Old 12-02-2015, 02:51 PM   #127
Gringosteve
Drives: UK Spec GT86
Mine dripped and I had photos of the drips from the engine down onto the overpipe and earthing point under the engine
Gringosteve is offline   Reply With Quote
The Following User Says Thank You to Gringosteve For This Useful Post:
Albaro08 (12-02-2015)
Old 12-02-2015, 02:52 PM   #128
Albaro08
Albaro08's Avatar
Drives: Frs asphalt Grey
Same here
Sent from my SM-G928T using Tapatalk
Albaro08 is offline   Reply With Quote
Old 12-03-2015, 01:17 PM   #129
Gringosteve
What I found when inspected my car, I provided the pics to the dealer as proof
Astroboy (12-03-2015)
Old 12-03-2015, 02:14 PM   #130
Albaro08
Albaro08's Avatar
Wow yours was really bad, mines it's there, but it's getting burned up by the manifold, and also its not my daily anymore, but if it was I'll probably looking like yours.!
Old 12-03-2015, 03:26 PM   #131
Astroboy
Astroboy's Avatar
Drives: None
Are you running an e tune?
Sent from my LG-D850 using Tapatalk
Astroboy is offline   Reply With Quote
Old 12-03-2015, 03:27 PM   #132
Gringosteve
No standard ECU no tune
Old 12-03-2015, 05:27 PM   #133
Albaro08
Albaro08's Avatar
Old 12-03-2015, 05:28 PM   #134
Albaro08
Albaro08's Avatar
Old 02-06-2016, 09:33 PM   #135
lupindub
Drives: Scion FR-S
So is this a problem only the MT has and if so how come only the MT have this problem?
lupindub is offline   Reply With Quote
Old 02-06-2016, 09:39 PM   #136
Albaro08
Albaro08's Avatar
Idk if it's only a Manuel problem but it's coming from the timing chain cover and it gets worse if you don't look for it soon luckily i caught mines fast before the 50k
Old 02-08-2016, 12:32 PM   #137
ShadowTS
Drives: Toyota GT86 SWP
If you look at parts diagram you will see that the automatic has a vacuum pump where the manual has the plate to close the hole.
See here, 6FC is automatic, 6F is manual
ShadowTS is offline   Reply With Quote
The Following User Says Thank You to ShadowTS For This Useful Post:
TofuJoe (07-10-2016)
Old 02-08-2016, 07:21 PM   #138
FRSBRZGT86FAN
FRSBRZGT86FAN's Avatar
Did they make a tsb for it and also if they did can you tell what was the service they did becuase my dealer is lost in space with this one. So I'm wondering if toyota knows about it
It's only a manual Problem, and I don't think it was an official TSB, but apparently they have updated the part for the UK at least, but honestly get the raceseng part, it looks genuinely better. Also the leak comes from an area that on the auto is used for a vacuum assisted pump for the auto transmission, the manual transmission doesn't need or have the pump so it's covered with a plate that is bolted on using the same pump bolt points and uses some toyota RTV silicone bead stuff to seal it. That seal was substandard and a gasket would've done a better job
The Following User Says Thank You to FRSBRZGT86FAN For This Useful Post:
lupindub (02-08-2016)
Old 02-08-2016, 07:22 PM   #139
Albaro08
Albaro08's Avatar
I can't see the pic
Old 02-08-2016, 07:24 PM   #140
Albaro08
Albaro08's Avatar
The same thing I told the tech a gasket would have been way better and probably wouldn't ever need change sense its not as hot at the valve cover and block gasket
Raceseng | Billet Aluminum Caster Camber Plates Raceseng Suspension | Chassis | Brakes -- Sponsored by 949 Racing 162 12-29-2014 10:32 AM
Raceseng | Billet Aluminum Engine Pulleys Raceseng Engine, Exhaust, Transmission 174 07-24-2014 12:24 AM
Raceseng | Lightweight Billet Aluminum Tow Hook Raceseng Cosmetic Modification (Interior/Exterior/Lighting) 13 08-27-2013 01:48 PM
SRP Billet Aluminum Door Sills pedalpusher Interior Parts (Incl. Lighting) 2 09-20-2012 10:25 PM
SRP Billet Aluminum Door Sills pedalpusher Cosmetic Modification (Interior/Exterior/Lighting) 2 09-20-2012 06:44 PM
