Old 12-03-2015, 07:02 PM   #29
StegaDragon
StegaDragon's Avatar
Drives: 13 Sc10n FR-S
I'm pretty sure he means with a regular intake manifold set up, there's a limit to how short the runner can be due to the distance between cylinders
SC10N driver
StegaDragon is offline   Reply With Quote
Old 12-03-2015, 07:13 PM   #30
2much
I wanna go fast
Drives: 2013 FR-S 6MT
Originally Posted by GSpeed View Post
Yup. Motec is popular for a reason, though... It's pretty powerful stuff and really isn't a bad price for the capabilities it's got.
I mean, no one's disputing it's expensive, but it's more than a fuel management system, it's basically everything but ABS. Traction control, launch control, etc. can all be handled. Especially with throttle-by-wire, you can do fun stuff like throttle-controlled traction control, etc.
I certainly did not mean to add anything meaningful to this discussion, just could help myself with the FATF quote
2much is offline   Reply With Quote
Old 12-03-2015, 07:30 PM   #31
Calum
That Guy
Drives: 2013 asphalt FRS MT
Originally Posted by celek View Post
why do you say that can not be made short enough?
If you make the plenum bigger to get the runners shorter, you could sacrifice throttle response. But technically speaking it is possible.
Old 12-03-2015, 07:45 PM   #32
GSpeed
GSpeed's Avatar
Drives: 2015 BRZ
Wow, that was a pretty obscure quote. Nicely done. Slipped right by me.
Guess I've been quoting too much Talladega Nights.
Jake
GSpeed is offline   Reply With Quote
Old 12-04-2015, 08:34 AM   #33
celek
Resident Gear Head
celek's Avatar
What if its set up like a LFA engine? "google" now?
celek is offline   Reply With Quote
Old 12-04-2015, 10:46 AM   #34
200hp/tonne
200hp/tonne's Avatar
Drives: Raven Fr-S
With Ecutek, will you keep the MAF style of tuning? Or will you switch to Speed-Density like some FI people? For MAF you can make a light duty CF or Aluminum plenum like the BMW M cars and still be mechanically compatible with the intake. Also, making a MAF tune should be easier
FR-S Mod target: 200 BHp / Tonne
4lb Li Battery, RPF1 17x9, 245 RE71R, RCE T2, OFH, OFT Stg 2, Berk Over+Front Pipe, , STI Eng/Trans Mts, PU Bushings, Forrester Liq-Liq oil cooler, Al Driveshaft, OSGiken Diff
200hp/tonne is offline   Reply With Quote
The Following User Says Thank You to 200hp/tonne For This Useful Post:
celek (12-04-2015)
Old 12-04-2015, 11:03 AM   #35
celek
Resident Gear Head
celek's Avatar
Which is why I referenced the LFA's engine
Old 12-04-2015, 11:20 AM   #36
StegaDragon
Again the issue is distance between banks, the LFA is a V8 and the intake ports are relatively close together compared to boxer engines, while individual TB would not have an issue, running a single intake manifold limits how short the runner can be without running a rather large intake plenum
SC10N driver
The Following User Says Thank You to StegaDragon For This Useful Post:
wparsons (12-05-2015)
Old 12-04-2015, 11:21 AM   #37
StegaDragon
Or maybe do two intake manifolds
SC10N driver
Old 12-04-2015, 11:26 AM   #38
200hp/tonne
Drives: Raven Fr-S
Throttle bodies would still be at the heads, the plenum would just provide filtered atmospheric pressure air to the runners through the MAF, and can be made from very thin gauge aluminum or CF. This is to avoid sucking in air from the engine bay
celek (12-04-2015)
Old 12-04-2015, 03:01 PM   #39
Spartarus
...Just add nauseum
Spartarus's Avatar
Drives: 2003 (AP1) S2000
SC10N driver
The LFA is a v10, not 8, and the design is not original.
BMW introduced it to mass production on the S62 engine for the E39 M5 12 years earlier. Yes, it can work.
The concept uses ITB's to compensate for the throttle response issues inherent in a large plenum.
That's the only practical way to use MAF with ITB.
I have never seen MAP-based speed-density work right with ITB's. You lose all your vacuum above about 40% throttle.
The smoothest running ITB setups (without a plenum) I've seen and worked nearby are all on a high-resolution alpha-N map where the primary inputs for fueling are throttle position and RPM. Significant corrections include ambient temp/pressure, wideband closed-loop at low throttle settings, and very thorough tip-in and overrun corrections.
Getting them to idle is harder than tuning them to run.
There are many ways to displace.
-Spartarus
Spartarus is offline   Reply With Quote
Old 12-04-2015, 03:06 PM   #40
StegaDragon
Woop confused it with the IS-F
SC10N driver
Old 12-04-2015, 04:15 PM   #41
200hp/tonne
Drives: Raven Fr-S
http://www.hipermath.com/engines/throttle_body_size
Old 12-04-2015, 08:02 PM   #42
celek
Resident Gear Head
celek's Avatar
SC10N driver
exactly a very large plenum, what else would go in the middle of the engine
Beginner STX Build Whiteout FRS Build Thread Hachi86Roku Tracking / Autocross / HPDE / Drifting 21 03-31-2020 07:52 PM
[B is for Build] BRZ resurrection build im_topher Member's Car Journals 49 03-05-2018 09:41 AM
No build date on passenger side sticker, how to determine build date? BBYZILA Scion FR-S / Toyota 86 GT86 General Forum 5 01-20-2015 10:14 PM
Dat sound - ITBs RWD_only Engine, Exhaust, Transmission 88 11-18-2014 04:19 PM
20v ITBs Nafe NEW ZEALAND 4 05-20-2014 08:03 AM
