.
Build Thread / Daily Driver
OFT Stage 2+, GrimmSpeed CAI, JDL Ultra Quiet FP, Perrin 2.5" Resonated CBE, Enkei 18x8.5 +45, 245/35 Continental ExtremeContact
Lakitu is offline   Reply With Quote
Old 04-18-2019, 04:51 PM   #80
Lakitu
Lakitu's Avatar
The scariest thought is if there is a tooth missing off a gear, and its just bouncing around in there. O_O
Old 04-18-2019, 08:09 PM   #81
Originally Posted by Lakitu View Post
I have this issue, ............I might switch back to OEM gear oil to experiment and see if it goes away.
That would be my suggestion.
Knocking sound from what sounds like rear suspension husker741 Issues | Warranty | Recalls / TSB 12 04-24-2017 05:26 AM
Cold weather knocking during start ups. JDMenrique Issues | Warranty | Recalls / TSB 38 01-12-2015 11:53 PM
Knocking/Rattle on start up. jimbobrand Issues | Warranty | Recalls / TSB 18 01-13-2014 11:34 AM
Bubbling/knocking (but not liquid) sound aside from chirping mike_ekim1024 Issues | Warranty | Recalls / TSB 22 05-05-2013 03:20 PM
Knocking sounds from lowering springs? bbaik Issues | Warranty | Recalls / TSB 7 03-07-2013 11:50 PM
