Old 12-08-2015, 10:23 PM   #15
Trust86
Drives: 2016 Halo FRS
Get a louder exhaust and some hello kitty stickers
Trust86 is offline   Reply With Quote
Old 12-08-2015, 11:04 PM   #16
White64Goat
If the TOB is turning all the time, as mentioned above, then that's just a shit poor design.
The Following User Says Thank You to White64Goat For This Useful Post:
rice_classic (12-11-2015)
Old 12-08-2015, 11:42 PM   #17
I think it's a better design.
However, you must have a high quality bearing ....
Back in the day, when the TOB retracted, every time it was called upon to do its thing, it was cold and stationary and got slammed up against the nasty fingers of the pressure plate ...... that were rotating at engine speed.
Musta felt kinda like this .....
Old 12-09-2015, 05:10 PM   #18
Cartman
Cartman's Avatar
Drives: 10 Series Scion FR-S
My TOB is making noise as of late, I just ordered a TOB from rockauto for 36 bucks and may replace it during winter vacation.
Cartman is offline   Reply With Quote
Old 12-09-2015, 06:13 PM   #19
fumanchu1
Drives: 2013 Brz C38 (bought not built :P)
I'll have to change mine in the summer but thinking I'll go with the ACT heavy duty one (hopefully it's made of stronger material, more resistant)
fumanchu1 is offline   Reply With Quote
Old 08-16-2016, 08:41 AM   #20
swill38
Drives: 2014 BRZ Limited
Does this require dropping the transmission? I'm having a squeak after I depress a warm clutch so I'm guessing. Replacing the throws it bearing could help.
swill38 is offline   Reply With Quote
Old 08-16-2016, 12:18 PM   #21
zc06_kisstherain
zc06_kisstherain's Avatar
Drives: SWP BRZ
post some DIY
Old 08-16-2016, 12:44 PM   #22
gramicci101
Off Topic
Originally Posted by zc06_kisstherain View Post
post some DIY
http://www.ft86club.com/forums/showthread.php?t=25054
Boom.
The Following User Says Thank You to gramicci101 For This Useful Post:
zc06_kisstherain (08-16-2016)
Old 08-16-2016, 01:30 PM   #23
It may be a bad throw out bearing; it could be a dry clutch fork; it could be something else.
The clutch fork can be somewhat lubricated without removing the transmission.
The transmission (or engine ....) must be removed to change the TOB (Throw Out Bearing).
jcw99 (08-18-2016)
Old 08-18-2016, 05:45 AM   #24
GT86>4>ANC
Drives: Argento>FRS
I took mine in 1week ago for that squeaky clutch. Dealer replaced TOB . Now I have this annoying rattle at 1st gear when coming up on rpm, goes away above 2k rpm..told the mechanic the same day and he said let it wear out for a couple of weeks and if its still there bring it back in.
GT86>4>ANC is offline   Reply With Quote
Melted Throw Out Bearing danthedirt Issues | Warranty | Recalls / TSB 59 01-25-2018 06:32 PM
Throw-out bearing mhigham Issues | Warranty | Recalls / TSB 71 08-18-2016 11:21 AM
throw out bearing clips... Shit Luck Engine, Exhaust, Transmission 0 04-12-2014 07:34 PM
FS: NJ O.E.M. Clutch, flywheel, throw out bearing Michaeljp92 Transmission and Driveline 9 02-04-2014 12:42 AM
Throw out bearing/Left Front speaker/Paint Chips 2014scionfrs Issues | Warranty | Recalls / TSB 11 01-06-2014 12:20 PM
