Old 12-04-2015, 11:53 AM   #29
DustinS
DustinS's Avatar
Drives: 2013 Ultramarine FR-S
Some good Fab work. Subbed for more updates and content.
The Following User Says Thank You to DustinS For This Useful Post:
NotSoJDM (12-04-2015)
Old 12-04-2015, 12:12 PM   #30
bfrank1972
Drives: 2013 FR-S Argento
Originally Posted by NotSoJDM View Post
I have worked on jackstands for the past 8 years so a few months back, I decided to get some Quick Jacks.
They were petty awesome, but I really wanted a full size lift in the garage, so I opted for a 2 post a couple months after.
It's been awesome to have, and has made quick work of all the cars that come through.
Awesome! You have me thinking about picking up a couple of quick jacks myself, pretty reasonable. Any downsides you notice while using them?
Old 12-04-2015, 12:14 PM   #31
NotSoJDM
NotSoJDM's Avatar
Drives: '13 BRZ | '04 E55
Originally Posted by CokeSlap View Post
I'm curious why you chose the edelbrock SC? And how it has held up, your inputs, areas it may be lacking, goals, etc. Any first hand info would be great!
If you have some time, I really recommend reading this thread here. I have posted a ton of good information in there regarding the kit, including some track data.
When I first got the kit, I did a review on it. You can check that out here. It goes over a lot of what you are asking about.
In a nutshell, I was not happy with any of the kits I had personally installed up to this point. They all had some problems during installation (even a $8k Cosworth setup). After Edelbrock announced their kit, I started to follow the progress, and it became evident that it was going to be the kit for me. After installation, my suspicions were confirmed. The instructions were extremely detailed, everything fit exactly as intended (no cutting, welding, etc), and the support being one of the early kits was top notch.
So far, I have no complaints with this kit. I daily drive it, autocross it, track it, and it has met or exceeded just about every expectation I've had.
My end goal for the kit is 300+whp with a pulley on pump gas. And some more with flex fuel down the road.
I'll link you some videos in a bit.
NotSoJDM is offline   Reply With Quote
The Following 3 Users Say Thank You to NotSoJDM For This Useful Post:
CokeSlap (12-05-2015), hmong337 (12-04-2015), Summerwolf (12-04-2015)
Old 12-04-2015, 12:48 PM   #32
NotSoJDM
NotSoJDM's Avatar
I REALLY loved them over a traditional Jack and stands. They make lifting the car to jack stand height really easy, and they fit under my low car easily.
The only real downside is the hydraulic lines, which are a necessary evil. They are cumbersome when you're trying to move around in front of the car, as they go from the pump to each side of the Jack.
Even with that downside they are well worth it.
The Following User Says Thank You to NotSoJDM For This Useful Post:
bfrank1972 (12-04-2015)
Old 12-04-2015, 01:49 PM   #33
Ramn
Ramn's Avatar
Drives: 2015 GTI
Do you have more photos of the center exhaust from a distance?
Ramn is offline   Reply With Quote
Old 12-04-2015, 03:52 PM   #34
NotSoJDM
NotSoJDM's Avatar
Oddly enough, just about every picture I have of it, its not visible becuase of the angle its at under the car. I will ask him to take a few for me today.
In the mean time, here are some pictures of another exhaust I did that came out of a Lotus diffuser. This one exits above the diffuser since it didn't have the hole that the other guys has in the middle of the diffuser itself. This is the rest of the exhaust that compliments the AVO turbo outlet and overpipe I posted earlier. Customer request was a single piece exhaust from the Overpipe-back, and must have 3" tips that exit 3.5" trim rings. It was an absolute mother to build, but came out pretty cool.
Tips I made:
The full bitch:
Installed (missing diffuser lol):
I will get some pics of both of them in the completed state here shortly.
The Following 2 Users Say Thank You to NotSoJDM For This Useful Post:
DustinS (12-04-2015), Ramn (12-04-2015)
Old 12-04-2015, 04:17 PM   #35
DustinS
DustinS's Avatar
The Exhaust Diffuser combo that made me cut my bumper. Looks great.
Old 12-04-2015, 06:15 PM   #36
NotSoJDM
NotSoJDM's Avatar
Thank you. Here are some pics I just got.
- AVO turbo car - No diffuser cutout
Sorry for the pic quality.
- NA car - Exhaust cutout in diffuser
MaximeT (12-11-2015), Ramn (12-04-2015)
Old 12-04-2015, 06:49 PM   #37
ichitaka05
Site Moderator
ichitaka05's Avatar
Drives: ichi 86 Project
2 Questions
1. Do you have more detail pic of SSR GTV03? Looks like 17's, but iirc 17's they only make in 17x7 with 50 offset.
2. Where do I need to send the money, so you can make me a custom exhaust. Cuz seriously, you fab job is awesome!
Keep up the great work!
Old 12-04-2015, 07:33 PM   #38
NotSoJDM
NotSoJDM's Avatar
2 Questions
Thanks!
1) The SSR GTV03s are 18x8.5 +44 square with a 5mm spacer in the front and 10mm spacer in the rear.
2) I don't want to infringe on your vendor rules, but if you'd like to talk I wouldn't mind hearing what you had in mind for a design. I think you were up at 86fest at Summit Point this year, which means you probably aren't too terribly far away from me
Old 12-04-2015, 07:59 PM   #39
ichitaka05
Site Moderator
ichitaka05's Avatar
Thanks!
Ah~ gotcha, I thought it was 17x7 ones and not the 17's. Thanks for the detail info.
As for the vendor rule goes on this, as long you don't make a continuously business out of it. Example, just say you did make a custom exhaust & say I posted the exhaust everywhere and you start getting crazy amount of request for custom exhaust. When you start making custom exhaust every wk or even a month and advertising it on the forum, THEN that'll be going against forum vendor rule.
If you just keep your work in member journal and not advertise it, I don't see anything wrong with it.
FYI 86Fest is in Cali & I missed this year's 86Fest. You mean 86EXPO? If that's the case, I flew there lol I have several friends up there
I'll PM you later more detail on the idea. For now, I'm hangry and I need to eat first.
Old 12-04-2015, 08:02 PM   #40
NotSoJDM
NotSoJDM's Avatar
Good to know. Ah yes 86EXPO was where I was lol. Look forward to hearing from you.
Old 12-05-2015, 12:34 AM   #41
shiumai
shiumai's Avatar
Drives: 2013 DGM BRZ, 2020 C8 Corvette
I'm liking those fab jobs - great work. Also, it's also comforting for me as a newbie e-force owner that someone who works on cars and knows this stuff much better than i do chose the same supercharger after considering the other available options.
shiumai is offline   Reply With Quote
The Following User Says Thank You to shiumai For This Useful Post:
NotSoJDM (03-03-2016)
Old 12-05-2015, 10:24 AM   #42
CokeSlap
Drives: 2014 Monogram FRS Whiteout
Excellent! Thank you very much for all of the info!
Previous Ride
1992 Acura Integra GSR in Aztec Green Pearl
CokeSlap is offline   Reply With Quote
Edelbrock E-Force Supercharger itsibarra Forced Induction 938 07-31-2021 04:48 PM
**EDELBROCK E-FORCE SUPERCHARGERS Available now!!** 86SPEED Forced Induction 8 03-28-2017 03:01 AM
Review: Edelbrock Supercharger Kit NotSoJDM Forced Induction 153 02-25-2016 06:53 PM
Edelbrock E-Force Supercharger FRS/BRZ Install Titanmotorsports Forced Induction 1 02-17-2016 11:24 AM
Edelbrock's Custom BRZ with SC Lonewolf Southern California 9 08-02-2015 05:17 PM
