Old 12-02-2015, 09:30 PM   #1
celek
Resident Gear Head
celek's Avatar
How to build ITBs
So not to stray from my Engine build thread here:
http://www.ft86club.com/forums/showthread.php?t=63901
I figured I would make a separate thread searchable via forums.
I picked up a scrap manifold from a well known FI kit. I have been trying to get one for over a year. Finally they had one, so don't think there is a plethora laying around that everyone can follow along.
It arrives next week so I can plan on how to attack it.
celek is offline   Reply With Quote
Old 12-02-2015, 09:30 PM   #2
celek
Resident Gear Head
celek's Avatar
Reserved
Old 12-02-2015, 09:32 PM   #3
celek
Resident Gear Head
celek's Avatar
Reserved #2
Old 12-02-2015, 10:12 PM   #4
Cueman
Cueman's Avatar
Drives: In Perfect Control At All Times
Good luck. I'm interested to see how you approach it. Really think it's worth cutting up an existing manifold to make two separate ITB manifolds?
Or do you have something else in mind?
What throttle bodies are you planning to use?
Cueman is offline   Reply With Quote
Old 12-02-2015, 11:05 PM   #5
airjonny
airjonny's Avatar
Drives: Nissan Murano
Man you're going all out on this! Can't wait to see the final product.
airjonny is offline   Reply With Quote
Old 12-02-2015, 11:18 PM   #6
JDM Haze
JDM Haze's Avatar
Drives: Whiteout FRS
Sweet! Subbed
JDM Haze is offline   Reply With Quote
Old 12-03-2015, 01:46 AM   #7
civicdrivr
civicdrivr's Avatar
Drives: 2018 Golf R
Yes yes yes yes yes yes
That is all.
Sent from my XT1095 using Tapatalk
Parting out HERE
civicdrivr is offline   Reply With Quote
Old 12-03-2015, 05:42 AM   #8
Captain Snooze
Because compromise ®
Captain Snooze's Avatar
Drives: Red Herring
*raises hand*
What's the difference, performance wise, of having four itb verses four tuned length runners from a plenum and one throttle body?
Old 12-03-2015, 07:18 AM   #9
celek
Resident Gear Head
celek's Avatar
*raises hand*
Longer your runners the more torque is built but at high end you lose HP.
BUT YOU WILL LOSE A BIT OF TORQUE WITH A SHORT RUNNER. But gain more top end. Additionally if you look at our factory manifold the passenger runners are longer then driver side. I have seen numbers on stock head flow they should be able to support 300HP easy but the problem lies in the induction as myself and others speculate. AKA intake manifold is a choke point. Additionally I have not done the math but I am sure 4 individual throttle bodies probably flow better and have more velocity and cylinder filling capabilities then a single throttle body like stock
Old 12-03-2015, 09:04 AM   #10
200hp/tonne
200hp/tonne's Avatar
Drives: Raven Fr-S
Are you planning a mechanical throttle, or one electric motor with linkage to the other bank, or 2 motors for actuation?
FR-S Mod target: 200 BHp / Tonne
4lb Li Battery, RPF1 17x9, 245 RE71R, RCE T2, OFH, OFT Stg 2, Berk Over+Front Pipe, , STI Eng/Trans Mts, PU Bushings, Forrester Liq-Liq oil cooler, Al Driveshaft, OSGiken Diff
200hp/tonne is offline   Reply With Quote
Old 12-03-2015, 09:27 AM   #11
Kuri
Kuri's Avatar
Drives: 2014 BRZ Limited SWP
Interesting..
#TrackDayBro
Kuri is offline   Reply With Quote
Old 12-03-2015, 10:27 AM   #12
DustinS
DustinS's Avatar
Drives: 2013 Ultramarine FR-S
Following.
DustinS is offline   Reply With Quote
Old 12-03-2015, 11:00 AM   #13
celek
Resident Gear Head
celek's Avatar
Probably single motor with linkage but I do have 2 spare motors, I considered electronics to split and duplicate the single from 1 to 2 motors. Additionally ability to tune individual signals to verify synchronized opening.
Old 12-03-2015, 11:19 AM   #14
Shark_Bait88
Shark_Bait88's Avatar
Drives: 2013 Firestorm FR-S
This is awesome. Can't wait to see how this turns out!
"Shark_Bait88, the man who’s spent the most money modding his stock FR-S and it’s still stock." -@jdnguyen
Shark_Bait88 is offline   Reply With Quote
Beginner STX Build Whiteout FRS Build Thread Hachi86Roku Tracking / Autocross / HPDE / Drifting 21 03-31-2020 07:52 PM
[B is for Build] BRZ resurrection build im_topher Member's Car Journals 49 03-05-2018 09:41 AM
No build date on passenger side sticker, how to determine build date? BBYZILA Scion FR-S / Toyota 86 GT86 General Forum 5 01-20-2015 10:14 PM
Dat sound - ITBs RWD_only Engine, Exhaust, Transmission 88 11-18-2014 04:19 PM
20v ITBs Nafe NEW ZEALAND 4 05-20-2014 08:03 AM
