#15 |
For street use on max performance summer tires, I really liked the following setup:
- Pads: Stoptech street performance - Fluid: ATE Type 200 - Rotors: stock Nice firm pedal. Pretty good bite. Minimal dusting. Very little squeal, if any. Definitely enough for backroad and canyons, and even some light track use. I think it's a great value for the price honestly.
2022 BRZ Build 2013 FR-S Build |
#16 | |
Undisputed El Presidente
Drives: Zenki 37J ZN6
#17 | |||||||
Drives: 2016 Toyota 86 GT (Auto)
My dad has a PhD. in Physics ![]() I like how did you explain the importance of the Front brake specially in front engine cars... But for now I think I'll stick with the plan adv ised by the majority of you guys, Sticky Tires + Streets Performance Pads + Better Fluid Many thanks for your reply and contribution. Noted With many thanks Quote:
![]() Quote:
![]() I'll look up the Wibmax W2 Quote:
![]() I'll most likely go with: 1- Tires: Goodyear Max Summer Tires 2- Pads: Stoptech street performance 3- Fluid: Castrol SRF Quote:
Appreciate all your kind feedback, I think more or less my question is answered, and I have a clear upgrade plan, many thanks to everyone who took the time to share their knowledge and experience |
#18 |
Not Bаnned Anymore
Drives: Heavily Modified FRS
Anytime
#19 | |
![]() Damn typos lol |
#20 | |
Drives: FR-S Whiteout
Intent > Content
cowardice is the mother of cruelty. |
#21 |
Drives: 2012 BRZ Premium WRB 6MT
UNREAL,
Have you read my brake upgrade guide? It goes into a lot of the why's behind others' recommendations in this thread. |
#22 | |
I just saw your reply now, went to your post, and Wow, very informative and well organized post... Many thanks for your help
#23 |
I'm late to the game, again . . .
If you haven't already started purchasing your braking "upgrades", consider this: Higher temp capacity brake fluid will NOT improve typical street braking, even when we're talking about hooliganism. If you need more heat capacity because you have been boiling fluid in your braking situations, then, sure, replace the fluid with something "better." But, unless you have experienced marked brake fade (soft pedal, pedal goes to the floor under heavy braking) it's unlikely that you have boiled your fluid. If my thinking about your particular needs is correct here, then you don't NEED to replace the fluid. Also, replacing your brake lines will not improve braking under street conditions. Having said all of that, I do highly recommend bleeding the brakes to maximize function and firmness, and that can certainly suggest simply flushing the system with new stock (or any DOT 3/4) fluid to start fresh, and ensure maximum fluid capabilities by eliminating air / dirt in the system. If you just bleed, any decent DOT spec fluid will do (heck, I like Ford Motorcraft fluid for such an application). If you want to flush the whole system and start fresh, there's no problem with staying with a stock/street fluid if you haven't boiled your fluid. But, if you want to, by all means upgrade to something with higher heat capacity. SRF and Torque are $$$, but they work great under extreme conditions. Motul RBF is also an excellent fluid, albeit with a lower boiling point (it's also 1/2 the price of the other two). I've raced with all of the fluids, and they all work great. I'm a personal fan of the Ferodo DS2500 for this application, and I even enjoy them on the track (lapping days, NOT racing). Other pads mentioned are good choices too. Check out Michelin PSS as a tire option. Since I don't think you're worrying about heat cycling and vulcanizing from track or autocross duty, I think the Michelin is an excellent high grip street choice. Other choices mentioned will work fine also, and pricing may be a factor where you live. Also, if your braking difficulties are related to a lot of sand or grit on the roads, no high performance street tire will be a magic solution to that issue, but they'll help. Finally, if you'd like to swap out rotors (just because, or its time to replace anyway), take note that Centric makes some nice "performance" options in the stock sizes with slotted and high-carbon options; all available around $50.00 per rotor (in the US at least). Hope all of this helps. |
#24 |
Drives: 2013 Brz C38 (bought not built :P)
Good to know and makes a lot of sense. The physics aspect of braking still stands though, bigger brakes in front are more beneficial due to the momentum/weight being all up front during braking.
| tire size advice needed | marcom | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 8 | 09-08-2015 03:45 PM |
| FA20CLUB turbo kit advice needed | joedaniali | Forced Induction | 26 | 02-24-2014 01:25 PM |
| A little strategy & rubber advice needed | ultra | Tracking / Autocross / HPDE / Drifting | 19 | 01-31-2014 02:36 PM |
| Advice needed on wheel stud issue | THEmailman | Issues | Warranty | Recalls / TSB | 6 | 12-16-2013 10:54 PM |
| What to do.. Advice needed | fuddbutter | AUSTRALIA | 44 | 01-29-2013 07:02 AM |
